Question about DeLonghi DD50P Dehumidifier
Manual How do I obtain a manual for the DD50P
Is there a special code to direct water to pump, dump bucket or drain
That would be the "Pump" button on the control panel. When you press it, your dehumidifier display should indicate "PUMP", and the unit should start pumping water out that little port at the center rear of the dehumidifier.
Alternatively, you could stand the dehumidifier on a counter and direct your waste water out the larger hose connection into a sink.
I personally carry it (more than five gallons per day) upstairs to the laundry, because it's distilled water - the softest water you can get. Works GREAT in the washing machine. 8) 8) 8)
Jul 30, 2014 | DeLonghi DD50P Dehumidifier
Just purchases the DD50PC. Set the pump to continuous, hooked the hose to the slop sink in basement approx 8 feet, pump running fine but when looked at it the next day the pump had shut off and the tank...
The reason this happened may be two fold. Either the hose is clogged or the length of hose is to long and then has to go up hill into the slop sink. The owner's Manual says the pump is rated for an 8 foot lift. However, what I have discovered is that rating, does not take friction loss in to account.
Try moving the unit closer to the sink and shorten the hose about a foot or two. Actually, a floor drain would be perfect, if you have one in your basement.
Hope this helped you ad thanks for choosing FixYa.
Aug 07, 2011 | DeLonghi DD50P Dehumidifier
Bought a Delonghi dd50pc dehumifier last week for my basement and I have the hose going uphill and out a window but the pump always shuts off after 3-4 minutes, filling the tank instead. Now when I lay...
You really answered your own question. The pump in the dehumidifier only has so much water lift capacity. By trying to run it up and out, you have exceeded the maximum lift capacity. Using a floor drain or even a bathtub drain in the basement will probably work, as long as the hose is not to long.*
However, if you can use a floor drain, there's no need to use the pump function. You can use the continuous drain on the back of the unit. using the drain hose provided for that application.
*The 13 ft lift capacity noted in the Owner's Manual includes whatever length of hose you're using to get to the window. As there is some friction loss involved. But, they fail to point that out.
Hope this helps you and thanks for choosing FixYa.
Jul 27, 2011 | DeLonghi DD50P Dehumidifier
The water will not drain into the storage tank, and insists on leaking out the back. How can I get it to drain into the tank?
The drain tube and or hole that is supposed to drain water into the bucket is clogged. To solve this problem, do the following:
First, turn the Unit OFF & Unplug it.
Remove the water collection bucket and look up inside the bucket holder cavity. You will see either a drain hole or small tubing that drains the water into the bucket. Using an appropriately sized, 18" long, plastic Zip Tie, carefully insert the tip of Zip Tie into the hole or tubing. Continue to push it in until you reach a bend in the tubing. You will need to gingerly work the Zip Tie past this bend, until it either bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip Tie back out while rotating (twisting) it. This will breakup any clogs. As you reach the inserted end of the Zip Tie, be prepared, as some water may follow. Reinstall the bucket, plug the unit in and turn the Master ON/OFF Switch to ON. NOTE: if you don't have a Zip Tie, you may use something similar, but NO wire coat hangers.
Hope this helps you and thanks for using FixYa.
Jul 25, 2011 | DeLonghi DD50P Dehumidifier
I was just given a DD50PC as a gift from a friend who did not have the accompanying instruction booklet. He told me to turn the unit on and let it work. I do not know what temp to set it at. It has to...
On a dehumidifer, you set the relative humidity, not temperature. Normally the humidity should be set within 40 to 60 percent humidity.
Click on this link for a copy of the manual for your machine. www.sylvane.com/images/.../delonghi-dd50p-dehumidifier-user-manual.pdf
Hope this helps you.
Jul 01, 2011 | DeLonghi DD50P Dehumidifier
Condensate pump buzzes but does not remove water. have blown out discharge hose and clean check valve with changing symptons. Should I give up and put it on a box and buy a separate condensate pump or...
Edwin, according to the Owner's Manual, when this happens the drain hose is not connected properly. Turn the unit OFF and unplug it, then disconnect the hose and reconnect it. Plug the unit back in, Turn the Master ON/OFF Switch to ON and press the pump button. If the hose is connected properly, the pump should tunr on and pump the water out.
To help you further, I have included a link to the Owner's Manual for a Delonghi model like yours. Once you go to that page, click on the Acrobat Reader Icon and download the Owner's Manual. You may print it is you like.
http://www.delonghi.com/us_en/products/dd50p/
Hope this helped you. Please let me know. Thanks.
Jun 23, 2011 | DeLonghi DE500P Dehumidifier
LOOKING FOR amcor dc800 manual. Any advice? thanks
problem solved. found instructions.
thanks
Oct 24, 2009 | Amcor Dehumidifiers
DE400 dehumidifier
Go to site...
safemanuals.com/references.php
in top search box show user manuals
go to search data base find delonghi- then type in de400 humidifier
then download
Sep 15, 2008 | DeLonghi DE400 Dehumidifier
Open Questions:
See all DeLonghi DD50P Dehumidifier Questions
DeLonghi DD50P Dehumidifier Logo
21 people viewed this question
Top DeLonghi Dehumidifiers Experts
Mike Kolbay
Level 1 Expert
Are you a DeLonghi Dehumidifier Expert? Answer questions, earn points and help others
