Question about Bosch Brute Breaker Hammer 11304
Overheating/smoking i just replaced the brushes on this unit, and it still smokes(alittle) and id assume overheating, but the top isnt hot. and it isnt making any unusual noise(normal sound) do the brushes just need to be worked in more?
2 Suggested Answers
alchiecez27
  • 641 Answers
SOURCE: how come my bosch WA20261AU makes loud vibrating sound and its hot inside?
Hi Yvemarie,
Based on what I searched about the machine that you have where in the beep noise can only be hear at the end of the cycle not during the cycle. And also that noise can lower down and I will provide you steps on how to do that. It seems to me also that there is some kind of an issue on your machine since you said there was steaming and smoking happening, right? If the steps I will provide below works and still doing the same thing I guess you need to have that machine serviced.
    • 1 Press and hold the "Select" button on the electric display until the acoustic signal symbol, which looks like a small speaker-phone, is illuminated on the display.
    • 2 Continue to hold down the "Select" button until the system cycles through "Continuous", "Max" and then "Off" settings.
    • 3 Release the "Select" button when "Off" is highlighted next to the acoustic symbol. The signal noise is now turned off on the washer.
Read more: How to Silence a Bosch Washing Machine ' eHow.comhttp://www.ehow.com/how_7552735_silence-bosch-washing-machine.html#ixzz1fRDAKHrO
Posted on Apr 27, 2014
How to fix a hard wired smoke alarm that won't stop chirping
you don't say what kind of smoke alarm you have, or what kind of chirping, so i'm assuming it's a once per minute chirp which usually indicates low battery, but can also indicate that the unit has some other problem...if the unit is more than 10 years old you should replace the entire thing (per NFPA72, the national fire code, all smoke ALARMS must be replaced every 10 years)...if this is newer than 10 years, try replacing the 9 volt battery being careful to follow any instructions that may have come with the unit or may be printed on the back, top or sides...good luck.
Oct 16, 2015 | Home
Why does my Nissan Altima2005 2.4 temperature gauge goes high of I replaced the radiator and thermostats? Car is overheating and smoking. Help!
Hi veronica im pierre if its still overheating and smoking you probably got a head gasket problem prestone goes in the engine and burn smell like burn candy sorry
Mar 11, 2015 | Nissan Cars & Trucks
2002 dodge caravan sport overheated. It has a new radiator and hoses; we changed the thermostat and replaced the relay and pigtail for the cooling fans after it overheated but we still have the overheating...
Double check the thermostat and make sure the water pump is doing its job. To check the thermostat, simply take it out and reassemble the housing with out the unit. Run the engine and hopefully it will get warm to hot. If not check the pump.
Oct 16, 2013 | 1997 Dodge Grand Caravan
Can a dryer heating element smoke if dryer is not running?
Something fried and is shorted. Unplug this unit right away. There are a few sensors on this that could have overheated as they failed causing this smoke and smell, but UNPLUG UNIT!!! Then look at what has fried.
Aug 31, 2012 | Whirlpool Dryers
My icemaker, model #S 106 626636 for a Kenmore top mount refrigerator isnt working. I tried using a jumper wire on L&V as described onlone but nothing happens. i also tried jumping T-H and again...
something I also do is just give the unit power and see, I don't know if ya got polarities right or not but assuming you did and nothing happened, my experience tells me the unit is in fact shot or it would've hummed, spun, smoked whatever. Sorry Bud
Sep 13, 2011 | Refrigerators
While charging the unit becomes hot near the top of the remote. The screen then has a blacked out circle in it.when the unit cools the screen returns to normal. Can this be repaired?
Yes, if you can get inside the remote control. For some reason the power management circuit is overheating and this is overheating the display. If it happens too many times, it could ruin the display. Fortunately, you know exactly where the hot part is; the only question is whether the part itself is the problem or something else is causing it to run hot.
If the hot part is the battery, you definitely want to get it repaired. The charger may be running at a dangerously high rate, or the battery is defective (assuming the temperature exceeds safe limits; some heating is normal). Check your warranty. Report this problem immediately to the manufacturer for possible recall action, even if the warranty has expired, and include the Product ID number as well as the model number (more information is provided on the manufacturer's page). Overheating batteries can explode, so they are considered a safety hazard.
Mar 12, 2011 | Logitech Harmony One Advanced Universal...
My coleman 18volt PMD8133XL drill smokes and has a burning smell when oressing triger
Hello, I hate when this happens to my tools. This could be a number of issues. I would think that the transistor that controls the motor speed is shot or the motor itself is loading the transistor causing the smoke, or the brushes internally of the motor are worn and causing the overheating, hence smoke. Is the unit new or well used?
Joe
Jan 09, 2011 | Coleman Cable Coleman 18 Volt Combo Drill...
I have a dewalt dw364 circular saw. the motor is running slower and sparking internally. The motor also starts smoking while using. A suggestion was to replace the brushes.
I agree with replacing the brushes, and don't use it until you do, so no damage is done to the motor. If it is smoking there is some overheating. Best regards and good luck.
Dec 31, 2010 | Garden
Craftsman Sander 315.117120 has begun smoking after mere minutes of sanding and sounds much weaker than it once was. Is this definitely a motor burnout issue, the motor is no longer sold by sears for this...
Brush failure usually doesn't produce much smoke--check the motor windings for apparent overheating. Replacement of the machine appears to be the best solution. Good luck!
Sep 11, 2010 | Garden
How to fix a vacume that is smoking
any electrical unit that smokes,is ,not worth repairing
Jul 01, 2010 | Eureka 2961AVZ Bagless Upright Vacuum
Bosch Brute Breaker Hammer 11304 Logo
67 people viewed this question
Top Bosch Hammering Experts
John Trevino
snowycreek
Are you a Bosch Hammering Expert? Answer questions, earn points and help others
