Question about Video Cameras
Panasonic hdc hs700 HDD error
HDD error, it wont fix it when camcorder is turned off and on.
SOURCE: i ned the English version manual for Panasonic HDC-SD7 HDV Digital
http://panasonic.jp/support/video/manual/manual.html
Posted on Feb 04, 2008
  • 987 Answers
SOURCE: Manual for my panasonic HDC SD20 camcorder
from here you can download manual ...
http://www.panasonic.co.uk/html/en_GB/Products/Camcorders/HD+Camcorders/HDC-SD20/Manuals/1973151/index.html?trackInfo=true
Posted on Aug 11, 2009
Davidivory1
  • 338 Answers
SOURCE: Panasonic HDC-SD1 camcorder will not turn on
Are the Batt's full? because this looks like you have not enough power to keep the camera on.
Posted on Jun 06, 2010
  • 3 Answers
SOURCE: E:31:00 Error Code on sony camcorder
Recently, I faced the same problem with a Sony XR-155 camcorder while being on vacation. Fortunately, I managed to recover my videos. First, make sure that you as little as possible to the hard drive in the camera menu, so I would not recommend to rebuild the image database or to reformat the drive.
Connect the camera to your PC in the same way that you would usually do. When I tried to access the drive in Windows Explorer, I got a message that the drive was not readable and needs formatting. You do NOT want to do that. I decided to make a full backup of the drive first, so that I could safely fiddle around later on.
The program that I used is Paragon Drive Backup. It gave me a few error messages during the back-up, which I all ignored, and after about 1.5 hours the copy was ready. The next step was to mount the image as to a free drive letter. I figured that I would need some kind of data recovery tool to extract the data, but to my surprise, the mounted disk image was readable in Windows Explorer as if no problem had ever occurred. Luckily, I was able to extract all of my videos from the camera in this way.
Of course I do not know for certain whether this technique also works in your case. For instance, it could be the case that the code E:31:00 is a generic HDD error message and therefore, it might be the case that your camera has a different problem than mine had. However, I think it is worth the shot to try to recover your data in this way (I assume Backup & Recovery 10 Suite does the same trick, a demo version is available on http://www.paragon-software.com/downloads/home/).
This procedure of course does not fix your camera (what I understand from various massages across the internet is that you should send it to Sony to get it repaired), but at least you might be able restore your data. I hope that you will be successful, good luck!
Posted on Sep 24, 2010
Keynan
  • 977 Answers
SOURCE: Hallo, I have a Panasonic HDC-SD600
Hi Nikolas!
There are 2 models of this camcorder: NTSC or PAL, so there's no setting within the camera to change the rcording TV system (PAL or NTSC).
Apparently, the TV system used by your camcorder is different that what you've selected while installing HD Writer software.
I can't find any detailed manual for HD Writer on the web, to direct you on how to change the preferred video format, but by uninstalling and reinstalling the software, you can choose another country which uses the your camcorder's video format (for example: USA- for NTSC; Australia- for PAL; etc.).
By the way, I've answered a exactly similar question to yours few days ago and it seems like my solution worked! You can read more about it here.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Good uck and best regards,
Pelu.
Posted on Feb 13, 2011
Hi I have Panasonic camcorder hoc-hs700 when turn on camra after few second later message on screen hdd error occurred please turn off unit and on again I have done that several time .but not luck pl
Hello there .
Well according to a manual,
Sounds like the Hard Drive is faulty.
"ERROR OCCURRED. PLEASE TURN UNIT OFF, THEN TURN ON AGAIN." is displayed.
The unit has automatically detected an error. Restart
the unit by turning the power off and on.
The power will be turned off in about 1 minute if the
power is not turned off and on.
Repair is needed if it is repeatedly displayed even if it is restarted. Detach the power connected, contact consumer support. ( Do not attempt to repair the unit by yourself
So......why not try a FORMAT of the Hard disk drive which seems to be at fault....nothing to lose friend Worth a try !!!!
