Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
What is the belt size for a craftsmen kohler model cv16s.43513
How do I adjust the governor on a 2009 Kohler Courage 20 HP engine?
loosen the pinch nut for the gov arm. have throttle at full. rotate the gov shaft in the same direction that the arm is for full throttle and tighten the pinch bolt.
Jun 06, 2016 | Garden
What's the wiring diagram for a craftsmen Kohler pro 17.5hp riding mower model number CV491S?
Not sure which charging system you have, so I have included both diagrams.
Feb 01, 2016 | Garden
How to adjust the valves on a Kohler command 13 CV16s
you need a valve job done and valves replaced you have to take in maybe carb rebuilt to valve job 100.00 per cylinder carb rebuilt 80.00
Sep 14, 2014 | Garden
I have a kohler model cv16s in a lawn tractor, sears model 944.608961. The problem is that the ignition is intermittent. I have replaced the spark plug and turned the engine over, plug out, it may spark...
weak spark could be a ground problem or it could be module itself check the wires that go to the module for nicks or cuts if none exist I would lean more toward the ignition module
Oct 19, 2012 | Garden
How do I connect wiring on Kohler CV16S motor to craftsman mower that had a B&S YBSXS.7242VFmotor?
You need to know which ones are the kill wire, charge wire and starting wire for both side of the harness and make you own connector.
Dec 06, 2017 | Garden
Will any other engine fit a craftsmen 26 hp lawn tractor other than the kohler
Yes there are 2 other options.
Briggs and Stratton, and Onan.
Here is the information. You will need to have your output shaft size.
http://www.smallenginewarehouse.com/
Feb 06, 2010 | Craftsman 26 Hp 54" Deck Yard Tractor
Where can i fine manual for engine replacement
TO REMOVE THE PULLEY FROM THE CRANKSHAFT END:
Remove the blade belt and, if needed, the deck to give yourself more room to work. Apply your brake pedal and lock it down, this will relieve the tension on the ground drive belt.
If you have an electric blade clutch, find the plug where the wire goes over from the clutch to the frame and unplug it.(Electric clutch will be heavy when unbolted so be ready for it.)
In the center of the pulley or blade clutch you will find a long bolt (most likely a 5/8 head on it) You may need a deep socket to reach it depending upon the type of stack pulley on it, remove this bolt and the pulley should slide freely on the crankshaft. slide it downward and slip off the belt on the top of the pulley then remove the pulley the rest of the way
Oct 05, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
50 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
