Question about Boating
Mastercraft prostar 190 boat fuse
No power to the fuel pump
2 Suggested Answers
  • 65 Answers
SOURCE: Mastercraft Prostar 197,2005. Electrical problem?
Try your tether , plug and unplug it a few times , sometimes they stick, get corroded from the water..
Posted on Aug 22, 2009
Wellcraft owners manual
In the fuse holder inside the boat
May 15, 2014 | Boating
2011 Yamaha WR125X fuel pump fuse location
Hi, Anonymous for this scenario you will need your service/owners/ manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $10 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
2011 Yamaha WR125X fuel pump fuse location Google Search
http://www.mastercraft.com/teamtalk/archive/index.php/t-71486.html
YAMAHA WR125R Owner Manual
OEM parts for Yamaha
Yamaha Wr125 Service repair Manual Download Manuals Technical
Sep 27, 2013 | 2011 Yamaha WR125X
Where fuse panel located on a 1994 nitro 190 ft. bass boat
You may be able to find the answer on the boating forums.
http://forums.iboats.com/nitro-boats-364/?boatid=171
It most likely is located near your battery.
Mar 17, 2013 | Boating
Lost electrical power to fuel pump
There are many reasons why fuel pumps have no power, most (in tank) fuel pumps fail due to low fuel inside of tank.
These fuel pumps turn at an alarming rate which in turn causes an alarming amount of heat. This heat is then dissipated by the fuel inside of the tank itself.If the driver/operator allows to run the fuel very low and continue to do so, this will over time allow for the fuel pump to overheat due to the ONLY source used to cool the fuel pump is the fuel inside of the fuel tank itself. Electrically, view the operator's manual or similar source to locate fuel pump fuse and/or relay of which will open the electrical path when the fuel pump overheats.
This should be a pretty good starting point to locate/isolate electrical issue you may be experiencing.
Good Hunting to you & hope this gets you back on the road soon!
FASTESTNASCAR
Dec 27, 2011 | 1987 Mercedes-Benz Mercedes Benz 190 Class
Hi , i have a 02 yukon and was driving it and the motor shut down. i can start it right away, but when i press on the gas it shuts off. is this a fuel pump problem or a relay problem?
I WOULD CHECK FUEL PUMP RELAY IF FUEL PUMP KICKS ON AND OFF.BUT IF FUEL FILTER HAS NOT BEEN CHANGED.CHANGE THE FUEL FILTER THE FUSE/RELAY IF ALL IS GOOD I WOULD SCAN VECHICLE FIRST BEFORE BUYING FUEL PUMP.
Nov 26, 2010 | 1993 Mercedes-Benz 190
My 98 mastercraft is like not getting enough fuel to go fast it sputters off and on idle s ok but not as you give it gas
is it carbureted or fuel injected? what engine size? Ethanol gas is proven to stay stable in fuel systems for only 30 days in 90 + degree heat. has the boat been in storage for a long period of time? if so the carburetor is needing a rebuild. or the electric fuel pump for the injectors is malfuctioning. to confirm do these test. Tools needed(1) A compression gauge (2) a spark gap tester.(3) A Clymer service manual for your engine. (you can purchase from your local dealer. I know all these are expensive but if your going to be a boat owner you will always need them. Troubleshooting (1) check compression. without the engine size I'm giving you a average numbers. Look at your Clymer manual. all cylinders need to be over 100 lbs and equal each other within 5 lbs.(2) check spark. use a spark gap tester. all cylinders should jump a half inch gap. If you have good compression and spark nine times out of ten you have fuel problem. If the engine is carburated rebuild carburator. If fuel injected refer to the cylmer manuel for fuel delivery test.
Sep 02, 2009 | Boating
Aug 22, 2009 | Garden
My 190 shuts down will restart after about an hour, car is not hot or overheated
hello,fuel or ignition is missing,try to check your fuel pump motor if working,if not check fuel pump relay,your excess voltage protection on fuse box or maybe your transistor box (switching unit),,try to remove your spare plug to determine what is missing,fuel or ignition,,ty
May 08, 2009 | 1984 Mercedes-Benz 190
Mercedes benz 1992 190E
Lift the hood. Just below the screen, opposite side from battery, you'll see a plastic cover shielding the engine management, abs control box etc. If you search around there after removing the shield/ cover you will find a relay with a fuse plugged into the top of it. This is the pump / system relay.
Cheers John
Nov 13, 2008 | 1992 Mercedes-Benz 190
Boating Logo
37 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
