Question about Delta Model DT2400CS Pressure Washer 5.5HP
Honda gcv160 Won't start
Hi I have a brand new Victa Mustang with the Honda GCV160 4 stroke. Hve fuelled up, added oil, turned on fuel tap but it won't start. Any ideas?
Has it been sitting? Has the gas been sitting? I'm sure the carb is all clogged and gummed up with stale gas and dried ethanol. Buy a new carb, GCV160 carbs are like $20 shipped on eBay.
Dec 09, 2014 | Honda Garden
Gcv160
Clean it up real well and try again. Most likely the oil is from the motor being put in a position that allows the oil to run into spots that it is not supposed to be in.
May 17, 2013 | Honda Black Max 2600 PSI Pressure Washer
Why won't my brand new Honda mower start
Take it back for a warranty fix as it is defective from the factory. Do not make any adjustments yourself as they will claim unauthorised work and may not repair under warranty.
Apr 24, 2013 | Gcv160 Gas Engine
I have a wood splitter that has a honda GCV160 5HP engine, when I choke it to start, it does find, but when I push the choke in, the engine will not run smoothly, it acts like it's not gettingg en
Sounds like debris in the carburettor. The carbs on these are relatively simple things which come apart easily. Check for debris or water in the float-bowl, and ensure both your idle and main jets are clear and you can see daylight through them.
Oct 10, 2012 | Karcher 2500 PSI Pressure Washer
Throttle stuck
remove the top cover from the engine and see if a mouse built a nest under the cover and keeping the governor from moving freely
Sep 01, 2012 | Husqvarna 21" Lawn Mower with Honda GCV160...
Need a Honda GCV160 mower owner op-manual
You will need to know your serial number. They are free to download, but if you want to order a paper copy, you have to pay for it. Hope this helps and please don't forget to rate!
http://engines.honda.com/parts-and-support/owners-manuals/GCV160
Jun 24, 2012 | Garden
Honda gcv160 starts with starting fluid in carb but won't stay running
It sounds like a clogged carb. It needs to be disassembled and remove the main jet and nozzle and clean them making sure the small holes are open and free of any debris.
May 18, 2012 | Garden
1990 Accord electric windows won't close
If you own a Honda Accord, you know they rarely give any trouble. ... My 1995 Honda Accord Window Won't Close ... are a bundle of complicated electronics, lots of wiring and more computing power than the average computer from 1990. That ...
http://www.ehow.com/how_4520901_fix-power-windows-honda-accord.html
Read more: 1990 honda accord electric windows won't close ' eHow.com http://www.ehow.com/search.html?s=1990+honda+accord+electric+windows+won%27t+close+&skin=corporate&t=all#ixzz1kZmevV9g
Jan 26, 2012 | 1990 Honda Accord
Husky 2600 pressure washer with honda gcv160 engine. engine won't run with choke off.
I bought mine at Home Depot, the pump failed after about 8 hours of use then Home Depot agreed to replace it now it failed again after aabout 10 hours of use. This is a piece of crap and Home Depot should be ashamed for selling this junk. I am sure they are in with Husky and making big dollars on a crappy product. My machine is like brand new just will not work. Now the carb has to be replaced only after less than 20 hours.
JUNK Home Depot
Nov 23, 2011 | Garden
Delta Model DT2400CS Pressure Washer 5.5HP Logo
32 people viewed this question
Top Delta Garden Experts
Dennis Key
Dennis Key
john h
Are you a Delta Garden Expert? Answer questions, earn points and help others
