Question about Cuisinart TOB-40 Stainless Steel Custom Classic Toaster Oven Broiler
Cost replace heating element
Where to fine a replacement
The heating element on my Hamilton Beach toaster oven 31134 has a hole in the covering and smells when I use it. Is that safe? Can I replace the heating element?
The element is failing and while it will probably not catch fire, it is better to be safe than sorry and just replace it. Does not look like a replacement element is offered. Sears has this toaster oven for $22.49 + $6.99 shipping.
Dec 10, 2016 | Hamilton Beach Toaster Ovens
What part needs to be replaced when the lcd and controls work but no heat?
Most likely suspects in this scenario would be the heating element or the temperature sensing rod. Not sure what the sensing rod setup on this oven looks like, but it is generally a few inches long, similar diameter to a charging cable for your phone, attached to the back wall of the oven and sticking out directly toward the oven door. If it goes bad, the oven may think it has reached the set temperature and turn off, but generally, it is the opposite (it allows the oven to get too hot). My guess is heating element, but the sensor generally costs a lot less to replace, though maybe not with a small toaster oven. Good luck!
Jul 18, 2014 | Breville BOV800XL 1800 Watts Toaster Oven...
West Bend MC38ACL convection oven
Yes normally a fuse which they replace for it to heat again generally goes when over heated especially if not in a air flow area will cost about $100 - $120 to fix local electrian
Apr 06, 2014 | Toastmaster TLWTOB6 Lightwave Toaster Oven...
My black & decker tro964 is not heating
That may sound like a stupid question, but is it plugged in?
Have you tried to plug in the toaster on a different power outlet?
If there is a ground fault switch where the toaster is plugged in (that's those outlets which have 2 buttons on the front, one labeld "Test" the other usually labeled "Reset") unplug the toaster and push the "Reset" button and try the toaster again. To test, if the power outlet, were the toaster is usually plugged in, is working, try a hair dryer or any other device on that outlet.
Its most likely cheaper to replace the whole toaster than to replace the heating elements, for about 40 $ since that's the price of your toaster on some websites.
Jan 06, 2014 | Black & Decker TRO964 Toaster Oven
Top filament has burned out; does it pay to repair toaster oven or shouldit be replaced by a newer model??? We rarely use the oven and mostly use the appliance for toast. A replacement would cost less...
Chances are very slim your toaster oven is repairable anyway if the heating element burns out. A replacement part is not available, and there's no way to reliably repair a break. Even if it could be fixed, the low replacement cost makes it uneconomical. Parts and labor would run close to $50, maybe even exceed that price.
Unless you can find a part and do the repair yourself, small appliances today are throw-away items.
Jun 20, 2011 | Black & Decker TRO400 Toast-R-Oven Toaster...
This toaster no longer toasts food evenly, it takes twice as long, it appears that the broiling coil element may not be heating...Can these elements be replaced?
the elements can be replace, BUT, it is just not cost effective. you can buy a new toaster for less the the cost of repair.
Jan 03, 2011 | Cuisinart Toaster Ovens
Heating units bottom stopped working. Then the top heating bars stopped working. It's a radiant oven.
it is several prosibilites for your problem:
1) the wire of the oven is damaged;
2) the thermostat is decalibrated or damaged;
3) one or more heating element is intrerupted or burned.
solution's:
1) check the wire an replace or repair where is posible whit similar heat resistant wire;
2) replace the thermostat whit similar one;
3) replace the heating element
Feb 21, 2010 | Oster 6239 Toaster Oven with Convection...
Quartz heating elements problem in Krups toaster oven
you can touch the element but be carefull the glass is thin .... so scrape it and do what you can . THEN USE A COTTON BALL AND ALCOHOL and clean the element that will get rid of the oil you left behind ,you will be fine ......Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
Mar 02, 2009 | Krups FBC2 1600 Watts Toaster Oven with...
Toaster does not work!!!
I investigated further (took it apart again to satisfy my curiosity) and it appears that one of the top heating elements (the front one) is open (burnt out). I cannot see an easy way to replace it (contacts are spot welded) and I can't find a place to buy the element. If I could it probably won't be worth it since a new oven costs $25 at Target (B&D TR0490W). Too bad since the oven looks like new. I assume the upper elements burn out more frequently because heat rises from the lower elements and adds extra heat at the top.
Jul 02, 2008 | Black & Decker TRO360 Toast-R-Oven Toaster...
Cuisinart TOB-40 Stainless Steel Custom Classic Toaster Oven Broiler Logo
Top Cuisinart Toaster Ovens Experts
D. E. Hev
Lawrence Oravetz
J.D. Browning
J.D. Browning
Are you a Cuisinart Toaster Oven Expert? Answer questions, earn points and help others
