Question about Sony Cyber-shot DSC-W180 Digital Camera
Flash won't work - Sony Cyber-shot DSC-W180 Digital Camera
    Problem Solver:
  • 6 Answers
Some cameras will have a auto flash were it thinks the lighting is to bright so turn it to manual
Posted on May 07, 2013
My nikon D-80's flash won't pop up, yet it also won't go past the flash sync speed of 1/200 while flash is down
Was the camera impacted? Sound like the flash up switch if always closed. Remove battery. If you carefully remove the flash cover (two screw underneath) by first inserting a business card under the flash on the rewind side (yeah, we haven't come up with a better term!) at the back and slide it forward freeing the flash down latch), and do not touch the flash tube as there is 300 + volts across it if it is charged!
Look at the pivot for the flash on the release button side at the back, you will see a small switch. the top part may be under the activating rod - reset it above the rod and it will now work properly
Once again, be careful - there are 300 volts across the flash tube if it is charged
May 06, 2012 | Nikon D80 Digital Camera with 18-135mm...
I have a Stanley IntelliSensor Pro. It's worked fine for a couple of months. Now it won't calibrate - it just flashes quickly calibrating, and alternatively flashing the centre (bullseye) ci
I hate to tell you this as you are an electrician but often it is best to look for the simple solution. My Stanley IntelliSensor Pro was doing the same thing here is the answer:
CHANGE THE BATTERY
Apr 26, 2012 | Cars & Trucks
I know I need to upgrade my flash player and a 11player won't work so how do I find a player number 9 for my cell phone its a android
To upgrade flash player, your mobile should have appropriate hardware to support. If you are trying to upgrade from market,it upgrades. But won't work. So you need to uninstall the upgrade and switch back to the older version of flash. Otherwise upgrade the required hardware for Flash to work.
Thanks,
Mr.Maduraikaran.
Oct 19, 2011 | Jaytronix Android Apps
My camera is several years old. The flash stopped working. I replaced the batteries. Any ideas?
Here are some simple things to try first for a camera that won't take a picture when the shutter button is pressed, or with an inoperative flash. They won't work for every case, but they're worth a try:
Aug 30, 2011 | Canon PowerShot A630 Digital Camera
My Nikon Coolpix s230 flash won't work. It just blinks red in the lower right hand corner. I've tried all the settings and they all won't flash.
If there is a problem with the flash itself or the mainboard connection to the flash it will not charge. If the flash won't charge then it won't go off when you take a picture. The only way to fix the problem is to replace the flash with a good used one and see if that fixes it. If not, then you need to replace the mainboard. Good used parts can usually be found online for cheap; that auction website doesn't pay me to type their name, so I don't, sorry. Hope this helps!
Thomas Drayton
Owner, www.darntoothysam.com
Affordable Digital Camera Repair
Jul 24, 2011 | Nikon COOLPIX S230 Digital Camera
My Pentax Optio M90's Flash has stopped working.. it doesn't matter if I have selected the flash to be on or off it still won't work. Even when setting are set at auto it still won't work...
Hi kerritm,
This indicated that it's time you need to replace your flash , therefore you can get it done via a service center,
The camera's flash has a certain life and you can't expect it to be ok for many years together ,
In unfortunate cases , it stops working due to hard ware failure.
Therefore , Please get the flash replaced and you would be able to use it.
Hope this helps..:)
Jun 19, 2011 | Pentax Optio M90 Digital Camera
I recently bought a Scosche Digital FM Transmitter Model FMTD8/FMTD8R. I loaded my 8GB San-disk flash drive with music but the transmitter won't read it.. doesn't even detect the flash drive being...
wma files won't be read, only mp3 files, in my experience. My 512 mb SD card works, but it won't read my 8 gb SDHC card. I suspect it can't manage SDHC (high capacity) cards. I haven't tested yet, because as it turns out, neither can my computer... I think I'll fall back to a flash drive.
Jun 11, 2011 | GPS
Ixus 430 will take photos when flash is turned off, but will not take photos when flash or redeye is selected
Here are some simple things to try first for a camera that won't take a picture when the shutter button is pressed, or with an inoperative flash. They won't work for every case, but they're worth a try. (Hint, make sure that all the screws around the perimeter of the case are present and firmly seated.)
Jun 01, 2011 | Canon PowerShot S410 / IXUS 430 Digital...
Sony Cyber-shot DSC-W180 Digital Camera Logo
32 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
