Hitachi ps-970gj - Washing Machines
Hitachi 43F300 has no sound or picture. LEDs flash on circuit board.
Blew the dust out and pressed on all the wire connections to circuit boards and when I turned it on it powered up. I will clean all connections and check for bad solder. I bet if I move the set the problem will return.
P.S.-Brother has the same set doing the same thing.
Jun 05, 2009 | Hitachi Televison & Video
Yellow hue circle in middle of screen. after leaving tv on all night
spherical or oval shaped light starting in the center of your picture is an indication of an led backlit tv.. probably a hitachi. solution, replace light engine..ps no garuntees not with led backlit sets.. was bad idea to begin with. when the leds start going they start at the center and branch out.
Apr 13, 2009 | Hitachi 50V715 50" Rear Projection...
Hitachi 50ux53k
Good Day, egipson;
When the CRT's Coolant (fluid) get onto PCB's, one can clean the boards with acetone. BUT YOU MUST MAKE SURE ALL POWER IS REMOVED FROM TV. SAFETY FIRST.
Good Luck, big IRISH. PS after cleaning [place heavy plastic over effected areas.
Aug 26, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi ultravision digital
Good Day, mmurray1959;
To me it sounds like you to replace the lamp if you want to view your TV in the future. Good Luck, big IRISH. PS most lamps last about 5,000 hours.
Aug 18, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi TV green CRT tube
Good Day, optih;
Why do you think the TV's green CRT is not working? If that is the case I would think of buying a new TV, or spend about
$550.00 to repair the TV.
Good Luck, big IRISH. PS Only use a Factory Authorized Service Center.
Jul 25, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Wont power on
Good day, papamotts;
Hitachi has LED’s, green ‘lights’ and a red light to determine what circuit may be the problem; after removing the back of TV, bottom only, plug TV back in and observe which LED’s come on …..BUT most important which LED’s don’t come on; locate and note number, EG; DP37 and etc.
Good luck, big IRISH. Ps let me know.
Jun 21, 2008 | Hitachi 50UX26B/27K 50" Rear Projection...
Hitachi 53udx10b
Good Day, bostonsuxs;
Like every else in the world you have a convergence problem.
It is not an easy repair so I would suggest that you call an Authorized Service Center and have them give a written estimate, first. If you want to repair your self get KIT 10 from B&D ENTERPRISES AT 1-800-458-6053 or www. bdent.com.
Good Luck, big IRISH.... PS try texas.
Jun 19, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 50ux26b
Good day, 1gary;
May 17, 2008 | Hitachi 50UX26B/27K 50" Rear Projection...
I have lost disc to download my movies to my computer
website who makes yoru cam will have software and drivers ready
hitachi .com eneter your model in and download drivers for it
Jan 29, 2008 | Hitachi DZ-MV730A DVD Camcorder
Washing Machines Logo
53 people viewed this question
Top Washing Machines Experts
