Question about Boss Mt 2 Metal Zone Effects Pedal
Light will not turn off...
Hello,my pedal didnt transmited the maximum sound... I put the pedal volume in maximum and i almost couldnt hear the sound :\ i opened the pedal and now i have the same problem with the volume and now the red light dont want to disappear even when i switch it to no-distortion... what should i do? it is too expensive to fix it in a shop... sorry for my english =)
SOURCE: The Distortion Pedal has no effect on the sound.
i got d same problm. i fixed it myself.. check all the op amp ic's if they're all gud. if youre not sure, replace all 4 rc4558 ic's. in my case, i still felt a very small output signal from my pedal (equalizers, vol n gain ctrls r gud since they vary when i change the setting) so i suspected that one or 2 of my ic's were damaged. i only replace d last two op amps which my signal passes thru. i also had this problm with my marshall drive master. same diagnosis and solution. check your schematics
Posted on Feb 13, 2009
  • 133 Answers
SOURCE: light indicator is on
Try changing the battery, if it doesn't help, some possibilities are:
- dirty contacts or a broken wire on the footswitch
- a broken wire from the distortion output to the output plug
- a broken wire elsewhere in the unit (e.g. potentiometers or rotary controllers)
- a bad input / output level or other potentiometer or rotary controller
- a burnt out component (a bit unlikely, but possible, and it could be anything)
- a bad connector contact inside the unit
- a bad pin solder contact on ANY of the components inside the unit (wires, connectors, switches, jack plugs, resistors,variable resistors, trimmers, diodes, capacitors, transistors, ICs, etc.)
Broken wires / badly soldered pins need to be resoldered, but if there is damage to any of the components, they wil probably need to be replaced.
I hope you can find out what it is.
regards
3rq8 (Triarcuate)
Posted on Aug 02, 2009
  • 5603 Answers
SOURCE: when i turn on my pedal i can get the clean tone
Make sure the pedal has the correct power supply voltage, current AND polarity.
Also adjust the setting knobs as needed.
Make sure the in's and out's are corectely connected... it will work clean if they are backward, but no distortion.
Posted on Mar 12, 2010
  • 417 Answers
SOURCE: My MT-2 wont distort my guitar.
A few things to try....
Usually the adapter will over ride the battery when used.
1) Make sure your 1/4" cables are working properly without the pedal "in-line".
2) Take out battery, and use just the adapter only. Make sure it is the correct and proper adapter that works with Boss. Usually the PSA-120. If you are not using a Boss Adapter, make sure yours is a direct replacement with same specifications. 9V/200mA. And "tip negative". DO NOT use Radio Shack stuff, nothing against them, but there adapters just don't mix well with Boss products and the like.
2) Try just the battery, no AC adapter. Remember to unplug the input when not in use. Saves battery.
Basic rule of thumb...when using correct AC adapters for all your pedals all the time, and all sounds good, then take out the batteries.
If you still experience problems, it would be an internal IC chip most likely. From there post another question maybe.
Posted on Apr 01, 2010
  • 5603 Answers
SOURCE: my boss metal zone pedal
There is a switch contact that connects the battery when you unplug the AC adapter. These commonly get sprung and cease to make contact leaving the battery disconnected when adapter is unplugged, resulting in no power. Verify the battery is being connected and see if the unit works properly. If so the adapter is either the wrong one or defective.
In other words, there may be two problems.
Posted on Jan 30, 2011
Dunlop SW95 Slash wah No volume + no blue LED : is it dead ? The distorsion seems to work fine
Why not ask the experts?
https://www.jimdunlop.com/category/gear+support.do
Mar 22, 2017 | Dunlop Music
Why does my lowrey organ not make a sound after I have switched it on?
This is a generic answer for this kind of question.
When there is no sound
Check the obvious.
Is there a light on the organ indicating it is on?
  • Plug it in to a known working wall socket, switch on at the wall
  • Switch on at the organ, check light
  • Very old keyboards need a voice to be selected!!
