Question about Sony Ericsson W700i Cellular Phone
Water damage here was a heavy rain outside.i put my mobile phone in my bag but unfortunately rain water goes into my bag and my mobile stopped working. when i take out it from my bag there is lot of water get inside mobile phone and my mobile's flash light (above camera) blinking very fastly i immediately take out the battery. and put my cellphone above the monitor (of pc) for drying. after 5 hour when all water evaporated. I just insert the battery, but the phone don't power on and began to vibrating, i again take out the battery and put it in my desk for fortnight, yesterday i again insert battery and press power key, but nothing happened although vibration has been stopped. I then take it to the service centre and they tell that your warranty has been void due to liquid damage and give me estimate around 6500/- Rs. (135/- US DOLLAR) which is just 40$ less than phone's price, i refused to do the service and take it out. So please is there any solution to my phone WORKS.
  • Anonymous Dec 26, 2008
    mobile inside water
  • 27 Answers
If u have hotair gun so make hit treetment , use liquied flux and at first heat cobba ic thane check if problem will stil there heat flash and cpu
Posted on Aug 11, 2007
  • Raju Adhav
    Raju Adhav Aug 11, 2007
    tell me your country what kind of material(instrument) u r using to repair mobile handset
Samsung c3262 white display
To dry it out, put it into a bag of rice for about 3 days. Don't use a hair dryer because it could damage soldered parts or other sensitive pieces. Next time, put your mobile into a small plastic zip-lock sandwich bag or similar. You can still receive calls and make them, and keep the phone dry.
Jan 04, 2014 | Cell Phones
Tip
I take an old pair of hose (womens), buy some loose tobacco, cut the hose to...
I take an old pair of hose (womens), buy some loose tobacco, cut the hose to about 1 foot, 30cm long making sure there are no holes in the toe or elsewhere, put a 1/4 cup or so of tobacco into the sock, tie a knot so the tobacco stays put. Then open the bonnet of the car, find the windshield wiper water tank, drop the end of the sock into the solution or plain water, make sure the upper end of the sock is securely fastened to something outside the tank so you won't loose the bag you created and you'll be amazed at how clean the windscreen will be next time you use the wipers after squirting the windshield as usual.
An alternative would be to boil the sock in water like tea, but don't drink it! after 10 minutes of boiling, let it cool, squeeze the bag so all the "tobacco tea" goes into the pot. When cooled, pour it into your windscreen water tank. As you wash your windscreen with the wipers going the squirted liquid will clean the glass and make rain water sheet off rather than leave droplets. You can actually drive the car safely because you can see as if no rain was falling.
If your wipers stop working all together and you can't see to drive, take a sock, as the one I described above, get it wet and wipe the windscreen with it. The rain will then sheet off the glass as if there was no rain at all. no drops can form. The tobacco breaks the surface tension. Want proof? Take a glass of water, fill it to the top just short of spilling over. You'll notice the water actually rises above the edge drop one grain of tobacco or black pepper and the glass will immediately spill the water out of the top of the glass. I keep such a bag in a plastic bag under my seat. You never know when you might need it. You can use it many times before needing change the tobacco.
If you just want some cheap glass cleaner, mix a 50% solution of white vinegar and pour it in your window wiper water tank. It will keep your windscreen nice and clean; also streak free.
on Jun 14, 2010 | Kitchen Appliances - Others
My canon rebel xt in totally inop due to water intrusion, any trouble shooting ideas?
I've seen a fantastic solution for mobile phones dropped in water and the same principal applies... put the camera in a zip lock bag with uncooked rice (lens cap on to prevent scratching. The rice draws out the moisture... it does take a while however, maybe a couple of weeks. Anyway, worth a shot if you're short on cash.
Jul 30, 2012 | Canon Rebel XT / EOS 350D Digital Camera
I want Nokia 1600 Cellular Phone Water damage logged
If your cell phone is damaged by water follow these instruction
1. Remove The Battery Immediately
2.clean your battery with a towel or paper and let it dry
3.Use air to force out the water from your mobile phone
4.else you can put your phone in a bag or dry rice over night so that in morning the water will be absorbed by the rice from the cell phone
5.now put the battery in the cell phone and try to switch it on
6.There are chances that the mobile get turned on.sometimes if the circuit is entirely damaged its impossible to recover..
I hope this will help you.if this helps you rate this answer
thanks and regards
Lalith
Mar 14, 2011 | Nokia Cell Phones
Yes my has been outside for a couple of months and has gotten rained on. The Problem is when I go to start it it wont go and if i pull up the release so i can push it one wheel goes one way while the other...
Hi
It Sounds like your Tracking is out also when a Scooter is left outside in bad Weather the Pot Assembly Unit Needs to be Replaced as they are To be kept cover at all times as it is an Electronic Pot Meter,and Moisture is not good for this Pot.
Gerry.
Aug 11, 2010 | Electric Mobility Mobility Electric Power...
Shampoo dripped into cell phone
Unfortunately, water damage is a hardware issue and can't really be solved unless you replace your phone. Water damage is SOMETIMES covered in warranty so be sure to check with Blackberry's customer support.
Jul 24, 2009 | RIM BlackBerry Bold 9000 Smartphone
I cant get my phone to turn on. The g1 tmobile screen comes on then it turns off and on over and over again. It was raining real hard and i think water got in it? can you help?
you can take the battery and the back off the device and place in completely submerged in a bag of white rice and leave it in there for 1 to 2 days this will help absorb the moisture, this should fix it if the water did not damage the circut boards if the water damaged the circut boards then the device is fried
Jul 20, 2009 | HTC G1 Smartphone
Left in the rain , checked battery , the indicator shows red x's; has there been any damage
Depending on the rain most likely it has suffered water damage. depending on how long it has been since it was left in the rain will depend on if you can get it back to life. Tr to put the phone in a zip lock bag with some rice. let it sit for 24 hours. If there is any moisture left the rice will draw it out. however if it's been a while the water damage may be fatal. If you do get the red blinking light on the top, there still may be hope. There is a way to attempt to reload the OS.
Jul 16, 2009 | RIM BlackBerry Curve 8310 Smartphone
Dropped BB in the rain
it would be best to take the phone now and have a mobile tech look and diagnose the problem to get it back in working order....you don't really want to take chances with a phone that has been in contact with water.
Mar 18, 2009 | AT&T Blackberry Curve 8300 Smartphone
Sony Ericsson W700i Cellular Phone Logo
106 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
