Question about Sony VAIO GRZ660 Notebook
How to install 2nd battery
I would like to get an extra battery for my sony laptop vaio grz660 , is it possible to charge 2 batteries from ac adaptor at the same time. I can only see 1 slot for the battery. How do you insert 2nd battery? Is there another slot for additional battery? please help thanks
    Guru:
  • 120 Answers
Most laptops these days do not have a second slot for a battery. This laptop only uses one battery. You would be best off purchasing a second battery and charging it ahead of time.
Posted on Aug 10, 2007
SOURCE:
LCD screen does not come on When plugged in, the battery light starts to blink yellow. The computer turns on,. I hear it doing something, but the screen never lights up.
Thats a no power issue : Remove battery and AC Adapter for 1 minute. Power on system with just the AC Adapter and then try just the battery. If its determined the AC Adapter and/or battery is not the issue.I
f the external monitor shows video the driver/video card is likely not the problem. The system will likely need to be repaired for a possible LCD/LCD Cable issue
Feb 20, 2010 | Sony VAIO GRZ660 Notebook
My computer will not start. Last I used it I had forgotten to plug it in. It displayed a message about critical low battery and I rushed to plug it in, but it will not re-start. I got another battery...
does it work if u use adaptor ?
did u check if the adaptor is OK ?
1st may be ur adaptor is out !!!
2nd ur batteries are not charged by the adaptor !!
3rd no power in any of ur batteries..!!!
Dec 23, 2009 | Sony VAIO FX340 Notebook
My sony vaio vgn-fs285e will not switch on since this morning. Even if the AC adapter is plugged-in it still won't come on. None of the lights come on, it won't run with the battery pack or just AC power....
To check if the problem is the power adaptor or the Vaio, just have a look at the charger itself and see if the green light on the adaptor itself is on?If yes, then more likely it is working fine. If no light, change the fuse in the plug and try again.
You can also try a static discharge on the Vaio. Please remove all external devices, unplug the adaptor and remove the battery. Put your finger on the power button and hold it for about 30 seconds. Then connect the power adaptor again and try to boot.
Regards,
Purito
Oct 17, 2009 | Sony VAIO NR Series Notebook VGNNR460EP
Hello, SONy Pcg-FRV37,Power problems
Clean the metal contacts on the Battery and in the compartment. Then, reset the BIOS to its default settings.
Next, plug in the AC Adaptor to charge the Battery.
If the issue persists then the problem may be related to the power circuitry.
Oct 16, 2009 | Sony VAIO FRV37 Notebook
My laptop cannot turn on, but the AC adapter is on. I try to switch it on it connot turn on. Please help me.
You will have to open open your pc memory compartment. Remove and re-install into the socket one after the other if they are two modules ok. If it doesn't work then you have to go for a confirmed working and compatible RAM and substitute for yours. If it still does not display, then try connecting to an external monitor to eliminate the screen as a possible cause. You could also remove the battery and power directly from the main and see what happens. If the pc makes some humming sound while being powered and there is still no display, it then means that the pc motherboard is bad and should be replaced. Good luck
Jun 03, 2009 | Sony VAIO GRZ660 Notebook
AC Power adaptor wont work without usb printer connected
Hey alberto,
First off thanks for choosing Fixya.com. The Ac adapter itself could be bad or it could be the dc jack. And also the problem with your cpu fan could also be that the fan has gone out or the motherboard itself needs to be replaced.
Feb 15, 2009 | Sony VAIO FRV28 Notebook
Sony Vaio Laptop Battery - increase charge
Hi Sony battery,
did you mean to say that you battery only remain at 50% and never exceed this amont ??
Normally all the notebook if you keep charging it should come up to 100%, but only a few case that will face the problem
1.problem with battery itself.
2.problem with ac adapter (I face very much problem here not continues power suplly)
3.problem with motherboard the module that deal with charging battery.
Goodluck,takecare.
May 08, 2008 | Sony VAIO PCG-K35 Notebook
Sony Vaio PCG-K86P laptop
hi, the problem seems with the RAM, remove and clean the contacts with an rubber/easer, this should fix ur problem,let me know
Dec 20, 2007 | Sony VAIO PCG-K25 Notebook
Sony VAIO GRZ660 Notebook Logo
Top Sony Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