  • Turn master volume up
  • Turn any other volumes up
  • i.e. lower manual volume
  • upper manual volume
  • swell pedals down
Sometimes a sustain pedal plugged into a volume pedal socket will mute the output, check this.
Headphones out, most headphones will turn speakers off, sometimes the headphone switch can be dodgy, work the headphone plug in an out a few times
There maybe a switch that turns off the speakers, look near the output sockets
Software volumes up, check display, if any.
MIDI instruments, check local control is ON
Still no sound?
Can you hear anything from the speakers?
Hiss or hum usually means the speaker is ok
Total silence may indicate speaker failure, but only if there is one speaker, as in older home organs, or smaller keyboards
Try headphones next, TURN Down master volume first just in case!
If there is some sound, very quiet and gross distortion then possible power amplifier failure.
If your instrument has any kind of line out as well as a headphone jack, try these.
The line output will likely be a pair of phono sockets,like you have on HiFi equipment, 1/4 inch, 6.35mm jacks, like the bigger headphone connector, a 3.5mm socket like the smaller headphone connector, or even a DIN connector on older equipment.
Connect these to the aux (or Line or CD) input on your HiFi, guitar amp or similar. (some times these outputs will drive headphones, usually you will only hear anything in the left side). If this works then it is very likely the power amplifier.
Further tests on MIDI equipped keyboards would be to see if the MIDI does anything.
If MIDI out works and there is no sound, and MIDI in makes a sound this points to local being off, buried somewhere in the menu will be local on or off, make sure it is on.
If MIDI out doesn't work then the failure is likely to be internal power supply or something else critical (not nnecessarily major).
Power amplifier failures in newer, low power, keyboards are often the power amplifier chips (i.c,s), older amplifiers may have just blown their fuses but one or more output transistors may have failed.
Cost of repair will be down to the time it takes to get to the fault, taking these to bits and putting them back can take a lot longer than the repair.!
Hope this helps, Chris the Fader
Aug 28, 2016 | Music
Why is my vintage boss dd-3 very quiet on the repeats even when level is turned up full?
Assuming you have the feedback level turned up....can you hear any difference at all when adjusting the feedback?
Aug 17, 2012 | BOSS AUDIO SYSTEMS Boss Dd-3 Digital Delay...
No sound after turning on DigiTech RP200
HEY THERE! I have had similar problems with digitech pedals before. Follow these steps and if the problem is fixable you should be able to identify and correct it.
First identify where the actual problem is. These steps are basically just a "process of elimination" troubleshooting method. This method works for almost any problem with electronics.
1.Plug cable direct to amp from guitar. Have sound? If so its not cable repeat this step with the other cable. Good?
2.If both cable are working plug direct to pedal and use headphones to see if you hear anything. If there is sound it is the output jack.
3.If you still don't hear anything turn on the metranome or "rhythm button and crank the volume ALL the way UP. If you faintly hear a click then it is definitely a power supply issue. Be sure that the AC adapter you are using is 9V and at LEAST 1300mA. I know from experience if the milliAmps are lower than that it will work but not draw enough power to output any sound.
(If you have an old Nintendo system that power supply will work)
4.If a new power supply is used and all other options don't work the pedal is probably broke....I would try a factory reset just to be sure it is not a setting you bumped or something.
HOPE THIS HELPS! Good Luck!
Nick Porter
Jun 07, 2012 | Music
Fender ultra deluxe amp volume max out a number 7 volume control. will not get any louder
It is likely that the amp is flat topped at the 7 setting. When the amp is producing the maximum voltage output it is capable of, that is ALL you can get out of it... The numbers on the dial mean NOTHING and are only relative. If you have high output guitars you might find the maximum might only be 3 on the dial for example...
If you need it louder, get a bigger amp and speakers. You should ALSO get a sound meter and follow OSHA guidelines for sound exposure... I know several musicians that now are nearly deaf because of being exposed to high sound levels... their music careers are now gone as they can no longer hear well enough. You need to protect your hearing for the long term. Great musicians don't need loud, but quality and inovation in their music.