Page 142 of this manual http://service.us.panasonic.com/OPERMANPDF/HDCHS700-MUL.PDF
Sep 16, 2014 | Lands Phones
Tip
Convert and Merge Panasonic TM700/HS700 MTS to ProRes MOV for FCP 7 on Mac
More Article about ProRes Converter: <br /><a href="http://www.aunsoft.com/mac-avchd-videos-to-prores-422-converter-m2ts-to-prores-422-quicktime/">Convert M2TS to ProRes</a> <br /><a href="http://www.aunsoft.com/transcode_convert_avchd_mts_m2ts_to_fcp_fcp7_apple_prores_422_on_mac/">Convert AVCHD MTS to ProRes</a> <br /><a href="http://www.aunsoft.com/convert_transfer_panasonic_hs60_mts_to_apple_prores_422_mov_for_editing_on_final_cut_pro/">Transcode Panasonic 1080p AVCHD to ProRes</a> <br /><a href="http://www.aunsoft.com/no_loss_of_quality_mts_to_prores_conversion-edit_panasonic_tm900_mts_on_fc_studio/">No Loss of Quality Panasonic MTS to ProRes</a> <br /><a href="http://www.aunsoft.com/convert_nikon_d5100_h264_to_prores_for_editing_on_fcp/">Convert Nikon H.264 MOV to ProRes</a> <br /><a href="http://www.aunsoft.com/convert_canon_eos_t2i_canon_7d_mov_to_prores_mov_for_final_cut_pro_on_mac/">Convert Canon EOS MOV to ProRes</a> <br /><a href="http://www.aunsoft.com/convert_deinterlace_sony_hxr-nx5e_avchd_to_prores_mov_for_fcp_on_mac/">Deinterlace Sony AVCHD MTS to ProRes</a> <br /><a href="http://www.aunsoft.com/convert_bloggie_touch_full_hd_mp4_to_prores_for_final_cut_with_mac_sony_bloggie_touch_converter/">Convert Sony Bloggie Touch Full HD MP4 to ProRes</a> <br /><a href="http://www.aunsoft.com/apple_prores_422_converter_convert_and_playback_apple_prores_codec_movies/">Convert and Playback Apple ProRes Codec Movies</a> <br /><br /><b>Panasonic HDC-TM700</b> is the new model introduced in early 2010 with 32GB built-in Flash Memory. To maximize the beauty of Full-HD 1920 x 1080, 60 progressive recording*, Panasonic worked to develop the ideal camera system. <br /><b>Panasonic HDC-HS700</b>,New 1080/50p recording (Full-HD, 1920 x 1080, 50 progressive recording) conveys about twice the information of 1080i (interlace) recording to produce the ultimate beauty in image quality, exceeding even conventional Full-HD images. It minimizes afterimages and flickering caused by subject motion and renders crisp, detailed images. 64GB SDXC card can record approximately 27 hours 30 minutes of 1920 x 1080i High Definition video in HE mode, and approximately 5 hours 20 minutes of 1920 x 1080p full High Definition video in 1080/50p mode. <br />Final Cut Pro is supposed to support AVCHD Lite import, but it does not work very well.If you encounter any problem using GH2 AVCHD Lite on Mac, or want to edit TM700/HS700 1080p MTS in FCP/FCP 7, it is recommended that you convert TM700 Full HD to common MOV for FCP/FCP 7.So you may face the rendering problem when editing in Final Cut Pro. To avoid waiting for rendering in Final Cut when editing, it is recommended want to <b><a href="http://www.aunsoft.com/video-converter-mac/">Transcode AVCHD to ProRes 422 for Final Cut Pro</a></b> native format. <br /><br />Apple ProRes,Apple ProRes 422,Apple ProRes 4444,introduced in Final Cut Studio, was advertised to one of the codecs to result in less compression and higher data rate/higher quality files for HD editing in Final Cut Pro. <br /><br />Here is the step-by-step guide for you to <b><a href="http://prores-converter.com/2011/06/convert-and-merge-tm700hs700-mts-to-prores-mov-for-fcp-7-on-mac/">Convert and Merge TM700/HS700 AVCHD MTS to PreRes 422 MOV</a></b> for Editing in FCP/FCP7 without rendering on iMac or MacBook Pro with Mac OS X like Snow Leopard. <br /><br />Step 1. Load Panasonic TM700/HS700 videos to Aunsoft Video Converter for Mac. <br />Run Aunsoft Video Converter for Mac as the best <b>TM700 AVCHD Video to ProRes Converter on Mac</b>, click the "Add" button and you can browse the TM700/HS700 1080p videos for conversion. <br /><br />Step 2. Choose Apple ProRes for Final Cut Pro. <br />Click the "Format" option, and navigate the mouse cursor to <b>Final Cut Pro &gt; Apple ProRes 422 (*.mov)</b> as output format. The video to ProRes 422 converter will transcode Panasonic DMC-GH2 1080 AVCHD Lite to Final Cut Pro native format. <br /><br />Step3. <b>Merge Panasonic 700 1080p AVCHD files. (Optional)</b> <br />Tick the checkbox for "Merge into one file", and the Panasonic TM700/HS700 1920&times;1080 AVCHD converter will join and combine the video clips into a single file as output. <br /><br />Step 4. <b><a href="http://canon-videoconverter.com/2011/06/convert-and-merge-tm700hs700-mts-to-prores-mov-for-fcp-7-on-mac/">Convert Panasonic TM700/HS700 videos to Apple ProRes for FCP</a></b>. <br />Click the convert button under the preview window, the conversion from <b>Panasonic Camcorder AVCHD to FCP Native Format ProRes 422</b> will start immediately. <br /><br />After converting and merging the Panasonic TM700/HS700 AVCHD files, just import the output Apple PreRes 422 .mov files to Final Cut Pro 7 or Final Cut Pro 6 for editing and the video is in HD 1920&times;1080.Optimize your workflow and save time with the Apple ProRes compression for Final Cut Pro. You can also import the output videos to Final Cut Express (FCE) 4 for editing in full HD.
