Question about Ematic 4GB* MP3 and Video Player with YouTube Ready Video Recorder and Camera - Black EM614CAM
How can I get it to work?
I was recently attempting to clean my sister's old laptop by removing some things, I guess I removed the file information for my ematic. For a while when I plugged it in I had to turn it on to get it it to connect and when it did connect it would say "Not recognized" I looked at the details and it says that its reporting a problem to the computer so the computer stopped it from connecting. Now it won't even turn on when its NOT connected but it does when I plug it into my desktop. I have no idea what I'm doing, does anybody else? -_-
  • yadayada
    yadayada May 03, 2017
    Woe I bet sis is mad at you!!!
Windows failed to start. A recent hardware or software change might be the cause. To fix the problem: 1. Insert your windows installation disc and restart your computer. 2. Choose your language settings,...
Big trouble. Try safe mode, if possible. Don\'t use recovery procedure, just manually remove unnecessary things. Finally backup your data, and reinstall whole system?
Mar 19, 2014 | Acer Computers & Internet
PC not POST - Phase LEDs blink once then nothing
Try testing with a voltmeter. They are common, cheap, and you may even have one. Or, at least be able to borrow one.
Nov 08, 2012 | Computers & Internet
Computer Running Slow
Okay, you have the same issue I used to have. I inherited a laptop from my mother, and she was the second owner. It was loaded with programs I didn't need, and had a zillion files tucked away. If you can go into your control panel and access the add or remove programs, go through it and remove every stinkin' one of the optional programs you don't ever use, or can do without. Be sure you know what you are removing. Next --and this may sound silly, especially if you have done it already-- you need to go into your homepage in your internet connection and clear all browsing history from every browser you use. These can include google, msn, explorer, firefox, etc. I find if I don't clear my browser frequently, my computer is a real *******. The next obvious step would be to get into all my documents files and delete any old files, such as photos that you don't want, a huge music collection, etc. I have all of my music stored on my D drive, because it has the same memory as my C drive, but is nearly empty. You can store and easily access all your entertainment files in D if you have a large capacity. I would perform this test: from your start menu, open my computer and right click your c, or main hard drive and click on properties. This should give you info on how much storage space you have left on the disc. If it is less than 50 percent, you may need to delete some old trash. Do the same with your d drive. If all else fails, you can go into your recovery program and see if you can wipe the computer, but that is a last resort. I had to do this with mine so I could program it to recognize me as the computer administrator. I was tired of fighting with a zillion hidden files I couldn't get into, much less locate. Hope this will help.
May 02, 2012 | Dell Computers & Internet
My computer hangs
Scan your computer with an updated Antivirus.
Use Microsoft Process Explorer to stop unwanted programs.
Use a system utility tool like ReginOut to fix corrupt registry & windows files. It will also remove unwanted junk files from computer.
Hope it works for you.
Jan 05, 2012 | Computers & Internet
My computer won't boot. When I press the power button the CAPS locks and scroll locks flash for about a minute and the whole thing powers down. I tried reseating the RAM, swapping my RAM, <fn>...
It's probably the motherboard at that point. Especially if it doesn't give you RAM error beeps on start-up. The only other things I would attempt is to remove the hard drive and the optical drive individually and see if that works. If not then it's the motherboard.
Hope this helps and please rate.
Jul 28, 2011 | Dell Vostro 1500 Notebook
Have gts toro, engine starts then stops can not get it started.. r s
Your mower engine has to have these things WORKING to run: 1. Compression (engine in good shape) 2. Strong Spark (magneto air gap has to be correct for strong spark) 3. Clean air ( good, clean air filter w/no air leaks) 4. Clean, fresh fuel supply (gas less than 30 days olds with an inline filter installed in mower's fuel line). These things are assuming the mower hasn't struck an immovable object such as concrete, tree stump etc. recently. This will shear the flywheel key and timing may be off so far that engine won't start. So, where would you like to start my friend? Try checking these things. In the meanwhile....we can try to "coax" the engine into running. Remove the spark plug. Get an aerosol can of carb/choke cleaner spray. Spray a couple of shots into the engine. Reinstall plug. Choke the carb and attempt to start. This may or may not work, according to the conditions listed earlier. If this doesn't get it running, remove the plug and try it again.
We are trying to get it to run on its own, so it will start (or attempt to start) drawing fuel from the carburetor. Sometimes the brass bolt that holds the carburetor float bowl on gets clogged. You drain the gas, remove the bolt and clean all the small hole in the bottom and along the sides of it. This bolt is also the main jet of the carb. Cleaning this with carb cleaner can only help. If you do this, use NO metal objects to poke or scrape the bolt. The holes are metered and have to stay that way. Check for spark, check your air filter, see if the plug gets wet after you attempt to start. If it doesn't get wet or even smell like gas, then likely you have a fuel flow problem. Try ALL these things and post back; and again, if you have hit something solid recently with the mower, you will have the replace the flywheel shear key. It is a small aluminum $1.00 part so don't worry. Post back as needed. We wish to help.
Jun 19, 2011 | Toro Lawn Mower With Toro Power Tools
New plug will not turn over prime and still will not turn over or run
Jun 19, 2011 | Toro Power Lawn Mower
Rca th1702-a turn on says usable memory exceeded please remove a few files then shuts off not allowing to remove files
Try to remove your unwanted files this way....
BE SURE NOT TO DELETE YOUR FIRWARE, ONLY THE SONGS,FILES,ETC.
Deleting Files,Pictures,Videos,Audio
Books, Apps,etc. from MP3 Player/Ipod
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release,right click and then click on "Delete"
Now you mp3 player should be clear of the files/songs you do not want.
BE CAREFUL and do not delete files needed to operate your MP3 player.
This is a FREE answer, Please rate me
Apr 15, 2011 | RCA Audio Players & Recorders
Acer Aspire One, Screen turns strip-y grey/white
hi there, my sisters dell laptop does the same thing. My best guess is that a hard knock on the graphics card and knocked a few pins out of it. This is something that a average person can not do. My suggestion is to bring it to a computer shop and tell them that you think it's the monitor connections.
Jan 31, 2010 | Acer Aspire One PC Notebook
Iv recently put windows xp pro on my laptop but i never deleted the old files which ar still on it now has low disk space on d drive how can i clear it
Back up all the files externally and do a clean install of XP, I would actually use a DBAN to remove all files right before the new installation, too
http://www.dban.org/
Jan 11, 2010 | Dell Inspiron 1300 Notebook
Ematic 4GB* MP3 and Video Player with YouTube Ready Video Recorder and Camera - Black EM614CAM Logo
29 people viewed this question
Top Ematic Audio Players & Recorders Experts
Lawrence Oravetz
Are you an Ematic Audio Player and Recorder Expert? Answer questions, earn points and help others
