Question about Car Audio & Video
Where can i find the manual of car tv video player FELIX FX038?
I am looking for the owner's manual for my Icon DVD100 in-car dvd player. Are these available anywhere on-line? Thanks!
Any chance you have found the owner's manual for your Icon? I am also needing one and can not find one. Please let me know at ehooper328@cox.net Thanks
Nov 18, 2010 | Icon DVD100 -TV Car DVD Player Car Video...
The tv repeatedly turns on then off
First area to check out is the power supply of the set.
Jun 14, 2017 | Sony Grand WEGA KDF-60XS955 60" Rear...
The video of my jvc dvd player won't display on my tv screen or the video is not working but the audio is ok.
Connect the yellow connector on the DVD player to the yellow connector on the TV. Refer to the TV manual and select the video input. Refer to DVD manual and choose interlace on the DVD player. Let me know if this helps
Jan 13, 2010 | JVC XV-N322 DVD Player
I have a dvp 3960/37 player I am trying to hookup to a Sony KV 32fs120 TV using YPrPb as a component. The Sony manual says the DVP must be Setup before connecting. The Phillips manual says to use the TV's...
If you are using the component output from the dvd player (3 wire video) progressive scan connect corresponding cable to tv . Besure to match colors. If you are getting a black and white double image you need to set the output of the dvd player to progressive scan. See owners manual for dvd player to set this. The yelow color jack on the tv is composite video and is not compatible with the 3 wire video .
Nov 20, 2009 | Car Audio & Video
Need to hook up a TV,VCR-DVD player,and CD player
Progressive scan video output would be available on Component Video terminals of dvd player so set connections between TV and dvd player via Component Video cable.
Please intimate model and brand of product that you need instruction manual.
Thanks.
Aug 31, 2009 | Sanyo Cinematic Progressive Scan DVD...
Instruction manual
google manuals for appliances
Jan 11, 2009 | Panasonic SDVD6300T SPL In-Dash...
Digix Manual/diagrams do not match my TV connectors
Simplest way. ++++++++++
If you have red, white and yellow on each match those and use a cable with 3 strands - red, yellow and white ends with RCA jacks. Use the setup key to get an onscreen display to set options.  Make sure they are the video/audio OUT on the DVD not in.
On your TV it's probably Video 1 or something like that - you can usually test this by putting the cables into the front of the TV. The TV remote might have some key like TV/Video to get to the Video input screen.  Make sure you check the video-in ports on the TV - not the video/audio-out.
Option if red is missing +++++++++++++++++ If the DVD player just has yellow and white then just connect yellow and white (it will be mono) on the TV.
It shouldn't matter if the holes are vertical or horizontal.
S-video +++++++ If both TV and DVD have S-video ports then connect those - they will give you better video than the yellow.
You will still need to connect red and white sound cables.
Jan 04, 2009 | Digix Televison & Video
Hook ups
use a video splitter for the audio and video, or go out of the DVD player in to the DVR, out of the DVR into the TV (WARNING!!!! Trying to hook a DVD player to any recording device may trigger the copyright protection, causing blue flashes, and distorted pictures)
Aug 22, 2008 | Memorex MVD2042 DVD Player
Car Audio & Video Logo
74 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
