Question about Exercise & Fitness
ERROR TREADMILLS STEELFLEX XT3300 - Exercise & Fitness
3 Suggested Answers
SOURCE: I have a steelflex XT-3600
1. If E6 or E7 appears during power on or during operation, turn off and restart
treadmill. If E6 or E7 still appears on the display, turn off and restart treadmill again.
If this problem persists, go to next step.
2. If the treadmill stops at higher level, press "STOP" & "DOWN" buttons at the same
time for 3-5 seconds to reset the elevation motor to bring the unit down to zero
position. Or else, press "STOP" & "UP" buttons at the same time for 3-5 seconds to
bring the unit up to zero position.
3. Turn off and restart the treadmill, the unit should show at 0% elevation and press
Quick start to begin.
Posted on Feb 25, 2011
ercupa190
  • 12223 Answers
SOURCE: We have a 2 year old Endurance XT3300 treadmill that is malfunctioning. I cannot find any customer service contact information. Nor can I find anyone who can repair it in the Delaware area. Can you
http://www.youtube.com/watch?v=yX_0vRPdMfU&feature=related
Please go to that video: the page web:www.unitedassemblers.com
they provide service in your area, see the Video and after go to the web page, and contact for service.
sincerely.
Posted on Nov 16, 2011
How do i fix a lifegear treadmill 97520?
Try below:
ERROR CODE
DESCRIPTION
E1
Speed error (The treadmill running speed is 3.2 kph faster than the displayed
speed). The treadmill will stop immediately when the console detects this error.
E2
Speed error (The treadmill running speed is 3.2 kph slower than the displayed
speed). The treadmill will stop 16 seconds later after the console detects this
error.
Troubleshooting / Resetting error codes
In the rare event of the treadmill displaying an error code ("E" followed by a number), simply reset
the computer by:
1. Step off the treadmill. Ensure that you are clear of the running belt.
2. Turn the treadmill off at the master power switch located near the motor housing.
WARNING: Ensure nothing is positioned near or under running belt which may possibly block
it's normal operation.
3. Turn the treadmill on at the master power switch.
4. Ensure that the Safety Tether Key is securely and properly installed onto the console or just
reinstalling the Safety Tether Key can also reset the display.
If the above does not clear the error code, please contact the nearest Dealer/Service Center
LifeGear 97320 Owner Manual Page 17
May 22, 2016 | Exercise & Fitness
What's the problem of error 1 on my york t520i treadmill that stopped working, I need your help please.
Error 1: Speed sensor error Turn the power switch off and on again to reset the treadmill. If the treadmill returns to normal operation, you may continue to use the treadmill. If treadmill does not return to normal operation, then call the dealer for advice.
ERROR 1 CODE This is a safety feature that can stop the treadmill from functioning. This error can occur because the computer is not receiving the correct information from the speed sensor located near the motor. As a precaution the computer stops the treadmill until it begins to receive the correct feedback. By performing a few simple checks, the error can be cleared quickly and easily, and the treadmill can be ready for use. The treadmill does not move and displays "ERROR 1" Switch off the treadmill at the mains, and then switch it on again. If "ERROR 1" still shows switch off and push the running mat round (1 cycle) using your feet. Then switch back on. If "ERROR 1" still shows, then UNPLUG from the mains and check all of the wire connections made during the assembly. (SEE BOLD PRINT) UNPLUG If the treadmill still does not move, then please contact the helpdesk. Doing this may reset the program error, and the treadmill will be ready to use. This should reset the sensor, and the treadmill will be ready to use. Once the cables have been checked, turn on the treadmill again. This should eradicate the problem. 1. 2. 3. When assembling, there are several cables that need to be connected. It is very common for these cables to look like they are connected when they are in fact not fully connected. Make sure that these cables are connected as tightly as possible. The connections may have come apart whilst assembling the treadmill. here is a link to your treadmill web site http://www.yorkfitness.com.au/uploaded/pdf_71T520i%20Treadmill_5562.pdf
Mar 02, 2015 | York Exercise & Fitness
Endurance xt3300
follow the steps and fix it. God bless you. You have 2 alternatives with this error.
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Jun 19, 2013 | Exercise & Fitness
Steelflex xt2700 won't start
adjust the REED switch, see the diagram , test for open or faulty. Clean it and tigh the connector very well.
2) replace the old batteries by new ones, and clean very well the contacats batteries.
3) tight the ribbon cables for keypads, and clean it, and tight the connector very well.
Jan 20, 2013 | Exercise & Fitness
sincerely.
Nov 16, 2011 | Exercise & Fitness
My xt2700 steelflex treadmill shows err1 code what is the problem amnd how do i rectify it
I an having a STEELFLEX 2700 Treadmill.
In the ELEVATION display its showing "Err7" and the running belt is elevated.Pleas kindly help me to rectify this problem.
My user manual also lost,if someone know the online manual please share the link.
Dilantha.
Mar 10, 2011 | Sport & Outdoor - Others
Exercise & Fitness Logo
35 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
