Lexmark x543 Color shawdowing (pink) running down one side of paper and getting progressively worse. Any Ideas on cause?
Ajkill
  • 2035 Answers
SOURCE: Lexmark X2250 uneven paper feed
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on Oct 06, 2008
SOURCE: Color LaserJet Printer Problem
Have you tried changing the magenta and black toner cartriages?
Posted on Jan 28, 2009
amfigue
SOURCE: Alignment error after replacing black ink. Lexmark X5495
I found a pencil inside my printer and took it out. It was not easy but now it does not jams the paper. Disconnect the power cord and softly shake the printer from side to side making sure you are holding on to the top scanner door so it won't flip open and listen for anything rolling or loose inside. It just might be your problem.
Posted on Mar 24, 2009
  • 250 Answers
SOURCE: The printed pages have pink blotches on the right
Try cleaning the color or magenta cartridge with rubbing alcohol and look inside the printer to see if there's pooled ink anywhere that is smearing on the paper. Try replacing the print head or cartridge.
Posted on Sep 17, 2009
SOURCE: right side of every page has pink strip down page
Either your magenta cartridge is leaking out of the right corner or you have a defective magenta drum.
(maybe it got scratched when changing the cartridge?) If it's the magenta drum, you have to replace all the drums since they come in one unit. OEM part only.
Posted on May 19, 2010
How do I open the lexmark x544 to change the cartridges
you could start on page 168 of the manual. I don't like to type everything there. In the end you still have to read it.
Use a PDF reader like adobe acrobat reader (free on the net) to read this:
http://www.lexmark.com/publications/pdfs/2007/x54x/v5404678_en.pdf
Jan 27, 2015 | Lexmark International X543, X544 Black &...
How do you change the ink cartridge on a lexmark x543 printer
See the manufacturer's web-site:
http://support.lexmark.com/index?segment=SUPPORT&userlocale=EN_CA&locale=en&productCode=LEXMARK_X5435&page=product&frompage=null#1
for the 'X5435' (not the 'X543') printer, and select to download the "manual", which tells you how to maintain your printer.
May 12, 2011 | Lexmark X543dn Laser Color All-In-One...
How do you change the fuser on a Lexmark X543?
A technician is needed to replace the printer's fuser. Please contact Lexmark Technical Support.
Jan 25, 2011 | Lexmark X543dn Laser Color All-In-One...
Lexmark X543 --Getting msg Waste toner box near Full. What is required ?
very simple there is a waste toner bag that came with your Lexmark X543, so you need to remove it and dispose of the toner inside and replace exactly the same you took it and the message will message will disappear
Jan 12, 2011 | Office Equipment & Supplies
The printed pages have pink blotches on the right hand side of the paper and horizontal pink blotches down the page
Sep 17, 2009 | Lexmark Office Equipment & Supplies
Some time it prints in pink
Do you see the color cartridge icon in the progress window being low ?. Or do you get an low ink warning dialog when you print a job. First try cleaning the cartridges if that doesnt help, you may need to replace your color cartridge.
See the below link for cleaning your cartridges, the procedure is near the end of the page:
http://support.lexmark.com:80/perl/support/support.cgi?relevance=0&ccs=229:1:0:537:0:0&mode=DOCS&doctype=KB&term=clean&docid=ENUS30978
Jun 01, 2009 | Lexmark X1270 All-In-One InkJet Printer
Toshiba 57h81
Go to the convergence and align the red and blue + - Under Menu then Picture then convergence to get to this screen- Hope it helps
Mar 24, 2007 | Toshiba 57H81 57" Rear Projection...
81 people viewed this question
jasbo
jasbo
