Question about Whirlpool Dishwashers
W10130986a dishwasher where is the filter located on this maching
My Whirlpool Quiet Partner II, Model #W10130986A makes a high-pitched squeal when filling, which varies in intensity when I turn the sink faucet off and on. What could this be caused by?
Sounds like a restricted water inlet valve on the dishwasher. Replacing the valve should solve it, if not there may be another issue with your house plumbing.
Oct 11, 2014 | Whirlpool Dishwashers
sounds like flowmeter is faulty
Jan 25, 2014 | Whirlpool Dishwashers
Water Laying in bottom of dishwasher
Usually there must be a filter screen in the dishwasher which can cause this to happen. It goes to the drain . If there is accumulation of food particles in the dishwasher filter screen then draining may be obstructed which can cause the water to be stranded at the bottom.
To exactly tell you where the filter is locate and how to clean it please specify the brand and model number of your dishwasher.Usually the filter is located at the back of the dishwasher near the drain. It is usually held in position by means of clips. You can just pop it out.Pour some hot water in the drain and clean the drain line also.
Feb 01, 2011 | GE Dishwashers
Water tremains in my dishwasher and teh cycle is finished.
Jan 15, 2011 | Whirlpool Dishwashers
Dishwasher won't drain
Dec 22, 2010 | Whirlpool Dishwashers
Not getting enough water flow into the dishwasher, suspect that a filter is clogged due to recent work on the waterline in the kitchen sink. Need to know where the filter might be located (on the...
You didn't specify a brand but most dishwashers don't have a water "filter." They may have an inlet screen at the water valve, which is typically located under the dishwasher. Generally, the lower front panel will have to be removed and you should then see the water lined connection to the unit. The front cover may have insulation behind it for sound deadening.
Be sure to turn off the water and power to the dishwasher working on the appliance.
Jan 01, 2010 | Dishwashers
Lx30h P2 ERROR CODE? WON'T DRAIN COMPLETELY - HELP
the p2 err. is on open or shorted rinse thermistor which is located on the back of the mach next to the vac. brkr. as for draining ck the drain valve for debris, and the end of the drain hose where it connects to the building drain
Dec 25, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart HD-20 home dishwasher that leaks occasionaly
ck the vac. brkr. on the back of the unit, if no vac. brkr. ck the air gap on the side of the mach. let me know how you make out.sounds like the leak occurs when mach. goes into the rinse cycle dont forget to vote thanks monomoy
Jun 22, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Not rinsing properly
make sure the heating element is cleaned and use a cleaner for your machine. Also check your filter and clean it.Mostly it is due to clogged filter or dirty and cacked on heating coil.
Good luck.
Make also sure the rinse agent is filled.
Apr 23, 2008 | Maytag MDB6000 Dishwasher
Dishwashers Logo
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