Jan 07, 2011 | Music
Just recently had a friend give me a broken mxr phase 90. said that he couldnt get it to power on with a 9v batter and had never tried a power supply. so i just figured that it just needed a new 9v battery...
This is likely a problem very near the power input connector. It could be a blown filter cap (electrolytic) or a shorted protection diode. You can troubleshoot this with only an ohmmeter.
A broken power input connector could also be causing a short.
Often the input audio connector is used to switch the power on so trace the power circuitry looking for the problem.
Suggestion test seperate from other pedals. Be careful to not burn out your power supply during testing... we put a lamp in series with teh 120 volts to the power supply to limit current to a safe value while troubleshooting.
Aug 08, 2010 | MXR Phase 90 Pedal
Very littel sound in white and black keys. normal
We can only guess at what model/brand you have.
OFTEN such low volume things can be traced to a burned out light used in some expression pedals that use light dependent resistors to vary the volume.
Be aware that on some organs things like rhythm drums MAY go through a different set of speakers and amps than the other voices.
Apr 30, 2010 | Music
My boss MT2 was working fine yesterday and today I went to go use it and two things happen. Either it will mute my guitar, no sound is being transmitted. Or I just get a loud buzz. Either way the power...
The light means NOTHING other than a small voltage is getting to the unit. Verify the power supply is putting out the required voltage...
BUT FIRST...
A common cause of this is we forget which side is input and output... happens ALL the time, so verify you have the in and the out cables to the right placee.
Apr 18, 2010 | Boss Mt 2 Metal Zone Effects Pedal
FENDER HOT ROD DEVILLE 410 POPPING SOUND
I have answered some of this before, however I have reveiwed the schematic and as an electrical engineer I want you to do a couple tests.
First, plug in a set of headphones into the preamp out jack. Note that due to the impedance mismatch what you hear will not be very loud. Now change the state of the clean OD. Did you hear a faint pop?
Next plug a LOW impedance device OR even an instrument cable into the power amp "input" jack. Do this with the power off then warm amp up.
Now, change the state of the clean OD. Did you hear a faint pop?
Now for the analysis. If you did hear one in the first test and NOT in the second, the pop you are hearing is the "NATURE OF THE BEAST".
I can tell you from the design that the pop you hear is from coupling within the clean and OD relays within the unit. There is no cure for this within the unit other than find another brand...
I would recommend that you use an EXTERNAL pedal for the effects you want rather than trying to use the clean OD in this amp. I suspect it was never intended to be shifted during playing as I can guarantee it will pop when you shift while having anything other than dead silence (not even a bit of hum from your guitar). There is also statistical noise in the preamp that the laws of physics will not let us get around that may be enough to create a bit of a pop.
You could also use a volume pedal between the preamp output and the power amp in to throttle the volume to zero before shifting to OD.
In general I think you will find that what you are hearing is the nature of this beast.
Mar 18, 2010 | Peavey Music
How to set up with amp and distortion pedal
With everything switched off. I will surmise that you are using the onboard battery with the foot pedal and not a power supply.
1. Plug lead from guitar/instrument into INPUT side of pedal
2. Plug lead from OUTPUT side of pedal into amplifier INPUT.
3. Turn amplifier volume to about 10 o'clock - to stop blowing your ears out.
4. Turn volume up on guitar to acceptable level.
5. press foot switch on pedal and adjust pedal controls to suit your type of distortion.
6. Play like Hendrix.
Good Luck
ps Just as an after thought rechargeable 9volt batteries are the way to go. I've been using them for years as I always get caught up in the power cable.
If you're going to add another pedal like a Phaser, Compressor, Flanger or what just use small connect leads between each pedal but always, always put the compressor pedal last in the line.
Sep 12, 2009 | BOSS AUDIO SYSTEMS Boss Ns2 Noise...
Boss Mt 2 Metal Zone Effects Pedal Logo
Top Boss Music Experts
Matthew Spark
Matthew Spark
shaun taylor
Darial Jr Lasaria
Darial Jr Lasaria
Are you a Boss Music Expert? Answer questions, earn points and help others
