Question about Sewing Machines
Babylock denim pro 1750
Hi, I have a Babylock denim Pro 1750 but I need the manual, someone has it? have problems like wind the thread for example.
  • Sewing Machines Master
  • 7,365 Answers
You'll have to contact a babylock dealer about a manual or go to babylock website and contact them and ask them about a manual.
Posted on May 06, 2013
Michaelle
  • 65 Answers
SOURCE: I need a manual for the babylock denim pro
I'm not sure what the model # is but the manf. site may help. They have a great cust. service dept, that maybe able to help.
http://www.babylock.com/search/index.asp
Posted on Jan 24, 2009
louislevel_2
  • 374 Answers
SOURCE: I need an instruction manual for the Babylock Pro II Model B15
hi!there similar bobbins winder in any brand of sewing machine uses mostly in domestic particularly in industrial manufacturing in this fig.check it out if similar to your bobbins any how itmay be he86acf3a.jpglpfull onethe bobbins winder that was a thread and shoul be clockwise rotation when coming out to bobbins case,if you to wound the thread on your bobbins winder, pull threads on spool then wind this in several times 4 to 6 rotation clockwise loop thread on top machine there is bobbins winder disc for tension put winder bobbins on shaft winder near hand wheel push the latch against bobbins winder to fit thead run machine to wind the thread.After hread wound in bobbins winder cut thread and insert winder to bobbin case as shown.
insert bobbins to shuttle hook case under needle foot holder
lift the cover plate you can see under this is the shuttle hooke415486.jpgafter set up was made on bobbins thread,set also the upper loop thead beginning at top of machine start on spool, pull thread and loop to upper disc tension then to the slot portion as in figure
insert on lever dial goes to the needle adjust tension to #8 range to #12 for cotton fabrics two layer sewing.
Posted on Mar 17, 2009
jmgldsmth
  • 2005 Answers
SOURCE: i have no manual and cant figure the threading
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=300126694758
Posted on May 20, 2009
micromatikal
  • 2777 Answers
SOURCE: Hi I have a Babylock
So you can turn the wheel manually but the same wheel that turns manually does not turn with the foot pedal. But when you press the foot pedal you hear the motor engage and move / rotate? If so then the motor assembly has a problem on your sewing machine...
Please confirm the scenario I wrote here is in fact what is going on with your machine.
Just reply to my answer here and I can help.
Thanks,
Tim
Posted on Nov 09, 2010
SOURCE: I have a Babylock Denim
Hey there,
This just happened to me last night, too! I figured out that it tightens back onto the shaft with an allen wrench. I found a tiny allen wrench in my tool box and it did the trick. Hope this helps!
Posted on Jan 29, 2011
Babylock
What's the problem?and which machine???
Babylock?? or Euro Pro?
Jan 25, 2014 | Euro-Pro Denim Sewlution 380 Mechanical...
I have a Baby Lock Pro Denim model 1750 sewing machine. Where can I download the instruction manual?
I haven't been able to locate a free download for any Baby Lock model in all of my searches over the months. However, you can download a manual for this model for $10 at http://www.sewingmanualsonline.com/instruction-manual-babylock-1750.aspx. Not too bad to know how to use your machine.
May 31, 2011 | Sewing Machines
Hello, I have a Shark euro-pro sewing machine. I am sewing denim on denim using singer needles that were suggested for denim. The numbers on the package are 2020 110/18 808 R 130/705H 05 un I...
The size of needle is fine for sewing on denim so unless the needle is bent (and even so) I doubt that is the problem. Breaking upper thread typically has more to do with the threading, ie wrapped around some place along the way or misthreaded somehow, of even if you somehow got knots or that it has somehow got thread around the spindle for the spool. So first recheck the threading. Best to do by simply totally unthreading it, looking closely at the spool and winding and then rethreading it again. Make sure your upper tension hasn't been accidentally tightened too.
Next check the bobbin and bobbin thread. First pull on the thread. Is it pulling real tightly or does it flow out readily? Take the bobbin out and look at it. Check the tension also. Is it too tight? That too can cause the upper thread to break.
Is the needle penitrating the material smoothly? Again examine the needle closely to see if it's developed a burr. Better yet just swap the needle with a new needle and try it.
The majority of the time it is one of these things that will cause the top thread to break.
May 18, 2011 | Euro-Pro Shark 80 - 7133
Denim pro #1750 don't have an owners manual
Try this site. http://ifixmachines.com You may be able to find a manual there and if not maybe if you contact them they can help with sewing a straight stitch. Hope this helps and good luck!
Aug 27, 2009 | Sewing Machines
Babylock Denim Pro 1750 Manual
needle keeps working while trying to load bobbin
May 03, 2009 | Baby Lock Sewing Machines
Jan 09, 2009 | Brother LS-1217 Mechanical Sewing Machine
Baby lock denim pro
try putting some bee's wax around your spool
Dec 09, 2007 | Brother LS-1217 Mechanical Sewing Machine
Sewing Machines Logo
246 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
