Question about Directed Dei Valet 561r Remote Start/Keyless Entry
Bypass When I step on break car shuts off. Thanks
    New Friend:
What are you trying to figure out what to do?
Posted on Feb 03, 2014
Truck will not start anti theft will not shut off
The security light illuminates when that signal gets broken, or not seen at all. When the communication breaks, the car misinterprets this as an attempt at theft and goes into antitheft mode. (like it thinks it's being hot wired) The car shuts down because it is not getting that signal from YOUR specific key. This is why the security light turns on and shuts down your vehicle. It will either turn off the starter, or the fuel injectors. The vehicle may run for 2-3 seconds before shutting down. This link explains it pretty well.
http://www.diy-gm-security.com/
Do It Yourself GM Security bypass
Aug 07, 2016 | 1999 GMC Jimmy
WHY CAN'T I SHIFT MY 1997 GRAND MARQUIS OUT OF PARK AND INTO ANY GEAR?
You may have a faulty Break-light switch. If the switch is bad, then it will behave as if you have no breaks afa the shift-lever is concerned.
Sep 07, 2012 | 1997 Mercury Grand Marquis
I am about to install my boss bv8962 unit into my vehicle but I want the parking break safety feature bypassed. What do I do differently during installation so that my passengers will be able to watch tv...
Yes, you can bypass parking break feature by connecting the corresponding wire of BV8962 to ground, also you could add a 3 pin toggle switch to get a normal and bypass mode switch, this can be wired of this way, the common pin of toggle switch to your video unit, at the other pin, it could be connected the parking break wire (normal mode) and the remaining one to ground (bypass mode).
Feb 26, 2011 | BOSS AUDIO SYSTEMS BV8962 Car Video Player
Clarion nx700 parking break bypass
Wrong. To bypass the lockout feature so you can see the DVD play anytime - you need to toggle the green wire away from ground (from Low to High - i.e. momentary switch) so the radio sees the rising edge of the 12Vdc signal. The green wire is normally high and is tied low. When you put the parking break on - it opens the loop.
A switch will trigger the Opto Isolator inside the head and bypass the lock out feature. This works fine - or you can spend the $25 on the bypass module - that does the same thing - but works as an electronic toggle ~ based off the remote wire and an internal relay in the module. The module will toggle the green wire every time the radio powers up.
Jul 01, 2010 | Clarion NX700 Car Video Player
How do I bypass the brake switch on the uv8 using just the face?
You can doing using a toggle switch inline on the brake wire . If you have the remote then there is a sequence code you can put in which consists of ,
ok this is very easy
1. have your player on radio (am/fm)
2. go to settings (must have a remote)
3. click the language button (next step is where you need the remote)
4. type in the following numbers 543210 (make sure you hear the beep)
5. a new menu appers after the code (hard-drive)
6. click on the break-bypass button
7. turn on the bypass
8. click the x on the bottom of screen
9. your all set now you have your player unlocked so you dont need the parking break
10. REMEMBER SAFETY IS FIRST PLEASE BE VERY CAREFUL WHEN USING THIS UNIT PAY ATTENTION TO THE ROAD AND NOT THE PLAYER YOUR LIFE IS MORE IMPORTANT THEN THIS DEVICE
Jul 06, 2009 | Car Audio & Video
Bypassing E-Break
Just connect the emergency brake wire to earth (vehicle body)
Jun 17, 2009 | Jensen VM9410 Car DVD Player
Kenwood DDX514, bypassing the parking break wire for video
Just hook up the parking brake safety switch from the unit to ground. That will do the trick. Hope this helps
May 23, 2009 | Kenwood DNX7100 Car Video Player
I need help to bypass the brake with my Dual XDVD9101
did you try connecting the bypass wire to the ground wire?
Apr 22, 2009 | Car Audio & Video
How do i use my tv without using my parking break
You either need to run a toggle switch or get the bypass code and follow the steps to enter it with your remote..
Apr 15, 2009 | Phase Linear UDV9010 Car DVD Player
Bypass for N2
there are to steps, very simple...
solder two points under the silver sticker on the bottom of the head unit (pay a pro! don't mess up your deck!) then you ground the light green parking brake wire (attach it to the black ground wire coming out if the same harness) this will give you "full function". i have this unit and have the upgrade, it works.
May 08, 2008 | Pioneer AVIC-N2 Car DVD Player
Directed Dei Valet 561r Remote Start/Keyless Entry Logo
Top Directed Car Audio & Video Experts
Colin Stickland
Colin Stickland
Libran Moreno
Are you a Directed Car Audio and Video Expert? Answer questions, earn points and help others
