Question about Maytronics Dolphin Supreme M4
#2010 Remote Control Unit from Maytronics - Maytronics Dolphin Supreme M4
How do I tune my remote control to my xenius TV
xenius tv remote code - Technical - Digital Spy Forums
forums.digitalspy.co.uk/showthread.php?t=492951
Digital Spy
Nov 30, 2006 - 24 posts - ‎12 authors
hi all, found this site trying to sort my new tv out. i am trying to set the code on my skyremote to control the volume etc on my xenius tv, but i cant ... Vestel remote control question (TOO versatile ...
Sep 2, 2010
TV stuck in standby mode. - TV and Home Entertainment ...
Feb 9, 2010
More results from forums.digitalspy.co.uk
Xenius LCDX37WHD88 - Who Makes This TV & Wheres The Customer ...
www.avforums.com > ... > Televisions > LCD & LED LCD TVs
Jul 15, 2009 - Hiya, I am having problems locating a picture of the remote control for a... hi my remote has broken for my xenius tv I have bought a universal ...
I cannot programme channels for my xenius 32" lcd - Fixya
Jan 13, 2016 | Televison & Video
Does anyone know how to fool Honda nsc 50 engine control unit or cdi unit Into giving a higher rpm by maybe tweeking crank speed sensor for example ?
Buyang 110 remote bypass how do u do it - ATVConnection.com ATV ...
atvconnection.com/...engine.../324114-buyang-110-remote-bypass-how-...
Feb 24, 2010 - '69 Honda MiniTrail 50 ... The way to disable the remote start radiocontrol module is to simply unplug it. ... Another way to add the jumper is just to do it directly: Find your CDI and look at the wire color on the ... This will restore the ability of the ignition switch to kill the engine when the remote is unplugged.
Honda Dio NSC110 MAGNUM REVOLUTION-PRO ...
Nov 29, 2015 | Honda Cars & Trucks
Goes to wall and turns itself over. It is clean.
Maytronics-Dolphin pool cleaner, Dolphin Diagnostic ...
? 3:44
www.youtube.com/watch?v=-x8hwghv8BE
Apr 4, 2012 - Uploaded by Swimming Pool Tips, Reviews & How To -MrDgvb1 Maytronics-Dolphin pool cleaner, Dolphin Diagnostic ... Solar Breeze: The Robotic Solar-Powered Pool Cleaner Review: http://youtu.be/jzWfClbOnIc ... Pentair Kreepy Krauly Legend Review, Troubleshooting & Tips:
Aug 08, 2015 | Dolphin Maytronics Diagnostic Robot...
Blows fuse when I turn it on
try disconnecting cord to the unit that goes into pool check to see if water in plug if so dry out if no water try turning on without being connected if it still blows fuse bad control unit or water inside
Oct 09, 2013 | Maytronics Dolphin Dynamic Dolphin Dynamic...
I have a Citizen flat screen TV model LT 2010. I just want to use my Jumbo Universal Remote Control but I dont have the codes. can you give me the codes for TV so that I can control my Flat...
here are some tv codes that you may find for your citizen tv model.the list are 002, 112, 319, 402, 407, 502, 512, 701, 805, 906. aside from those code click this universal remote control which have tv codes it might have compatible to your unit.make sure the remote control was properly set up so that the tv unit must recognized the codes. good luck i hope it will help you.
Jun 04, 2011 | Televison & Video
Need to find wires for power lock &power unlock am installing a remote start these wires are for the power door locks on 2010 ridge line
If your 2010 Ridgeline is the same as the 2009, the wires colors and location are listed below;
Power Lock pink/black - MICU, green 30 pin plug, pin 25
The MICU (Multiplex Integrated Control Unit) is part of the dash fuse box, in the driver kick. It has 2 plugs on the left side edge of the fuse box. Meter this wire while pressing the passenger door lock switch.
Power Unlock pink/blue - MICU, green 30 pin plug, pin 9
Feb 08, 2011 | Honda Ridgeline Cars & Trucks
Quit working are there repair people available in san antonio, tx?
Thank you for posting your question here on Fixya.com.
Contact the US representative for Maytronics at www.maytronicsus.com and they will send you repair information as well as a listing of service centers in the country. There are a couple in Texas if memory serves but I am not certain they stock much in the way of parts. The listing Maytronics sends notes who stocks parts and lists phone numbers so you may want to check with them before shipping or dropping off the unit.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Jun 28, 2010 | Dolphin Maytronics Advantage
My dolphin cleaner runs for a couple of minutes and then shuts down. What could the problem be?
It is usually either the power supply or the motor unit or both. None of those items are considered do-it-yourself repairs. For information on sending the unit in for service you can check with the manufacturer at www.maytronicsus.com or try us at www.arrowpools.net. If the unit is several years old and in need of repair and also the replacement of wear items such as brushes and/or tracks, it can be cost prohibitive to fix. It is helpful if you get the serial number from the units casing when you contact us or Maytronics so we have an idea of how old it is.
Nov 23, 2009 | Dolphin Maytronics Advantage
Stopped working
Try a self test...Flip the unit upside down on the ground, tracks 'up towards the sky' and trun it on. It should run for about 30 seconds during which it will cycle through various track and impeller motions.
If it completes the test, try it in the water again.
If not, contact us at www.arrowmotor.net for service arrangements or parts. You can also try Maytronics direct at www.maytronicsus.com.
Jun 01, 2009 | Dolphin Maytronics Diagnostic Robot...
Maytronics Dolphin Supreme M4 Logo
150 people viewed this question
Top Maytronics Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Maytronics Pool and Spa Expert? Answer questions, earn points and help others
