Question about Behringer HPS3000 Professional Headphones
How to fix behringer HPS3000
I bought some headphones (the behringer hps3000) but the sound is the worst ever. I connected them to my TV but they were making some terrible effects and you couldn't even understand what were the people saying. Next I connected them to my computer and I heard a song. I couldn't hear the voice of the singer and the instruments had terrible effects again. Can anyone help plz? Any answer would be useful.
marsrover
  • 682 Answers
SOURCE: my behringer FBQ 1502 produces static sound even there is no input conneted
please bring a balanced cables in your input.(3 pin connector and cables)
Posted on Aug 22, 2008
  • 1138 Answers
SOURCE: Behringer B-1 Will Not Pick Up Anything
The microphone needs a phantom power supply to work. In your case you need a 48volt phantom power supply. Some mixers have this feature built in.The Micropower PS400 by Behringer would probably be a good choice.
Posted on Apr 29, 2009
  • 5603 Answers
SOURCE: My microphone doesn't do it right.
Some of the Podcast mics are condenser mics and MUST be used with a preamp or DEVICE that supplies PHANTOM power to the mic.
You computer DOESN"T supply Phantom power.
Read up on Phantom power in Google to understand it.
Posted on Jul 27, 2009
  • 5603 Answers
SOURCE: my effects on the behringer djx 700 dj mixer stop working how
This is a wild educated guess.
I repaired a Behringer guitar amp that had a DSP effects in it (BX1200 I believe).
The effects were on a seperate board and the board had its own 5 volt power supply. The filter capacitor for the 5 volt power on the board was UNDERSIZED and it had degraded causing the 5 volts to drop out of regulation, dipping to 4 volts. This caused the DSP effects to fail.
YOUR device MAY use the same DSP OR design.
Check the 5 volt power with an OSCILLOSCOPE to look for dips below the 5 volt operating point that occur at 120 HZ.
Posted on Oct 24, 2009
AJIN G
  • 6694 Answers
SOURCE: i have a behringer EP1500
hi,
check the power outlet socket to which the amp and mixer is connected. if there is any loose contact in that power socket, this problem can occur. try to use a good surge protector with emi filter for connecting the amp and mixer.
ok
Posted on Dec 29, 2010
Pmp6000 Behringer
What kind of speakers are you using and how are they connected to the mixer? Do you get a level in the headphones when you speak into the mic?
Mar 16, 2014 | Audio Players & Recorders
I bought wireless headphones, how do i connect them to the TV wirelessly
Normally the wireless headphones have a transmitter that send audio via wireless to the wireless headphones.
The transmitter needs to be plugged into the headphone outlet on the TV. This will switch off the speakers on the TV and sends the audio to the wireless headphones.
Sep 23, 2012 | LG 32LG30 32 in. LCD HDTV
Blown speakers?
usually with a blown speaker you will get sound but it sounds like there is an abundance of paper very loose on the speaker, so if there is no sound at all try taking the box apart if you are familiar with stuff like this and check to see if there are any loose wires or blown capacitors
Jun 24, 2012 | Behringer Music
No sound out of Behringer BXL3000 speaker
Suspected Faulty PC board Dead Capacitor Or Mod Pot I would suggest returning it for an exchange the problem is your speaker will work on a regular stereo because a stereo powers the sound internally causing the magnets in the speaker to vibrate Headphone jacks are designed to pick up off a seperate circuit board with a different connection to the main board hence the no sound from the speaker.
May 04, 2012 | Behringer Ultrabass Bxl3000
Brookstone wireless headphones have static along w/ tv sound
Well I just plugged into the cable box and that worked. On my old tv as well as my newer one the only audio out was an optical I had bought an optical splitter (one input for my sound bar and the other one to the optical to Rca) and an optical to rca for the headphones. This allowed me to use the headphones on all things going through the tv. For some strange reason it no longer works that way (just got my new tv this week). I bought all pieces on Amazon for a nominal cost. I'm going to doublecheck all connections again tomorrow.
Jul 12, 2010 | Brookstone Surround Sound Earbuds...
Just bought the brookstone wireless tv headphones. I have a Westinghouse 40 inch lcd tv. I plugged in the rca red/white into the audio out and I don't get any sound into the headphones?
I had the same problem with Brookstone wireless headset the only solution I found was plug in the red and white connectors to your cable box it works perfectly that way. Just make sure the red cable connector from the transmitter is connected to right red input connector on the box. I have a Comcast cable box. Now I need a solution for them on my PS3?
May 09, 2010 | Brookstone Surround Sound Earbuds...
Can you connect single behringer powered speaker to dell desktop
if you are good at wiring you could take old headphones and use it and plug it into the headphones jack and have it work without frying it but if you arent good at wiring dont atempt to because it could hurt the powered speakers or the computer
Mar 14, 2010 | Behringer Eurolive B212A Speaker
Behringer SL3242 Mixer has a noise problem.
It sounds like you have ground loops. This is noise generated by having interconnected equipment grounded at different physical locations. Especially a problem if you have a cable from your cable TV provider connected into your equipment.
Remove EVERY connection into and out of the mixer. Plug in headphones. Noise? If so, mixer needs repair. If not, re-connect equipment 1 piece at a time and assess for noise. If it slowly increases as you add connections you will need expert on-site help to fix it. If it is sudden, what was just connected is the source and steps need to be taken to lift the ground on the connection to that equipment.
Apr 15, 2009 | Behringer Audio Players & Recorders
Hooking up wireless headphones into the tv
u have to split the signal by having both the tv and the headphones getting the input,as you're probably only have the audio cables going to the headphones.You need an audio splitting cable (it has 4 malle connections) so you can put 2 in the tv and 2 in the headphone base.
Jun 16, 2008 | Radio Communications
Acoustic research aw722
No need to plug into the back jacks on the TV or change the out put of the tv audio source to the Front jacks
Dec 29, 2007 | Acoustic Research AW-721 Consumer...
Behringer HPS3000 Professional Headphones Logo
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
