Question about Dishwashers
Miele g7783 Fill / Drain lights flashes steady after several minutes. I have 3 and they are all flashing.
  • 9 Answers
SOURCE: Miele G841 Built in. Intake/Drain light on/flashing and the dishwasher just shuts down.
In the user manual there's a section on how to clean the non-return valve. It's the plastic piece under the wire below the triple filter. Why did you pull out the machine? Did you kink the drain hose? If you don't find a clogged valve, spin the impeller wheel several times. It's under the valve inside the bottom hole where the valve came out.
Now here's the important step- Reset the fault! Power off/on the unit. If the light blinks when you turn it on, Press and hold the start button 4 seconds with the door open. Find the combination of off/on buttons to press to reset the machine in the user manual.
(Note: If the machine runs continuously as soon as you pressed on the power button, then you have water under the unit in the safety pan. Call Miele for help.) Now select the normal wash cycle close the door and start it. The drain motor always runs first. This verifies to the brain how much water is inside the machine when it starts filling. The drain pump runs for half a minute. If you hear it running with no drain check the drain hose especially if it's connected to a disposal. Clean the disposal.. If it's not running at all the light will go on again before filling, call Miele. If the machine fill up with fresh water, the drain works. Watch and listen when the light comes on. Is it filling or did it start circulating? Open the door, are the baskets are dripping wet? Then it filled and circulated. If the light comes on several miutes later then call Miele.
Posted on Apr 20, 2008
SOURCE: I have a miele g892sc
I had the same problem and I was able to fix it by trying to reset the machine. You push the on/off button for 5 seconds to reset and then disconnect the machine. I also check the drain for clogs. I found that the problem is with the water sensor on the drain. it is telling the controller that there is water in the drain so the impellers keep turning to flush the system. I pour CLR solution into the drain and let it sit for a few hour and then plug in the machine. It is working fine now.
Posted on Jan 08, 2009
SOURCE: Kenmore dishwasher Lock On light flashing
holding the button for four seconds will not do it, you have to hold it until the light stops blinking and
will go back to normal, normall takes more than four seconds to unlock the unit, this is something
the sears repair techs know becouse the are trained on all this things but, they will not share this things, becouse thats how they make money
Posted on Apr 18, 2009
SOURCE: miele dishwasher red inlet light flashes
This is most probably a software glitch. I had the same issue a week ago and my dishwasher is only about 2 yrs old and only gets used on average once a fortnight.
At first I did everything as the manual shows in the troubleshooting section. The whole process takes only about 5 to 15 minutes depending on how good of a handyman you are.
When I cleaned all the parts involved (all pretty clean to start with anyway) and connect them all back, sadly the red light wouldn't go.
It looked like I was stuck with the most hated option I had left: call the dreaded technician and be prepared to depart with some hard-earned cash.
Before doing that and out of desperation, I decided to surf the net for clues, blogs, forums, etc... and on one of them I found my answer.
One blogger suggested that "if anything else fails, try the 'reset' step" which means pressing at the same time the On/Off button and the Start/Stop button. That operation put a big smile on my face (and my wife's face too) as the red light magically disappeared.
My suggestion is "first try the reset trick and if that fails try and clean the parts as the manual shows". It'll save you headaches because the reset would do the trick in 90% of cases.
I work in IT and I can understand the fact that a software malfunction would trigger the red light and not reset it.
Good luck.
Posted on Aug 14, 2009
  • 177 Answers
SOURCE: Miele Intake/Drain light on/flashing and the
hi,
this is a general fault light which could mean anything without a Miele Technician coming out and connecting a laptop to the unit. However most common faults with dishwashers is a drain fault. Check for any kinked hoses and check the drain spigot under the sink where the drain hose connects into the u bend. Usually this is where food gets trapped due to the spigot not being drilled out large enough. This then causes a blockage.
Hope this helps.
Posted on Jan 25, 2010
Miele G 851Intake/Drain light flashes and program stops
http://m.miele.ca/OperatingInstructions/en-CA/Dishwashers/Previous%20models/Miele%20Dishwasher%20Manual%20G851%20SC%20Plus.pdf
Page 39
Jul 01, 2015 | Miele Dishwashers
Miele G641 SC Plus Drain /inlet light 4 short 1 long flash. How do I find a fault code chart?
Inlet / Drain is a general fault meaning there was no water movement when it was necessary to start the pump. Either it didn\'t drain out or it didn\'t fill the last time.
Call 800-999-1360 for free Miele tech support. They will advise you free of charge. You will perform step by step control board operations over the phone to clear the fault code as well as advise you how to cleanout the drain pump.
Dec 27, 2014 | Miele Dishwashers
Miele dishwasher 892 intake/drain light blinking
The intake light blinking error can be caused by several different problems and may take some pains taking effort to figure it out. There is some helpful information about Intake/Drain light flashing. http://www.techanswerslive.com/appliances/miele-icognito-dishwasher-service-mode-error-codes/12
Apr 18, 2014 | Frigidaire 24 in. FDB1050REC Stainless...
Miele premier novo, the main wash light flashing
Hi
Main wash is a fault indicator. The is a problem within the heater circuit, NTC, element, relay or loose wire. You will have to open front and check.
Remove 3 screw around dispenser and 3 10mm bolt around door. disconnect hose by drain pump and front of machine will open like a door.
Apr 01, 2010 | Miele Novotronic Premier 500 Front Load...
Outlet/inlet light flashing on miele dishwasher G674SC
Usually indicates a intake or drain fault - could be a plugged drain line at the garbage disposal or insufficient water coming into the unit
Sep 22, 2009 | Miele Dishwashers
Intake/drain light is flashing
When this happens with my dishwasher it usually means that the drain is clogged with food/debris.  To fix 1) remove bottom dish rack from machine 2) using a small cup, scoop out as much water as possible 3) remove inlet drain cover and unsnap the plastic insert and remove 4) rinse the plastic part and reinstall 5) start machine 6) if light still flashes, repeat steps 3 4 and 5 and restart
Jul 18, 2009 | Miele G892SC SS Dishwasher
Miele intake/drain flashes, no drain
this can happen after inactivity. the circulation pump seal sticks and wont turn . when the dishwasher starts to fill the circulation pump is pulsed on to see if the preasure switch switches over (to see if water is getting into the dishwasher) if the pump does not turn there is no preasure and the machine stops thinking no water has entered. turn pump by hand to cure.
Jul 18, 2008 | Miele 24 in. Touchtronic Platinum Built-in...
Dishwashers Logo
77 people viewed this question
Top Dishwashers Experts
Owen Barnes
