Question about AM Auto Parts 1996 to 1999 VW Cabrio Mass Air Flow Sensor for L4 2.0L
What hydraulic oil should i use for convertable top motor
Which hydraulic oil do you recommend to put in the convertible top motor
  • AM Auto Parts Master
  • 15,639 Answers
You can use any hydraulic fluid. It is usually about the same as a 10 W oil
Posted on May 12, 2013
Engine cranks very slow on starting and will not start
refill the battery with electrolyt and charge it fully, then try to start the vehicle
If it cranks/turns over no faster have the starter motor checked.
Ensure that the timing belt is intact before you do anything, and that it is in the correct position.
Ensure that the oil is clear of water and is clean and is topped up to the top mark on the dipstick
Assuming you have checked the above and the belt and oil/coolant is all as they should be, and you have a fully charged battery and the starter is ok .......attempt to start the vehicle. Turn it over/ crank it over a few times if it does not start immediately.
Should it not start perform a compression check to find out the
engine's state of health.
Then come back with the results and we can go feom there.
Add the detail of your work and the make and model of the vehicle, along with the engine option, and repost the query
Jul 18, 2015 | Spectre 2003 Dodge Stratus - 2.4L 4-cyl....
New furnace, Water In Induction Motor, Yellow Flame
The problem is too much gas as opposed to not enough air. It is still running rich. Did you take into account the elevation of the location your furnace is installed at. The higher above sea level the less air that you have to aid in cumbustion. The condensation is from excess gas being cold and causing water to accumulate. Can you run it like this? Yes but it will cause issues with soot and carbon deposits. It will also cost you more money in the long run.
Dec 23, 2013 | Goodman Manufacturing Goodman GCH950453BX...
Fan is not coming on
The motor spins on brass bushings. you can try oiling the brass bushing. take off the front grill then gently pull off the fan blades. you need to oil the motor center shaft lay it on its back so the oil will run down into the bushing(not to much and use a light oil). there is one on the back of the motor also, this one is a little harder to get too. if this dont work you need a new motor. you can get on off of ebay cheaper. the motor should be replaced by some kind of tech savey person, as the are delicate and a very specifice disassemble procedure.
Jul 07, 2012 | Alpine Air XL-15 Air Purifier
My fan running 110v how to convert in 220v
Use a stepdown transformer to reduce the 220v back to 110v. You can buy them on the internet for using 110v gear in 220v countries
Apr 13, 2012 | Air Purifiers
Electric motor makes screeching sound and stops running.
The motor has worn bushings making the motor shaft hot and swell and eventually seize. You can let it cool off and it will more than likely run again until it heats up again. The motor will have to be replaced if you want to repair it.
Jun 05, 2011 | Honeywell Enviracaire 12520 Air Purifier
Hi my old Honeywell 13520 has acquired a periodic squeal. I am sure it is a motor issue. Any way to tune up these little motors? (Brushes, etc..)
Usually if the motor is squealing, the bearings are dry no lubrication and worn. If you have oil ports you can oil it and quiet it down for a while. Most motors now have self lubricated or oil impregnated bearings, which you can't lubricate. It costs as much for somebody to replace the bearings, as it does for a new motor. Most people replace the motor.
Nov 17, 2009 | Honeywell Enviracaire 13520 Air Purifier
My ecoquest breeze is squeaking
Singer sewing machine oil works great. Remove the front grill and carefully remove the fan by sliding it off the shaft. Where the shaft meets th4e motor, place three or four drops of oil. Spin the shaft and wipe off the excess. Place the fan back on the shaft, flush with the end of the shaft. In the rear, remove the lint screen and the ozone plates. Put oil on one end of a Q-tip over a trash can until it drips off. On the rear of the fan motor, push the Q tip against the shaft so that oil oozes out. Again, spin the fan. Repeat this process every time you clean your Breeze and it should never squeak again.
Mar 25, 2009 | Ecoquest Breeze AT Living Air Purifier
Rainbow Rainmate making a screeching noise!
just take it to ur local dealer they will replace it or fix it.
Feb 12, 2009 | Rainbow Rainmate Air Purifier
Fan motor
Most likely a lubrication problem. These motors can easily become "gummed up" from use. I normally would remove the motor and hold it with the shaft vertical, I would then apply a few drops or 3in1 motor oil just above the bushing (bearing) and allow gravity to move the oil into the bushing while turning the motor by hand. I would flip the motor over and do the same to the other bushing. This motor should spin quite freely. Do not over oil. once the motor is spinning freely, wipe any excess oil from motor and reassemble and test.
Let me know what you find
clarkco
Feb 12, 2009 | Ecoquest Flair Air Purifier
AM Auto Parts 1996 to 1999 VW Cabrio Mass Air Flow Sensor for L4 2.0L Logo
54 people viewed this question
Top AM Auto Parts Air Purifiers Experts
David Payne
David Payne
Are you an AM Auto Parts Air Purifier Expert? Answer questions, earn points and help others
