Question about Garden
John Deere 160 Mower Surging Problem
I have an older JD 160 that sat for many years. I replaced the battery, all belts, fuel line, fuel & air filter, spark lug, rebuilt the carb, and all new intake gaskets. Starts right up and runs great. The problem is, when I drive in first, it drives fine, 2nd gear has a very slight surging when driving, 3rd gear seems to surge bad, 4th is slight like 2nd, and 5th has no surge. It acts like the governor has issues, but I checked and adjusted it and it seems fine. The surging is more like a bucking and I cant figure it out. I have been working on small engines for 20 years but this has me stumped. Any ideas? Please!
Have a JD LT166W/48 and need a mower deck belt
Do you mean the John Deere LT166 Lawn Tractor with 48" Convertible Deck mower. If so, the replacement belt is GX10063, according to the maintenance sheet: https://jdparts.deere.com/partsmkt/document/english/featbene/fb_MaintSheet_LT166_48CdeckLawnTractor.pdf . One vendor has the belt here: http://www.greenpartstore.com/John-Deere-Drive-Belt-GX10063.html .
I hope this helps. If you have a different mower deck, please add a comment with more information about your specific mower. I may be able to find additional JD parts for the machine. You can also look up parts here: http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt .
May 31, 2017 | Garden
757 Ztrac. Why do I keep burning belts off?
if you dont use kevlar belts,then you are wasting money,they cost more,but,they last ten times longer,use the widest width that it can handle,dont buy from jd,it will cost you 100.00,go to ebay,etc,your tensioner should not be tight enoughto stretch the belt also,here is a jd belt,you can get cheaper just make sure it looks green or red,not rubber black, JOHN DEERE oem Mule Drive Belt TCU13195 737 757 Trak below 030000
OEM Replacement PTO Belt John Deere 737 757 Zero Turn Lawn Mower
JOHN DEERE TRAK 737 757 797 60 DECKS DRIVE BELT TCU13198 12760
Jun 24, 2015 | John Deere Garden
I need a belt diagram of John Deere L120 mower deck
Belt path for JD 100 series, 42" cutting deck, 2 blades.
Sep 14, 2014 | John Deere L100 Series
How do I replace the drive belt on a john deere 265? There doesn't seem to be a clear answer anywhere. Please help
you can look at the manuel that came with the mower or if you did not get one, go to the JD mower web site and look up you model and download the needed documentation. If that is not possible contact the local JD mower dealer and get a copy of the mower deck docs and look at the instructions for belt replacement.
Aug 03, 2014 | John Deere Service Repair Manual 240 260...
How do you change the drive belt on a john deere d110 riding lawn mower?
You can look at the manuel that came with the mower or if you did not get one, go to the JD mower web site and look up you model and download the needed documentation. If that is not possible contact the local JD mower dealer and get a copy of the mower deck docs and look at the instructions for belt replacement.
Jul 31, 2014 | John Deere Riding Lawn Mower. D110 42 in....
Scotts by john deere riding mower - 220 hours, 17.5 HP, 42" cut, Briggs & stratton engine -- New Strarter, new battery, good fuel... will turn over but engine will slow down then stop, will not...
Very high likelihood you have fuel line problems. Disconnect primary fuel line from bottom of fuel filter and blow compressed air back up the fuel line to the gas tank. This will clear the line of any trash. Reconnect fuel line to filter. Then remove spark plug and spray a couple of sprays of WD-40 into the cylinder.. Re-install spark plug and then restart. WD-4- will act as a starter fuel and will start the engine for enough rounds to get fuel pump to working to normal run.. Good luck.
May 15, 2011 | Briggs & Stratton Garden
JD Lx289 Surging at full revs, and full accelleration. Grinding noise and accellerator pedel vibrating/pulsating. more common when machine is warm.
When it is at full throttle start pulling the choke on slowly and see if it smoothes out and stops surging.if it doe,s you have a carb problem.this means it is getting too much air.you will have too rebuild or replace carb.
Dec 09, 2010 | John Deere 22HP Hydrostatic 42" Riding...
Garden Logo
67 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
