Question about Garden
Pioneer chainsaw p39 - Garden
Repacing the cambelt tentioner
Ah yes then. See here p39 on
http://www.turboninjas.com/camry/eg2.pdf
If you find the engine is a little different to this, it is probably the older 3VZ with a cast iron block. In that case I need to email you a file.
Feb 27, 2014 | 1993 Toyota Camry V6
Car AC makes squeeling sound when turned on
That is the compressor drive belt slipping. It should be tightened. See p39 here
http://www.turboninjas.com/camry/ac.pdf
Oct 27, 2012 | 1999 Toyota Camry
When I stored my pioneer chain saw last year, I forgot to empty the fuel from the tank and the carburator. Now it won't start. What should I do? Louis
GO TO YOUR LOCAL RURAL KING AND PURCHASE SOME ..."LUCAS GAS TREATMENT FOR CHAINSAWS"... TO CLEAN THE STALE GAS IN YOUR CHAINSAW.
HOPE THIS HELPS!
Sep 06, 2011 | Homelite Garden
What is the correct gas/oil mixture on a Pioneer 1074 chainsaw manufactured in 1981?
I would run it on a 25-1 fuel oil mix,with good quaility two stroke oil.
Jul 16, 2011 | Garden
2000 nissan maxima. The service engine light is on with codes: p38 & p39.
P0038 is HO2S Heater control circuit high bank 1 sensor 2
Nov 27, 2010 | 2000 Nissan Maxima
What is the petrol/oil ratio for the poulan pioneer 2050 chainsaw?
The fuel must be mixed 40:1. Also, the manual is here: http://www.mccullochpower.com/node4043.aspx
Just click on the first link. Good luck!
Jun 27, 2010 | Poulan Pro Chain Saw 46cc 20"
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
