Question about Vehicle Parts & Accessories
Where is the interior lights fuse on a 2001 Intrepid please?
Hi!The radio on my Intrepid 2001 doesn't work anymore but the 3 slider leds for bass, middle and treble are flashing non stop.Could you help me please?
  • 635 Answers
Replace radio.
Posted on Oct 14, 2013
My 2001 bmw 325i doesn't have power no light no radio and the interior lights are all off
Sounds like you have a dead battery. Try recharging the battery or get someone with jumper cables to give you a jump. If your battery dies again after driving for at least an hour you likely need a new battery. If the battery in the car is the original, it's time to replace it anyway.
Jan 06, 2013 | 2003 BMW 325
All interior lights flicker while driving & in park
I would check your fuse board for a loose fuse or wire to it from the battery as sometimes vibration loosens terminals eric
Dec 12, 2017 | 2000 Dodge Intrepid
My interior lights and radio do not come on anymore
Radio lighting is usually on a different fuse, graba a test light and check all your fuses, you'll probably find the cure.
Feb 10, 2012 | 1995 Jeep Grand Cherokee
2001 dodge stratus Radio doesn't work bass & trebble lights blink always
you should let it recheck from a electrician, probably one of your wires loose or something burned on the first i could think
Feb 06, 2012 | Cars & Trucks
What number fuse goes to the radio, plate lights and interior lights
The radio fuse is #7 a red 10amp fuse. The plate-interior+inst. lights are on fuse #4 a yellow 20amp
fuse, both located in the fuse block at the far left end of the dash pad. Hope this helps.
Nov 22, 2010 | 1999 Dodge Intrepid
2001 dodge neon radio
Also had no radio but flashing bass/treble indicator lights. As suggested by another post, I disconnected neg. batt. cable and pulled the "interior cluster" fuses, re-set them and then reconnected batt. cable. This fixed the radio.
Apr 04, 2009 | 2001 Dodge Neon
After dead battery, radio won't work. lights...
you need to call your local dealership and they will give you the code to reset you radio.. good luck keith..p.s. remeber to write down the codes, that way if it happens again you will have the code for the radio..
Mar 21, 2009 | 2001 Dodge Intrepid
After dead battery, radio won't work. lights flashing
First I would try to disconnect the negative cable and then reconnect the cable. See if it resets.
Mar 21, 2009 | 2004 Dodge Intrepid
2001 dodge stratus radio
I researched and found I needed to reseat or replace the IOD fuse. In my Dakota this is labled "Interior Lights". By pulling this fuse it allowed the radio to reset and everything came back. Hope it works !
Nov 29, 2008 | 2001 Dodge Dakota
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