on Jun 16, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
Tip
Convert/Import MTS, M2TS files to FCP MOV, MP4, DV on Mac OS
MTS format is high-definition MPEG, AVC, H.264 transport stream video file format which commonly used by HD camcorders such as Sony, Canon, Panasonic, JVC. HD camcorder makes use of MTS in the form of AVCHD, a format for recording and playback of high definition video.
Nowadays, most digital camcorders record videos in AVCHD MTS/M2TS format that is a high-definition and high quality video format.
Here you can check the list of some popular HD camcorders recording video in AVCHD MTS/M2TS format including Canon, Sony, Panasonic and JVC as follows:
Canon HF10, HF100, VIXIA HF S100, VIXIA HG21, VIXIA HF200, VIXIA HF S200, VIXIA HF M300, HG20, HG21, IVIS HF M31, IVIS HF R10
Sony HDR-SR1, HDR-SR10, HDR-XR100, SDR-SR10, HDR-SR11, HDR-XR100, HDR XR-500V, HDR-TG1, HDR-CX7, HDR-SR5, HDR-CX7
Panasonic HDC-SD60, HDC-SD100, HDC-SD200, HDC-HS100, HDC-HS350, HDC-HS700, HDC-TM35, HDC-TM350, HDC-TM700, HDR XR-500V
JVC GZ-HD10KR, GZ-HD30, GZ-HD40, GZ-HM200, Everio HD10, Everio GZ-MG130
HD camcorder owners can enjoy HD video with their HD camcorder, however, original AVCHD MTS, M2TS files cannot be directly imported to Mac. So for Mac users, if you want to import MTS/M2TS video to FCP(a highly-regarded video editing, compositing, and special effects package for the Macintosh) on Mac for editing, you have to convert MTS/M2TS files to MOV, MPEG-4, DV for FCP firstly.
Doremisoft MTS to FCP Converter for Mac is the best software to convert original MTS, M2TS files to Final Cut Pro with good quality. It can transfer MTS video to MOV, MP4, M4V, AVI, DV, 3GP, etc and other HD videos like HD MP4, HD MOV, etc. With this AVCHD Converter for Mac, you can convert MTS video to FCP, FCE, iMovie, Quicktime, iTunes, iDVD, iPad, iPod, iPhone, Blackberry, PSP and so on.
Easy Tutorial for you to convert MTS/M2TS files to FCP on Mac here:
Step1: Import MTS, M2TS Files to Mac MTS Converter
Click the "Add File" to upload your chosen AVCHD MTS, M2TS files to MTS to FCP Converter for Mac after you lauched it.
Step2: Set Output Video Format for FCP
Click "Profile" to open the Profile drop-up list to select MOV, MPEG-4, or DV as output video format for FCP on Mac OS. And you also can convert MTS files to iMovie, Quicktime, iDVD, iPod, iPhone, PS3, Blackberry, etc.
Step3: Convert MTS Files to FCP
Click "Start" to convert AVCHD MTS, M2TS videos to FCP on Mac. you can edit your converted MTS, M2TS files with FCP on Mac OS X after converting finished.
Related: How to Convert MTS, M2TS to iMovie for Editing?
How to Convert Panasonic HDC Series to Mac and Edit Panasonic HDC Video in iMovie, FCP?
on Oct 21, 2010 | Computers & Internet
Panasonic hdc mdh1
My camera mdh1 Error occurred Problum Solution
Sep 25, 2013 | Panasonic Hdc-mdh1 Hd Camcorder pal Mdh-11...
