Question about Troy-Bilt Tb90bc 17-inch 31cc 2-cycle Gas Powered Straight Shaft
Troy bilt weed eater
Pull string broke off, need to replace?
    New Friend:
I have a troy built 2 cycle pro-line tb90bc spring assist trimer.
its getting fuel and it wouldn't start I took out the spark plug and it was wet with fuel. pls fwd any info to
Posted on Oct 20, 2016
How to put a new battery cable on my troy built weed eater model # tb22ec?
I don't think this item has a battery
Troy Bilt TB22EC 41ADT22C966 25cc 2 Cycle Curved Shaft Trimmer Parts
TB22 EC Curved Shaft String Trimmer by Troy-Bilt EC Curved Shaft String Trimmer. 25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design Model No. 41CDZ22C766 .
Jul 31, 2017 | Troy Garden
Replace duel string trimmer line
Change the line on Troy Bilt 4cycle TB525EC weed eater
Oct 16, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
The head will not spin on Troy Built weed eatter
sounds like your flex cable has taken a trip south. Pull the shaft off the head and take a look at the flex cable. If flex cable is ok, they your clutch is defective.
May 29, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Weed eater runs slower
Your air filter may be plugged, your pug may be fouled, or your carb may be gummed up.
Sep 10, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Pull string for Weed Eater Featherlite Plus came out
If you have the starter spool out (the one the rope goes in)...Here is what to do. Take the starter spool and change the rope out putting it back exactly as it was. Leave the rope hanging. Hold the spool and set it down on the rewind spring. Turn the spool on the rewind spring until you feel it is tight enough. While turning, hold the rope in the little slot in the spool so it can go around without hanging up. Once it is tight, get the rope in line with the spool opening and SLOWLY let the rope rewind. Put on the handle and put the unit back together.Good luck...Lee
Sep 06, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Troy built weed eater won't feed line
Check the size of the line,(OD), make sure you are using the correct size, sometimes cheap line will be problematic, also, you said you are re-stringing it, try a new batch of string, the old string inside the hub can get chaffed and will stick to itself...
Aug 22, 2009 | Troy Bilt Tb70ss Gas Trimmer
Tryingto replace my troy built weed eater's head
Replacement head can be purchased from amazon, here Amazon com troy built head. I hope this helped you. Have a nice day. Vince
Jul 12, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
My Troy Built weed eater wont keep string going.
troy built is pure trash ill never waste money on any of thier trash agin i have a weed eater 5 months old it wont even crank pure china trash
May 09, 2009 | Troy Bilt Tb70ss Gas Trimmer
I have a Troy Bilt TBP6040 XP 4 cycle weed eater with the spring assist starting. The pull cord broke and I am trying to replace it but I can't seem to get the cord to go all the way back in. I need help....
I just had this same issue. I found out that you have to take the cord out of the handle then put the spool in. You then rotate the spool back in and align the spool with the spring and fish out the cord which will put a small amout of tension on it. You keep the tension on it and put the handle back on.
Mark J
Apr 16, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Weed eater does not start
I had a similar problem with my troy-bilt weedeater. I tried replacing the sparkplug, replaced the fuel filter and etc. It still would not start. I looked at the troubleshooting guide in the owner's manual and it listed a possible cause as a clogged spark arrestor. I cleaned out the spark arrestor by taking it off and cleaning it with a wire brush. Now it runs like brand new again. I hope this helps.
Apr 08, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Troy-Bilt Tb90bc 17-inch 31cc 2-cycle Gas Powered Straight Shaft Logo
188 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
