Question about Tascam Cd-rw900sl Cd Recorder/player
Tray cd player door not open
The tray not open when push key to open
    Scholar:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 134 Answers
Probably a stretched out loader belt due to age of the unit. You may be able to find a replacement on ebay but need to get the part number from the repair manual. Most belts are available in Europe even if not available in north America. When searching on eBay use the international search option to find dealers in Germany which stock many old repair belts for home audio/video.
Posted on Mar 16, 2014
Door will not open when you push open button
Presume you mean CD/DVD players tray? It has a small hole. Intoduce a straight clipp, and press until tray opens
How to manually open CD or DVD drive
May 12, 2015 | Miscellaneous
Why won't the CD drawer and Cassette door open on my Panasonic SA-PM17 CD Stereo System?
This does happen with CD trays, it's quite common. I can't remember the exact mot common cause, but it's some worn out part, such as a small (plastic) cog wheel. Search on "cd tray won't open" on the internet to find a multitude of reasons, most to do with computer CD trays, but I guess the mechanism is essentially the same. These may also describe ways round the problem.
Some CD players have a small hole on the front near the tray into which poking a straightened out paperclip should enable you to open the tray by a few mm, enough to be able to pull it open in an emergency - but it's awkward to do on a frequent basis.
5.May.2014
May 05, 2014 | JVC XL-F254BK 5-Disc CD Changer
How to get a dvd tray unstuck
There are two ways to open the CD/DVD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD/DVD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD/DVD disc.
If you still having problem opening with the Eject button, then the CD/DVD drive is faulty and needs replacing.
May 19, 2013 | Televison & Video
Replace cd player
Apr 16, 2013 | Samsung Computers & Internet
The tray on my Arcam Alpha 6 CD player will not eject and refuses to budge. Neither the remote control nor the load button on the front of the unit will make it open.
It's either the gear on the tray loading mechanism or it's drive belt. The gear is made of a soft material and the teeth wear down on the hard tray rack. Get hold of Arcam and order TP21H replacement part and belt. The same happened to me and the gear had perished. In the meantime stick something onto the front of the tray that you can use to pull it open after you have pressed the 'load' key. Place your CD in the tray, press the 'load' key and push the tray closed manually. The player will work like this until you can replace the gear/belt.
Jul 04, 2010 | Audio Players & Recorders
Cd player wont eject cd
Try this:
Starighten a paper clip and gently push it into the small hole situated usually just below the tray door until you feel some resistance: continue to push gently and the door should open slightly - enough for you to pull it open and reclaim your disk. Make sure the PC is turned off before you do this. You may then find also that the CD tray will co-operate again when you turn it back on.
Sep 10, 2009 | RCA Alarm Clock w/CD Player, AM/FM Stereo...
Onkyo C-707chx cd tray jammed won't open won't play
I have the same exact problem with my Onkyo C-707CHX and I found a solution that doesn't involve jamming any screws or other metal objects into your cd tray (which could most likely just cause more damage). This way seems a little safer: Power on your device and hit the open button. As soon as you hit the open button quickly push slightly with both hands on both sides of the cd tray that should be opening. You should hear the trays moving around in there and then you have to try to feel for a slight push from the tray. As soon as you feel that slight push, take your hands off of the tray and let it come out. This has been working for me for a while now (and hopefully will continue to work until I take it to get fixed somewhere). The only issue I have run into is that my "Disc 1" open button doesn't work with this method. So I just use this method with disc 2 or 3 and then once it's open I can hit the disc 1 button to get to that tray. So if it doesn't work with one tray, try the other two as well. Hope this helps.
Jun 07, 2009 | Onkyo DX-C390 6-Disc CD Changer
Cd stuck in dead cd player, how can I get it out?
On almost all CD Players, there is a small hole, about the size of a paper clip, located somewhere on the door. Take a paper clip, straighten it out, and push it into the hole. Push it in until you feel the door unlatch. Then, you should be able to open the tray.
May 02, 2009 | Audio Players & Recorders
Onkyo c707chx...
This is an easy fix if you are somewhat handy.... The belt for the door/tray is slipping. If you remove the enclosure and face plate, you will see two motors below the disc drive. Press eject while observing the pulley to the left. You should see the problem with the motor shaft spinning and the belt slipping. Replacing the belt is possible without any further dissassembly. Simply bend some light wire into an L shape and you should be able to hook both pulleys and lace the new belt on. As far as obtaining a new belt I decided to do the simple thing and use a slightly smaller rubber band. The repair has held now for almost three months and the player is used everyday. Good luck.
Jun 21, 2008 | Onkyo MC35Tech CD Shelf System
Denon CD door jammed
If you are comfortable taking the cover off, you can try removing the cover and then try to help the tray out the same time you are hitting OPEN/Close.
IF you are not comfortable removing the cover then, you can try to take a credit card (Actually, if you have any of those JUNK credit cards that the CC companies send out as trial offers, those work the best, and who cares if you bend those, they get tossed anyway) and bend an edge at a 90 degree.. (about 1/8" of the edge) so it makes like a small ledge. try to fit it inbetween the top of the door, and then see if you can open it up. Some players have a seperate door, and some trays are attached to the door. You might be able to help it out or unjam the tray this way.
And in the Future, with any other CD/DVD Players, use your remote control or the open and close button to open and close the tray, and NEVER Push on the tray itself. If I had a dollar for every dvd player tray that Ive fixed because of this, I would be buying bill gates dinner. (not really, but you get my point)
Good luck.
Feb 03, 2008 | Audio Players & Recorders
Tascam Cd-rw900sl Cd Recorder/player Logo
119 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
