Question about Viking VGRT360-6B 36 in. Gas Cooktop
Part T36TIISS for Viking Range
Island trim kit
I have a new viking stove slide in electric top range that was installed in our kitchen with existing granite counter tops. But there seems to be a small gap between the stove and the counter. My previous...
If you are talking about a gap caused by the height of the stove, You can lower the height of the stove by adjusting the threaded leg posts on the bottom of the stove. A more difficult fix would be in raise the height of the countertop and cabinets by shimming the bottom of the cabinets.
If your gap is not a height issue, then you can experiment with some type of trim around the stove itself. Local granite dealers has an assortment of trims for issues like this.
I was able to find a number of trims for a back gap on my granite countertops and backsplash from my local European Marble and Granite.
Mar 15, 2013 | Cooktops
We are in need of a Tech Manual for a VGRT5364G conversion from LP to Nat. Gas. Thanks
Manual exist in the location: http://www.retrevo.com/support/Viking-Range-VGRT536-4G-Ranges-manual/id/23666dj391/t/2/
It clearly mentions that:
"A certified
technician is required for any adjustments or conversions to Natural or LP gas."
So pls dont' try unless you already know (and it seems that you don't)
Safety comes 1st!
Jul 28, 2011 | Viking VGRT5364G Cooktop
My Viking Range top has 4 burners and the automatic ignition on the left two burners do not wok. Can hear clicks and gas but no ignition. Can manually lite them. Any ideas?
Sorry to read about your problem, I hope this helps you out.
your lite tube may be clogged, or take a needle and clean the hole's next to the lite tube on the range grills..
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 19, 2010 | Viking Cooktops
I hav a Viking professional. Only one burner ignites.
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Mar 18, 2010 | Viking 42 in. Professional Series...
11 year old Viking VGSU161-6BSS with intermittent gas smell.
STOP USING COOKTOP AND TURN OFF GAS AND GET SOMEONE AUTHORIZED IN AS SOON AS POSIBLE .
Oct 22, 2009 | Viking 37 in. VGSU161 Gas Cooktop
Viking Burners keep on clicking! Anoying!
The causes to the clicking is that the ignitors could be wet, dirty (with grease caked on them or cleaning products or a bad spark module). The ignitors are the little white things on the side of each burner with a metal piece on top. If they are wet (let them dry out for 20 - 30 min on a high flame, if dirty sand the metal piece on top with sand paper or nail file. And if it is the spark module and u are technical, order one from the parts department for Viking. You will need ur model and serial # then find out if it is located under the burners or the rear of the range. There are several wires going to the spark module. Best way is to disconnect one by one and connecting it to the new box until all wires are switched from old to new module. Remember to unplug the unit before doing this because you may get shocked. Also if it is a sealed burner system that means that the burner bowls cannot be lifted from the range and water cannot seap under the burners then you could just change all 4 or six burner bases. Viking has adapted them throughout the many complaints and they are better now. Typical cost is: $350 - $400 if spark module is under burners, in rear = $500 - $600. Burner bases = 400 - 600 depending on number of burners and if it is with a venturi or screws. Good luck.
Aug 23, 2009 | Viking 31 in. VGSU101 Gas Cooktop
Viking pro gas range propane conversion
Sounds like your range is set up for the wrong kind of gas, or, in the case of LP, your installer failed to make the necessary adjustments once it was hooked up. First step is to insure that you have the proper range for type of gas you are using. If not, the orifices for all surface and oven burners will have to be changed out. That should be done by a qualified service technician.
May 21, 2008 | Viking 37 in. VGSU161 Gas Cooktop
Viking range - no way to simmer
There is a conversion kit to convert the range from natural gas to propane, it is possible that it was not installed or not installed at the time of purchase. There is a part in the regulator that has to be switched from one gas type to another as well as individual burner orafices that have to be changed. You should have the point of purchase service verify that this has been done correctly. The complete information should be in your owners and installation manual or available directly from the viking website.
Nov 19, 2006 | Viking 37 in. VGSU161 Gas Cooktop
Viking VGRT360-6B 36 in. Gas Cooktop Logo
Top Viking Cooktops Experts
Dan Webster
Dan Webster
Ed Mac
Andrew Taylor
Andrew Taylor
Are you a Viking Cooktop Expert? Answer questions, earn points and help others
