Question about Audiovox FPE3206 32 in. LCD Television
TV won't turn on. Is there a reset button?
TV would not turn on intermittently. Now, won't turn on at all. We use a cable provider, but, cable is working. Is there something we can do short of calling a repairman? thx
Digix bd 500. worked fine for a couple Weeks. now it froze up and won't turn on. the power lite is dimly blinking. but still won't turn on. is there a way to reset without turning on? I have check...
1) test the outlet wall for 120vac 2) test the power cord for open 3) test the power switch tv for defective 4) power supply inside faulty repair.
God bless you
Jul 25, 2013 | Televison & Video
Toshiba 32av615db tv - keeps scrolling channels
On the back of the TV, where the main board is (the one with many AV inputs to it) there are several cables going into it.
Find the one that leads to the buttons on the TV - it won't be too hard to trace - and after turning on the TV disconnect that cable.
Or, if the cables for the buttons and the front LED and IR sensor are separate (sometimes they are) you disconnect the one for the buttons and then turn the TV on with the remote.
Either way, see if the problem persists with the buttons panel disconnected.
if it does then the problem is in the main board and likely you'll want it replaced. The way they make them these days it's really cheaper to replace the whole thing than to look for a problem among components the largest of which is about a millimeter long.
if the problem is in the button/cable connector...you'll probably find it easy. Often it's because that same cable has been trapped between the front and back covers and broken or shorted by the friction and pressure.
Hope this helps....would appreciate a review on Google if it does!
bobby
www.coppelltvrepair.com
Oct 08, 2012 | Toshiba 32AV615DB 32-Inch Lcd Tv Dvb-t...
Sound won't work
If your TV has a picture but no sound, start by checking the obvious such as whether the mute button is on or whether the volume has been turned all the way down.
Next check your cable connections and make sure everything is plugged in tightly.
Change channels to make sure that it's not a technical difficulty with your TV service provider or TV station. Call your service provider to see if they're experiencing issues with their audio.
Try reconnecting the HDMI cable after you turn off the TV.
Make sure your remote is on the correct input, and see if you have sound while playing a DVD or video game.
For a simple troubleshooting checklist, see No sound on TV and get more details on some simple fixes for this problem. I hope this helps!
Sep 13, 2012 | Mitsubishi WD-73735 Television
I put in my mw2 disk and it won't load and goes
Hello
If you took your PlayStation 3 to a friend's house and hooked it up to his HDTV with an HDMI cable, you may have been in for a surprise when you got home to your older television. If you didn't change the video output back to the regular AV cable, your system will still output video to a port you now can't use.
Connect your PlayStation 3 to your television with the composite yellow, white and red AV cables and plug the system in to the power outlet. You can also use a component cable if you own one and your TV supports it. If you already turned the system on and see no video, turn it back off with the power button.
Press and hold the power button until you hear two beeps after about five seconds. The system will reset to SD output on the AV cable and proceed to boot normally.
Press the "PS" button on a controller to turn it on and log in to your user account. The reset process removes all video settings, so you will need to choose your options again.
Select the "Settings" menu and pick "Display Settings" and then "Video Output Settings."
Proceed through the settings to select TV type and resolution. If using the composite AV cable included with the system, settings should be correct automatically after resetting, but verify them to be sure. If you're switching to a component cable on an HDTV, you will have to reselect the compatible HD resolutions of your television.
Save the settings and continue using your system as normal.
Sep 26, 2011 | Sony Video Game Consoles & Games
My brother's PS3 on my non-HD tv. We tried connecting and getting different S-video cables but it still won't show up anything. We know the input channel is correct, it just won't show. My...
Yes the display settings need to be reset since he had HDTV and you don't. I do this by simply having the PS off then press power button and hold it for 5 seconds.
Jun 09, 2011 | Sony Playstation 3 (PS3) Console
Hi. My playstation won't work at all. When i try to turn it on, it goes on sometimes on the tv, or else, it says that i don't have connection from the PS3 to my tv.. I Checked my HDMI, and...
If the screen is just black and the PS3 doesn't turn itself off, then it could just be that the video settings don't go out through the correct output. This will reset the video output:
  • Hold the power button for 5-10 seconds until you hear two beeps; then let go
May 31, 2011 | Sony Playstation 3 (PS3) Console
Hi our tv just won't turn on any ideas? We have pluged it into another power source and checked the cable . the cable is fine. thanks
If it does not turn on then it is usually due to a component level failure on one of the boards. Does the LED at the front blink or just stay on? Does it make a clicking noise like its trying to turn on when you press the power button on your remote? Also please let me know the make and model of the tv. Please provide this info so that I can offer you insights into the cause of the problem and how to fix it.
Sai.
May 28, 2011 | Televison & Video
My 42 inch olevia 242fhd-t11 tv just shut off and will not come back on.. The blue led light will not come on either... Also was having intermittent sound issues for the last couple of days prior to it not...
I just repaired this identical problem on the same model TV. You have a bad power supply (also known as an SMPS). The board is model FSP271-4F02, and is about $75. Unlike the main board for this TV, you can find the power board relatively easily. Try shopjimmy, for example. Replacing the board isn't too difficult if you have a reasonable mechanical ability, have some tools, and are careful.
Jun 12, 2010 | Olevia LT42HVi 42 in. LCD Television
Vizio LCD 37 Inch Turns Off Randomly
I had a similar problem with my 32 inch plasma tv. I called vizio's
1 800 number and the guy said to unplug the tv from the wall and hold down the power button for a minute and then plug the tv back in outlet and turn on. And it works I guess from what I understood from his heavy accent was that the tv retains power and this resets it somehow. hope that was helpfull!!
Jan 15, 2008 | Televison & Video
Audiovox FPE3206 32 in. LCD Television Logo
37 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
