Question about Toshiba Office Equipment & Supplies
Close offset tray cover toshiba studio 244 - Toshiba Office Equipment & Supplies
4 Suggested Answers
  • 4 Answers
SOURCE: getting close front cover error when i start
i am a toshiba engineer, you have no 24volt supply from the psu. check the fuse on the psu. highly unlikely to be the door switch.
Posted on Sep 01, 2009
  • 52 Answers
SOURCE: We have a toshiba e studio 255 and it is showing
THE DUPLEX COVER SENSOR NEED TO BE CLEAN OR THE THE STUD ON THE DUPLEX COVER IS BROKEN
Posted on Aug 29, 2010
  • 132 Answers
SOURCE: My Toshiba e-studio 45 displays
Hello
I encountered the same problem a few years back, I found the power supply to be faulty.
You can try checking all the fuses on the power supply.
Sorry that is all i have at the moment.
I will see if i can download the pcboard repair manual.
Please let me know where i can email it to.
Regards
Posted on Apr 26, 2011
How to clear code f901 toshiba 456
CDF0 Offset tray related
service call
Initialization error of the offset tray: The home position of
the separator cannot be detected when the power is
turned ON.
[CDF0] Initialize error of the offset tray (e-STUDIO205L/255/305)
(1) Check if each connector between the OCT motor and OCT board (CN261) is disconnected.
(2) Check if each connector between the OCT board (CN261) and LGC board (CN302) is
disconnected.
(3) Check if each connector pin is removed or the harness is broken.
(4) Check if any conductor pattern on the OCT board and LGC board is short circuited or open
circuited.
(5) Replace the OCT motor.
(6) Replace the OCT board.
(7) Replace the LGC board.
Dec 16, 2016 | Toshiba E-Studio 456 Copier
Close Front Cover For Toshiba E-studio 350
There are many possibles that can cause "Close Front Cover"
Check the front cover actuator, switch. If all covers, switches is working fine, probably power supply is faulty.
Dec 02, 2015 | Toshiba e-Studio 350 Copier
Studio has an error message to close offset tray cover estudio 450 copier
Need check cover open or not. if open closed covers properly
Aug 13, 2015 | Toshiba e-STUDIO 4511 Printer
How to do periodic maintenance 0088 in Toshiba Studio 2330c
Toshiba e-STUDIO 2330c
Is given error message "Close Front Cover". The front cover is closed and I can not get error message to go away.
Where can I buy Power Supply (6LG03347000)
Mar 23, 2015 | Toshiba E-studio 2330c 2830c Color...
Close side cover error tray
You see front cover switch if front cover knob not touch then this messege appear OR check power card & front cover connection
Nov 06, 2013 | Toshiba e-Studio 350 Copier
How to reset cdfo error toshiba estudio 355se
service call
turned ON.
disconnected.
circuited.
Oct 31, 2013 | Toshiba e-Studio 350 Copier
Make sure the front cover is closed firmly, triggered the front switch, u can see clearly by removing the paper exit tray.
It might be front cover switch problem also.
Sep 27, 2013 | Toshiba e-Studio 350 Copier
Error cdfo what is it e-studio 455
CDF0 indicates Initialize error of the offeset tray.
Check the connectors of the offset gate motor, MOT2,
Oct 14, 2010 | Toshiba e-Studio 350 Copier
Where is the duplexer cover
In an e-Studio 650 the duplexer is located under the fuser/transport belt tray inside the machine. If you open the front cover, turn the blue lever clockwise and pull that tray out you can then open the duplexer by pushing down on the blue tab that sticks out the bottom on the tray.
Sep 13, 2010 | Toshiba E-STUDIO 650 Copier
TURNS ON BUT KEEPS SAYING CLOSE OFFSET COVER
There is an exit sensor with a black actuator attached. I suspect the actuator has fallen off. If you can't clear that you should be able to remove the offset catch tray assembly and just let the paper feed into the center output tray.
Feb 09, 2010 | Xerox WorkCentre Pro 416 All-In-One Laser...
43 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
Branko Djurdjevic
Branko Djurdjevic
CheckitRight
CheckitRight
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
