Question about Air Lift 1992 Cadillac Deville Air Suspension Compressor
When replacing the ignition switch what is the proper proceedur for sodered wires at the switch? Is there a schematic available for the ignition switch to starter
  • Air Lift Master
  • 10,291 Answers
No solder . use crimp connectors to splice the wires color for color
Posted on Jan 29, 2014
Motorcycle wiring schematics
mag wiring is pretty straight forward, if the mag is working properly you just turn it off or on with the ignition switch. if need be track the wire to and from the mag to the switch. you haven't said what your problem is.
Jul 31, 2014 | 1973 Yamaha DT 360
Sylvania 6842thg flat screen circuit board burnt at one of the resistors. How do I repair as opposed to replace? Thank you.
Good luck---Philips (who makes this) only has schematics etc available online to authorized service centers and unless parts needed can be replaced with generic parts they do not sell any individual parts---go shopping on the internet for the board--should have a number on it.
Nov 04, 2012 | Televison & Video
What are the schematics for wirinig an ignition for a 1991 300e mercedes benz? I am not sure what wire goes where when wiring my ignition
  1. The following fuses can cause the car not to start. Check and Replace fuses B, 5 and 6 and 7.
  2. Check the power to the neutral safety switch. When the ignition switch is activated there is no power to the neutral safety switch. Power to the neutral safety switch comes from the ignition switch on the violet wire. If there is no power at the violet wire when the key turns to start, the ignition switch is probably bad or there is a problem with the wiring to the switch.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Feb 17, 2011 | 1991 Mercedes-Benz 300 Diesel
No dash guages work .it will start but then stop running. tried new ignition switch , which did not work.
To fix the dash going out try this. This is a common problem with the voyager,caravans and Town & Countrys. What the problem is is a cold soder in the interment cluster itself. The problem area is where the plug comes from the van into the cluster. You need to take the circuit board out of the cluster and reheat the soder on the back side of the circuit board were the plug plugs into. This will fix the cold soder permanitly I think its about 16 pins you have to reheat with the soder gun. If you don't feel comfrotable doing that you can just replace the interment cluster and it will be fine but if you buy a used one make sure it was tested. Hope this helps I have done several of them.
Aug 14, 2010 | 1998 Plymouth Voyager
My car does not start. I changed the ignition
Check to see If you have power to ignition module,coil a good wiring schematic is needed to properly check you power supply to computer .factory repair manuals are availible on eBay about 10 bucks .computer is high failure item on these.
Nov 01, 2009 | 1993 Mitsubishi 3000GT
97 4wd blazer ignition switch assembly replacement
You need either the service manual or go to Alldatadiy.com for wiring schematics.
Mar 04, 2018 | 1997 Chevrolet Blazer
I replaced the ignition switch, and my car wont turn on no more, dash board doesnt work my windows wont go up either.i have a 1990 ford mustang 5.0
the ignition switch must be adjusted, it slides back and forth, did you check the adjustment? if not call me at home 925-459-0571
Oct 16, 2009 | 1990 Ford Mustang
Battery
maybe yes ,maybe not !!! my advice is don't use soldering iron more than 25 watts of heat it may cause your PCB board or other component burned.A solution to your problem just try to look cold soldering if available in your area or any major electronics shop. this will solve your problem
Jan 21, 2008 | Apple iPhone Smartphone
Air Lift 1992 Cadillac Deville Air Suspension Compressor Logo
44 people viewed this question
Top Air Lift Air Tools & Compressors Experts
John Trevino
Lawrence Oravetz
Are you an Air Lift Air Tool and Compressor Expert? Answer questions, earn points and help others
