Question about Corel Draw Graphics Suite X6-En Upgd Hard Back Book / Mfr. no.: CDGSX6ENH
I don't know if this is repeating - sorry if a duplicate.
I have several hundred files created in multiple versions of Corel (most X5 & X6). Only a few have files have caused this problem. . When I try to open in X6 the file crashes the program. If I open the file in X5 - there is no problem. I saved the file down to V12 and when I try to open in X6 -Crash. Open the same file in X5 no problem. Just found this problem because I had to replace a computer.
20YrsCompExp
  • 227 Answers
SOURCE: Corel draw files do not open
Try launching CorelDraw FIRST then open the file from the CTRL+O command in Corel. Let me know if this works!!!
Posted on Mar 28, 2009
SOURCE: I am using Corel X3 version and would like to open
Step 1 Launch CorelDRAW Graphics Suite X4. If you don't own the software, download and install a free 30-day trial from Corel.
  • Step 2 Go to "File" "Open" and open the X4 file you want to convert into a backward-compatible X3 file.
  • Step 3 Go to "File" "Save As" and choose "CorelDRAW X3-compatible" from the "Save as Type" drop-down menu. Click "Save."
  • Posted on Feb 11, 2010
    Testimonial: "that worked, thanks alot"
    • 71 Answers
    SOURCE: how do you relink a file to corel videostudio?
    Using a USB key is the worst thing you can do when you are video editing.
    When you are editing video it is best to have the video clips on your main hard drive for the best Play back and rendering performance.
    Video editing software doesn't actually change the original files, it just remembers what parts of the videos you want to use and then saves that memory in a project file, it does not save the video files. when you render the video it will make a new video file.
    If you make any changes to the project files (Pictures and videos) in the project (e.g. name change, location, re-save) the video editing software will no longer be able to link the files back to the project and will then prompt you to re-link the files.
    Also the performance of video editing software relies a lot on the data transfer speed. when you are using a USB drive you are cutting the performance down BIG time.
    When you are using VideoStudio save all the files you are editing to the hard drive in one folder. when you are done and you want to transfer the project off, select File | Smart Package. What this will do is gather all of the project files and allow you to save to a USB drive and you can transfer the project to any other computer and open the project using VideoStudio without the relinking issue.
    Posted on May 30, 2010
    widyo15
    • 97 Answers
    SOURCE: When ever I go to
    i think your software is not compatible on your operating system find that was compatible on mac os...
    Posted on Dec 30, 2010
    nonontech
    • 4737 Answers
    SOURCE: Corel Graphics Suite X3 will
    This problem may start when a different workspace is selected or maybe whenever (by mistake) a new workspace has been created. You will need to load the default workspace. Press and hold down F8 on the keyboard once the Corel Draw is loading to open up. This will prompt you to select the default workspace. Select it and the program should work fine.
    Let me know if you need further help..
    Good Luck..
    Thanks for using FixYa.
    Posted on Apr 13, 2011
    Corel DRAW X6 problems
    I presume you mean CorelDRAW Graphics Suite X6 and NOT technical Suite?
    If nothing seems to work I would then do as follows.
    1.Uninstall CorelDRAW X6 via Control Panel
    2.After uninstalling X6 in the Control Panel - Go BACK to the Control Panel and uninstall "Corel Graphics - Windows Shell Extension".
    3.Then go to Documents > Corel folder > Uninstall/Delete anything that says CorelDRAW X6
    4.You can also go to C: > Program > Corel and delete anythign that says CorelDRAW X6
    5.Repeat step 4, but choose folder called Programx86, and delete anything that says CorelDRAW X6
    6.You should now have uninstalled everything that useally could disturb when you re-install from scratch.
    7.NOW put in your DVD again with CorelDRAW Graphics Suite X6 - and INSTALL from Scratch.
    8.You SHOULD now be able to run your CorelDRAW X6.
    9.And NOW you should go online to www.corel.com and download and install Update/service pack and Hotfix for CorelADRAW Graphics Suite X6
    10.It should in all normal situations work just fine on your PC with any Windows 7 version as well as any Windows 8 and 8.1 version.
    11.Try to use a program to recover and view CDR files. For example, you can try this CDR Open File Tool http://www.cdr.openfiletool.com/
    12.Also recommend to come to this forum. Many have useful information on the topic. http://www.filerepairforum.com/forum/cad-tools/cad-tools-aa/coreldraw/479-problems-with-cdr-files
    Good luck and hope this helps!
    Nov 12, 2014 | Corel DRAW Graphics Suite X5
    Corel draw x5 universal installation key
    Hello Sir, search in google Coreldraw x5 full version torrent download torrent then you are add torrent in utorrent download full version software when u are finish your downloading then turn off your internet and start installation. they have keygen folder run keygen and activate your software
    May 15, 2014 | Corel DRAW Graphics Suite X5
    Corel x6 activation code
    corel video studio pro x5
    sileal number
    active cod
    Jul 26, 2013 | Computers & Internet
    Coreldraw
    I have downloaded the latest version x6 corel draw. can u please tell me how to activate it. it was just a trail version. pls help me. i will be thankful to you
    Jul 01, 2013 | Corel Computers & Internet
    Activation Code for Corel Draw X6
    You will have to refer this to Corel for resolution
    May 08, 2013 | CorelDRAW Graphics Suite v.X6 - Complete...
    I need help with Corel Paintshop Pro XI
    I used to work for Corel and they are a great bunch of people, give them a call and they will help you out.
    Apr 27, 2013 | Corel Paint Shop Pro® Photo XI Full...
    I need an Activation Code for Corel X5 DR15R56P42VS5U5RTBUDPSAM4QQABRQ5N
    I need activation code for corel draw x6 DR16R22-C5JH7FK-BEJX49Y-RPW3HXA pls send me a reliable code
    Jan 15, 2013 | CorelDRAW Graphics Suite X4 for PC...
    I need installation code for coreldraw x5...for serial no. DR15R68CHAURV8B24TTKDNXJF8NJHTJUS
    All follow these steps to get installation code:
    1. Start Corel Draw
    2. Click on Activate Now or Other Activation Option
    3. Now click on Phone Corel
    Now from here you will get your Installation Code
    4. Use this installation Code and Serial number in Keygen.exe to get your Activation code
    100 % working . Enjoy guys solution by Pawan Soni (ZF)
    Mar 01, 2011 | CorelDRAW Graphics Suite X4 for PC...
    Corel Paint Shop Pro X will not respond or open
    Please inform corel from the internet and tell them that you purchased the 2007 version of paint shop Pro. tell them that you needed to install back unaccessed software.
    Thanks.
    Jul 09, 2009 | Corel Paint Shop Pro® X Full Version for...
    Corel Draw Graphics Suite X6-En Upgd Hard Back Book / Mfr. no.: CDGSX6ENH Logo
    50 people viewed this question
    Top Corel Computers & Internet Experts
    Martin Murray
    Chris Larocque
    Are you a Corel Computer and Internet Expert? Answer questions, earn points and help others
