Question about Hayward SAND FILTER, PRO SERIES
Pantera pool filter manual
Pump is leaking
  • 717 Answers
Exactly where is the pump leaking?
If it is leaking between the wet end and the motor then you need a new shaft seal sometimes referred to as a mechanical seal.
You will need to know the brand of your pump when you start searching for the replacement.
Rod
US Parts Center
Posted on May 09, 2013
Please where can I find valve body lower part no. 14965-0013 for my pantera sand filter
So sorry, this part is No longer available.
Has been... Obsoleted, Discontinued, Cancelled all production, Ixnayed, I think you get the picture.
Anyway, your option is to either get a whole new filter assembly with a new valve, or just a new valve...?
This one is the replacement for your filter tank. New and improved. Oooohh.
Take a look, some re plumbing will be required. One draw back : (
No Unions : (
Pentair 261186 Valve Replacement Sta Rite Cristal Flo High Rate Pool and...
Jun 10, 2015 | Pool & Spa
Label positions for pantera P21 sand filter
12:00 Filter.
1:00 Rinse.
3:15 Recirculate.
4:30 Backwash
7:00 Closed
10:30 Waste
Nov 29, 2014 | Pool & Spa
Pantera pool filter model p24
give them model number of filter and multiport you need new multiport gasket (spider gasket)
Feb 09, 2014 | Hayward SAND FILTER, PRO SERIES
Pantera wicor model no. P24
if not able to get seal check hardware store for oring or replace unit
When filtering water it is also leaking through back wash pipe it is a sand filter pantera hi-rate filter with sta-rite water flow control
Is this a multi-port valve offering back wash, no filter, rinse, etc. modes? Have you ever turned it counter clock wise? (Never turn it counter clock wise.)
You will need to remove the top and put a new gasket in the valve.
If it is Push Pull, remove the two screws at the top and pull the assembly out. Remove and replace all "O" rings. Lube with silicone grease for pools and reassemble.
I think this will fis you up.
Thanks for your question today.
Jan 30, 2011 | Sta Rite Pool & Spa
Labels Gone
I also have the same problem with the label on my filter. My pool dealership said I would need deal with Wicor directly. I see two other people with the same problem, however, neither has been responded to. It is VERY difficult to run your pool properly if you don't have your control lever labeled. An immediate response would be greatly appreciated.
Apr 23, 2010 | Wicor Industries Master Plumber Geyser...
My filter and pump will not retain the prime after turning off. Its a pantera sand filter. I can hear an air hissing sound coming from the multi valve port
Either you have a bad spider gasket inside the multiport valve or a bad threaded fitting going into it. Check for leaks around the multiport and backwash line. You'll have to take apart the multiport valve to make sure the spider gasket is not damaged or out of place. Make sure to install the multiport valve in the same position. You can get a replacement gasket at most pool supply stores or online.
Oct 29, 2009 | Hayward Pool Products HAYWARD HEAT PUMP...
Hayward SAND FILTER, PRO SERIES Logo
143 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
