Question about Frigidaire FAM187S2A Air Conditioner
Fan stays on all the time even if compressor is not on?
The A/C will not turn off on my 2006 Kia Sedona EX. Air blows cold, but no matter where you set the control knobs for A/C system or fan controls the A/C stays on. Even with knob in the OFF position.
Looking under the hood in engine compartment with engine running A/C off , the compressor is engaged ? If so , the A/C compressor clutch relay is stuck closed energizing the compressor clutch all the time . Now if your talking about the blower inside the car running all the time , air blowing out of the vents . The A/C isn't engaged . Could be blower motor relay stuck or the control module is bad .
Jun 21, 2016 | 2006 Kia Sedona
Both aux fans remain on from cold startup. is it more likely the radiator temp switch than the fan relay?
fan relay more than likely, but I think think it would stay on all the time even with key off, could be wrong tho. sounds to me like you have your air condition on, or heater set to defrost as defrost basically runs the air conditioning compressor and cooling fans when defrost is on.
Dec 09, 2013 | 1997 Jaguar XJ6
True gdm12 evap fan runs all the time evev with the compressor off wiring seems not to have been touched
evap fans will run continuiously on this unit,it is normal. fans stay on to circuilate air evenly inside unit.
Sep 19, 2011 | True 72 cu. ft. / 2039 liter Commercial...
RV Air conditioning not working properly
IF YOU HAVE A ENERGY SAVER SETTING ON TSTAT SET TO OFF THAT WILL KEEP FAN ON WHEN COMPRESSOR IS OFF. REMOVE LITTLE THERMOSTAT WIRE IN FRONT OF COIL WHERE FILTER IS , BE CARFUL NOT TO BEND IT IN HALF IT CONTAINS GAS IN IT MOVE IT SLOW ,ITS ABOUT COAT HANGER THIN OR HAS A BULB AT END . CARFULLY STICK IN WARM WATER GLASS TO SIMULATE HOT TEMP. SEE IF IT STAYS ON. NOTE BULB HAS NO WIRES ON PROBE. MOST ARE ALLUM. OR COPPER. IF YOU ARE NOT SURE WHAT YOU ARE STICKING IN WATER THAN HOLD BULB IN YOUR FIST CLOSED TO HEAT UP BULB IT WILL WORK THE SAME.
Apr 18, 2010 | Dometic Rooftop RV Air Conditioner
Compressor will not stay on
do you know if the fans are running constantly? and if so when the compressor comes on it trips out and the fan remains constant? i would like to know the running amps are they correct.
Jun 08, 2009 | Heating & Cooling
Out air compressor fan runs for about five minutes then the fan stops turning unit is about 5yrs old
if the compressor stays on for a short time after the fan stops most likly the fan motor has problems could be capactor or bearings dan
Jul 17, 2008 | Heating & Cooling
REPLACE COOLING FAN ASM
well if your condenser fan shot out, i'd advise that you shouldn't use the unit but all your doing buy putting the fan is doing the job of the defective one. but your causing more stress to the compressor and system, your forcing it to "work overtime" so technically you are cutting the compressor's life
May 03, 2008 | Samsung RS2630SH Side by Side Refrigerator
Frigidaire FAM187S2A Air Conditioner Logo
20 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