Tip
Convert/Edit Panasonic HDC-SD9/HS700/TM700 to Mac, iMovie, FCP. FCE
Panasonic HDC camcorder family has a great number of High-Definition Camcorders that satisfy different people who want to record their interesting daily life, now, You can check the list of popular Panasonic HDC series camcorder as follows:
Panasonic HDC-SD Series: Panasonic HDC-SD9, HDC-SD10, HDC-SD60, HDC-SD100, HDC-SD200, HDC-SD700, etc.
Panasonic HDC-HS Series: Panasonic HDC-HS250, HDC-HS300, HDC-SD60, HDC-HS200, HDC HS100, HDC-HS700, etc.
Panasonic HDC-TM Series: Panasonic HDC-TM10, HDC-TM20, HDC-TM60, HDC-TM50, HDC-TM30, HDC-TM200, HDC-TM300, HDC-TM700, etc.
Most of Panasonic HDC Series Camcorders record video in AVCHD MTS/M2TS files, for example, Panasonic HDC-SD9 records 1080i 17Mbps video in M2TS files; Panasonic HDC-SD700, Panasonic HDC-HS700,
Panasonic HDC-TM700, these three types store videos in MTS format and all offer Full HD 1,920x1,080-pixel resolution at 50 frames per second. For Mac users, if you cannot import Panasonic HDC video to Mac to enjoy, or cannot directly edit Panasonic AVCHD MTS/M2TS files in iMovie, FCP, FCE, you need to convert Panasonic HDC videos to MOV, MP4, 3GP, M4V, H.264 for Mac and then you can edit converted AVCHD MTS/M2TS video with iMovie, iTunes, FCP, FCE, etc.
Mac Panasonic HDC Video Converter, a professional AVCHD Converter, is designed for converting videos collected from Camcorder Panasonic, Canon, Sony, etc to MP4, MOV, MPEG, 3GP, M4V, AVI, etc to Mac, then you can play AVCHD MTS/M2TS, videos on Mac, iPad, iPod, iPhone, PSP, Blackberry, and any other mobile phones.
How to convert and edit Panasonic HDC video to Mac?
Step1: Import Panasonic HDC Video to AVCHD Converter for Mac
Click "Add File" to upload your Panasonic HDC video to Mac AVCHD Converter after you launched it.
Step2: Set Output Video Format for Mac, iMovie, FCP
Click "Profile" to open the Profile drop-up list to select MOV, or MP4 as output video format for Mac OS, iMovie, iTunes, iDVD, FCP, FCE, etc.
Step3: Convert Panasonic HDC Video to Mac, iMovie
Click "Start" button to convert Panasonic AVCHD MTS/M2TS files for Mac. After conversion finished, you can enjoy converted MTS/M2TS files on Mac or edit these converted AVCHD video with iMovie, FCP, FCE, iDVD, etc as you like.
on Oct 19, 2010 | Computers & Internet
I am looking for a user manual for Panasonic HDC-HS60 camcorder
You can download and print the instruction manual for Panasonic HDC-HS60 in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Click here to download the latest version of Adobe Reader.
Thanks for using FixYa.
Oct 03, 2010 | Panasonic HDC-HS9 HDD Camcorder
Cannot re use a formated SDHC card in Panasonic HDD camera.
after formating the card u can re use it ,somthing is wrong with the card.Try once again after cleanning the card and card reader.
Apr 05, 2010 | Panasonic SDR-H40 HDD Camcorder
How do i import videos from my HDC-HS20 Panasonic camcoder to a pc?
Depending upon you PC operating system, you can connect via a USB cable. Since it sounds like you don't have the application CD that comes with the camera, contact Panasonic support on the following page to get a copy. Also, you can download the user manual for free at the same site so that you can see the instructions for downloading stills and video.
http://www2.panasonic.com/consumer-electronics/support/Cameras-Camcorders/Camcorders/Hi-Def-Camcorders/model.HDC-HS20K
Jul 29, 2009 | Panasonic SDR-H40 HDD Camcorder
Need a manual
I went by the picture on this post Panasonic HDC-HS9-HDD. found a link (you may have to copy/paste in address bar)
http://www.panasonic.co.uk/html/en_GB/Support/Downloads/220239/index.html#anker_220239
the manual is under HDC-HS9 (mfr# HDC-HS9)
May 05, 2009 | Panasonic HDC-HS9 HDD Camcorder
Video Cameras Logo
140 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
