Question about HP DeskJet 5550 InkJet Printer
Need to reinstall printer software
Since I tried to put my printer from my desktop in network with my laptop. After that unsuccessfull attempt, both orange and green light were on and I was advised to uninstall the printer hpdeskjet 5550. Now I would like to reinstall it but I don't find my printer installation CD anymore?!! Is there a version availble online? can I have a new sent?
  • Anonymous Nov 25, 2008
    Dis shiit wont work
  • abarbri3 Dec 03, 2008
    yes I need to reinstall the printer program but do not have the disk. What can I do
Since I tried to put my printer from my desktop. After that unsuccessfully attempt, both orange and green light were on and I was advised to uninstall the printer hpdeskjet 5550. Now I would like to reinstall it but I don't find my printer installation CD anymore?!!
Is there a version available online? can I have a new sent?
Posted on Nov 29, 2008
    President:
  • 1,114 Answers
You can download the software from the link below: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=71896&lc=en&cc=us&dlc=en&submit.y=9&submit.x=5&lang=en&cc=us
Posted on Aug 10, 2007
My Dell 3115cn printer will not connect to the network (it still works on USB cable), hard to believe it's broken, so can the printer system be reset?
Try turning off the printer and disconnecting power plug from wall. Hold power on button for about a minute. Then replug unit and turn power on - it should then attempt to hook up to your existing network.
If no go, try reinstalling the software that initially came with printer and was used to set up the network
Jan 10, 2017 | Dell Office Equipment & Supplies
I have an Acer Apire 3680 - 2576 laptop, have difficulty installing All in-one Office jet 6210 series printer, during installation, the printer is detected but connection breaks after detection leading to...
Sounds like your cable is bad or the printer itself is malfunctioning.You may be able to uninstall it and find a more updated/better driver then reinstall it.Use a registry cleaning software first such as CCCleaner etc.to clear references in the registry and to remove any temporary files used with your previous attempts at the install.Restart you machine then try the reinstall.If after your attempt to reinstall fails again,you should consider (malfunctioning port,bad connection cable or the printer itself is defective.Hope this helps........Lee
Nov 05, 2011 | Acer Aspire 3680 Laptop
I have a Lexmark S405 that was installed on my network, since getting a new router the printer will now not connect to either my desktop or laptop, I have tried reinstalling software but neither computer...
Try to reset your printer's wireless network adapter. From the printer operator panel, press the Setup button > Network Setup > Reset Network Adapter to Defaults. The WiFi light on your printer will momentarily turn off then on to a solid orange light. You may then run the printer wireless setup utility on your computer to configure the printer for wireless connection.
Sep 06, 2011 | Lexmark Interpret S405 Wireless All-in-One...
HP OfficeJet 7310 - My print jobs get stuck in the que and never print. In "devices and printers" it says "printer offline". It is a network printer, to which all ethernet connected...
Solution 1 :
Go to START MENU
Choose RUN
Type the letter "cmd"
Type the word "net stop spooler"
Exit
Go to C drive
Choose to Windows Folder
Click show content
Choose system32 folder
Choose spool folder
Choose printer
And delete all printing jobs pending
Again go back to CMD window and type the word "net start spooler"
Restart your computer also turn off your printer and switch it on.
It will work fine right now
I hope it helps you
Solution 2.
Check the printer driver using device manage and maybe it is corrupted. Try test page if necessary.
Solution 3.
Reinstall the printer software
Solution 4.
Check the network switch hub and maybe some loose connection.
Solution 5.
Solution 6.
Check the configuration of the printer is somethings not correct.
Dec 11, 2010 | HP OfficeJet 7310 All-In-One InkJet...
I JUST BOUGHT MY BLACKBERRY CURVE 8330 TODAY. I PUT A PASSWORD ON IT. I CONNECTED IT TO THE COMPUTER. I HAD 3 TIMES TO PUT IN MY PASSWORD. I DID IT 3 TIMES ( I KNOW FOR A FACT IT WAS RIGHT ) AND FOR SOME...
start Blackberry desktop software and then connect the phone to the computer..
Blackberry desktop software will detect it..
And after Blackberry desktop software has detected your phone you can use it to upgrade / restore your phone..
Oct 19, 2010 | Cell Phones
How do I set up to print wirelessly with a Canon MP 620 Printer?
Hi
Thank you for your query
To share your printer you will need to do the following
1) On your desktop Click on Start>Control Panel>Printers and faxes
2) Right click on the printer in question and click on sharing
3) Put a dot in 'share this printer' and give it a name
This has now made your printer a shared one on the network
On your Laptops click on Start>Control Panel>Printers and faxes
2) Click on Add printer
3) On the resulting screen put a dot in the option 'A network printer, or printer attached to another computer'
4) Then follow through and the printer you named on your network
This will add the printer to your laptop and will allow you to print
Do the same for the other laptop
I hope this has been useful
Mar 12, 2010 | Canon PIXMA MP620 All-In-One InkJet...
Need to reinstall my printer software. how do i do that? thanks.
if you would reinstall your printer software then you should have cd installer for it.if you dont have then that another problem but we could solve that by looking at the website for its software installer.
May 26, 2008 | HP Office Equipment & Supplies
Help. I have a Belkin Wireless G Router safely installed and functioning with a laptop running XP. However, I also have a Belkin Wireless G USB Network adapter that was safely running a desktop with...
is the wireless network adapter driver installed on your pc? if its properly installed you have to reconfigure the wireless network adapter to your belkin router.
wireless usb adapter should obtain the ip address from your belkin router
Apr 17, 2008 | Computers & Internet
Wireless laptop not printing
Indeed, you don't need the print server. Since your HP 6310 already has an integrated network port, you may setup and use it on your laptop the same way you do with your desktop. If you can browse the Internet wirelessly with your laptop, you should also be able to print.
Jan 20, 2008 | D-Link Air Plus DP-G310 (dpg-310) Print...
HP DeskJet 5550 InkJet Printer Logo
131 people viewed this question
Clive
Clive
