Question about Brother PC-6000 Pacesetter
Brother PC-3000 only sews a straight stitch
Machine has been cleaned and is free of lint. I can not select different stitches. I think it needs to be re calibrated, but don't know how.....it is different from the PC-6000 series.
bargainbox
  • 1388 Answers
SOURCE: stitching looping
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....the question you pose could have 2 meanings....this reply is for looping thread.
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
cc3f045.jpg...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all back properly.
FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes. ie a different colour top and bottom just for the test.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is, and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine case....no case ? then make some sort of cover ! Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistant diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
If you need any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Feb 23, 2008
  • 1027 Answers
SOURCE: How do I change the stiches?
The brother website has a users manual for it that can be downloaded. Use this link to get it:
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=hf_ls2125eus&type2=5&flang=English&dlid=
Posted on Jul 10, 2008
vash4me
  • 5 Answers
SOURCE: Machine sews zigzag although stitch is set at 0 for straight
It must be a design flaw- things don't always last like they are supposed to. I would personally check the physical reason it is not responding... knowing what it would take to make it stop moving- or whatis causing it to. *perhaps the switch isn't working to stop it- or the mechanism that controls it is worn down. If it was new- I'd return it- but there are only a few options at this point.
Posted on Jan 13, 2009
SOURCE: Brother sewing machine will not make continuous stitches
first you should turn off the machine and let in reset it's internal programs. Yes the feed dogs are very important. start your machine again...set the feed dogs...unthread and rethread teh machine from start to finish to include taking out the bobbin and replacing it. then make sure you bobbin winding in completely in Un using mode...
Posted on May 23, 2009
SOURCE: Stitch selection
Next to the "selection wheel" there's a large-ish "hole" with a screw at the bottom, use your screw driver to wind up the screw and you'll be able to use the 9 to 15:)
Posted on Aug 25, 2009
Testimonial: "Big thanks mate! :)"
Stitch length problem
the stitch length dial may need to be checked to see if it's worn or damaged or may need a adjustment.
Jul 27, 2013 | Riccar Sewing Machines
Can lint get up inside the shaft that raises and lowers the needle?
the needle bar is not hollow,
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
May 01, 2012 | Singer Confidence 7463 Computerized Sewing...
Singer 4423, timing out,what line up with what
I don't think it's a major timing issue, so don't panic. Take a look at your selected stitch pattern selector and set for straight stitch, and set Tension at 3-4. Width: 4. Length: 4. Make sure presser foot Down when you rethread machine so the tesion disks open up to locate thread. Always hold thread taut when "feeling" for tension slot. Insert new needle. Needle goes all the way up into needle clamp as far as it can possibly go, FLAT side needle toward needle bar and more rounded side needle facing you. Leave 6" tail. Hold thread toward you as you turn hand wheel toward you so needle can make a loop with bobbin thread. Make sure bobbin thread isn't hanging down on or across bobbin! Make sure thread in bobbin has wound evenly - good quality thread ideal! Clean bobbin area and feed dogs for broken, loose threads and lint. Always use needles appropriate size for weight of fabric. I suggest walking away from machine, taking deep, cleansing breadth, humming a favorite tune, then doing above and see how it goes! Soon your machine will be humming happily along with you. Hope these suggestions help. Jimmy
Mar 31, 2012 | Singer 4423 Sewing Machine
Bobbin thread too loose in singer 9805c
change the needle
make sure the thread isn't coming off the thread take up lever
clean under the needle plate & bobbin area for lint or loose threads
try a different thread
make sure the fabric & needle & thread are compatable
do you have a manual?
Go to the singer website
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example 9805 ) don't a the C in the box
& click search--if you don't find what you need--contact singer customer service
Mar 19, 2012 | Singer Sewing Machines
When trying to change to the other sewing stitches the cams will not the the selector pass
doesn't sound like he tried real hard, my suggestion is to find a sewing machine shop that will take the machine apart & find out why the selector doesn't move, it's possibly a worn or loose or broken part, & the repair man is suppose to open the machine & find out what's wrong.
Mar 01, 2012 | Bernina Sewing Machines
I have a new Phaff Coverlock 4.0 Serger that I cannot get the box to come up on the screen to calibrate it. There is on stitch in there that coms up, but I cannot calibrate it to make the other stit
I would suggest taking the machine back to the one you bought it from & see if they have another one that will calibrate ,,& if they don't have one ,, I suggest another sewing machine dealer..
or you can try contacting Phaff customer support by phone or email & see what they say
Jan 30, 2012 | PfaFF Sewing Machines
Simplicity Fashion Pro Sewing machine problems. Machine stitches are too loose on the bottom of fabric.
try setting the top tension to 4 or 5 & see if the machine sews any better, you should see a nob or dial with numbers or alphetbet letters on it, that's normally on the left side of the machine
also try changing the needle, it's possible that it's bent or blunt
also clean under the needle plate & in the bobbin area for loose threads & lint
Jan 28, 2012 | Sewing Machines
Distorted embroidery with Designer SE
have you tried changing the needle
try rethreading the machine top & bottom
also clean under needle plate area & bobbin area for loose threads & lint
Jan 27, 2012 | Husqvarna Designer I
I have a model #9120. It's sewing perfect stitches, but it started running very slowly. I cleaned all the lint out under the bobbin, but its still running slowly. What else can I do? My manual says...
Hello, if the manual say not to oil it then don't, some machines parts are soaked in the oil & the more the machine is used when the parts get hot the oil come out of the parts & lubricates them
if the machine is running slow, it could be the motor going out, power cord or foot pedal,
when was the last time it was serviced? they need servicing at least once a year
Sep 13, 2011 | Euro-Pro Sewing Machines
Sewing Machines Logo
79 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
