Question about Lanier 1205 Copier
Lanier 6735 Copier
Various size stripes running horizontal on page. Copying blank page and still have stripes. Changed toner, cleaned the corona, still have stripes.
  • 2 more comments
  • Insuranceman Aug 13, 2007
    Located the cleaning blade. Looks to be damaged or bent. Seems to be the problem, but waiting for replacement part.
  • Anonymous Jan 04, 2008
    It makes blank copies. After I tried to clean the drum and removed all the powder in it. Can that be the problem?
    What should i do now? Before it was making black lines on the paper.
    Paul from Kampla uganda.
    [email protected] [email protected]
    Thanks.
  • liddymorris Sep 24, 2008
    Where can I find a drum for a 6735 copier Lanier? or User Manual
  • Minhtran Trandinh
    Minhtran Trandinh Dec 01, 2011
    I have the same problem. I have no idea where the cleaning blade is or how to remove it? Can you please elaborate?
Sounds like you need a new cleaning blade. It is located inside the process assy behind the drum.
Posted on Aug 10, 2007
SOURCE:
My sharp AL800 copier is making copies with horizontal lines on the paper and the text is suddenly fuzzy. it just started happening while i was copying documents.
Does this happen when using the document feeder? If so place the original document on the big glass a make a copy did the lines go away if so when you are using the document feeder you are not using the big glass but the small slit glass check if it is clean. If the line are also on copy when using the big glass you have a problem with your drum, cleaning blade, corona, or fuser unit (hot Part). Have atech check it out, Does it print OK?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 25, 2016 | Sharp Office Equipment & Supplies
Minolta CSPro copier is not printing
Change the transfer/separator corona holders,corona wires and clean the optics(mirrors,lens exposure lamp),and make a copies.
May 24, 2010 | Minolta EP4000/5000 CS/PRO Copier
Copier is not copying; blank page is produced
you will chek the transfer corona unit and the bise conecting from the developing area or from the cartradge if thire is no contact point of bias the blank copy will be ocure and if you are not solve you have to chek the high tention voltage from the primery corona or transfer or bias
May 19, 2010 | Canon PC-1060 Black and White Copier
Have a lanier 6735 with an ''A1''Code
Hello sir; A-1 code means discharge corona cleaner problem, check it up may be the cleaner not function right.
Oct 16, 2009 | Lanier Office Equipment & Supplies
HP Laserjet P1006 prints with blank white stripe down left side
Clean the Corona Wire carefully to remove any residue. As the charge on the wire is effectivley masked it cannot deposit any toner to the page and will result in a consistent white vertical stripe.
Aug 29, 2009 | HP LaserJet 1022 Printer
White lines while sending/copying
Everything seems to indicate a dirty 'corona wire'. This seems to be the most common cause of vertical white lines running the length of a page when copying/sending. Below is a link to the User's guide for your machine with instructions for cleaning the corona and other care when using your fax machine. Best of luck.
Greg
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_IntelliFax_2820_2920_MFC_7220_7225N_EN_1344.PDF
May 20, 2009 | Brother IntelliFax-2820 Laser Fax
Dark copies with overprinting
Cleaned the coronas as per instruction book. Done this before but this time it made a difference.
May 07, 2009 | Lanier 1205 Copier
Aficio 1015 Ricoh copier;page margins changed without instructio
Check the print/copying area to see if those controls have been handled or not. Also remove the wire mesh through which the toner passes through. Clean it well but very gently using a painting brush and a blower. Rest it and try a copy....................sodeep
May 04, 2009 | Office Equipment & Supplies
Light print and leaves a blank stripe
Try the blue corona wire on top of the drum unit. If it is not right back to the left it will leave a line on every page.
Jan 04, 2009 | Brother HL 5040 Laser Printer
Why does minolta copier print white stripes?
TRY TO CLEAN AND CHECK MAIN CHARGER AND TRANSFER CORONA FOR VOLTAGE LEAKAGE,AND CHECK DEVELOPER GEAR AND DEVELOPER DRIVE GEAR
Dec 03, 2008 | Minolta EP1030/1030F CS/PRO Copier
703 people viewed this question
Top Lanier Office Equipment & Supplies Experts
quennie732
Adorjani Laszlo
gggg
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
