Question about Vermont Casting Signature VCS5008P Stainless Steel Propane All-in-One Grill / Smoker
Model VCS5008P All 5 burners go to high fire individually, with four or five burners on they stay on low. Reg. problem?
    Problem Solver:
  • 11 Answers
Yes thats a problem with the regulator, its not allowing the gas to regulate through to the control which is why its stuck on high. Try http://www.ibuygrillparts.com/50003815.html this is where I get all of my grill parts
Posted on May 10, 2013
GE TrueTemp range JBP30W0B1WW — 3 of 4 burners stay on HIGH even when set to low/medium.
as there is no make /model listed only a guess would be the switches
Dec 26, 2015 | Kitchen Ranges
Control knob doesnt adjust flame height?
Use a manometer to insure lp gas pressure is correct. The regulator for the stove may need adjusting. The air mixture adjustment may not be correct for PL as well.
Aug 18, 2014 | DCS Professional RDU305N 30" Pro-Style...
Desa heater
For (fire) safety, there is usually a thermostat that will turn off the gas if pilot light goes out.
So when you try to light the pilot you will have keep press & hold the pilot gas supply for at least 10 sec until the thermostat is heated up. Then only when the pilot light stays on continually, can you turn on the burner.
Forget about changing to a High pressure regulator!
Dec 24, 2013 | Heating & Cooling
Hello, we have a 3 switch stainless grill that has NEVER heated up properly. It always seems to stay luke-warm. Please help.
First, how high are the flames when turned to high as opposed to the low setting on each of the 3 burners? If there's no significant difference in height between the two settings, here's what I want you to do.
Turn off the gas tank (that's assuming you are using a 20lb LPG cylinder) and disconnect the hose from the tank. Wait 5 minutes and reconnect the hose to the tank. Turn the Tank Valve ON very, very slowly, until it's fully open. Now, light each burner individually turning them to high. Are the burner flames higher than before? If so, you just solved your problem.
Remember to turn the tank ON very, very slowly after turning it off to change the tank or if you turn the tank off after each time you grill. Also, when grilling preheat the grill with the lid closed, after lighting the burners.
Hope that solved your problem ... Happy Grilling!
Feb 15, 2011 | Ducane Rottisserie 2004 (LP) All-in-One...
I would like to upgrade one of my burner grates for a GE "Gas Slide-in Range (Model #JGSP20). The individual burner grates are 8 5/8" square and 7/8" high. I would like to locate one...
Hi!!
A new OEM grate for your unit will cost about $62.00 + S&H at this place http://www.repairclinic.com/PartDetail/Grate-or-Griddle/258336
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Jan 08, 2011 | Microwave Ovens
Hi Everyone, I purchased a Frigidaire range 4 years ago and found out soon after that these models (or similar models) are notorious for having issues where they burners don't heat consistently, etc... A...
Dude the ERC don't control the top burners. That is the electronic oven control. The top burners are controlled by them fancy knobs on top with individual switches. I have 2 vids here that might interest you. The first one show old school burner switch operation. The second it the new fangled dual burner switch. Watch this:
Electrolux stove manual featuring them fancy switches
Dec 20, 2010 | Kitchen Ranges
Our whirlpool gas dryer burner only lights one in four or five starts. The igniter always glows but the gas is not always started. Once started the burner stops after 10 or 12 minutes. What should I do?
Call the fire department. That puppy is gonna explode!
Seriously the average time a flame stays on is 25 seconds. 12 minutes would cause a Chernobyl type meltdown. If the burner is lighting intermitantly that is the coils7329710.jpg, feel the coils, the one that is hot is the intermitant one. This 4 wire t-stat could be wank,many have fallen in the past.38bdb0e.jpg
Mar 09, 2010 | Dryers
I have a Rheem (Criterion) unit and i'am having promblems with the main burner staying on. When i turn the unit on everything operates like it should up to the main burner staying on.Once the main flame...
Run a wire from the sensor down to the control board conector. Bypass the sensor wire around the connector in the blower deck.
The connection can be wire nutted on the sensor lead with the wire (16 or 18 guage stranded wire works) routed through the blower deck to the other side of the plastic wire connector on the blower deck.
The Sensor operates at high voltage but very low current. The connector will sometimes fail due to humidity or wear.
I have seen this on the Rheem or Ruud furnaces.
Hope this helps.
Matt
Jan 07, 2009 | Heating & Cooling
Gas Grill - flame always stays on high even though I've turned in on low
hey buddy that use to happen to me so what i started to do was once the fire was high i use to turn the gas off i hope this helped.
 infamouspk
Oct 07, 2008 | Sport & Outdoor - Others
Igniter for burners is firing continuously
Under each gas control is a switch that will turn on the spark module when rotated to the light position. One or more of these switches has failed. Some models these switches are individually replaceable, others the switch is an assembly of all four.
Jun 13, 2008 | Tappan TGF320 Gas Kitchen Range
Vermont Casting Signature VCS5008P Stainless Steel Propane All-in-One Grill / Smoker Logo
56 people viewed this question
Top Vermont Casting Grilling Experts
Dan Webster
Dan Webster
Tom Chichester
paulcarew
Are you a Vermont Casting Grilling Expert? Answer questions, earn points and help others
