Question about Craftsman 12 Tilt Head Band Saw Owner Manual 113247210
Sears manual model103.24550
How to install blade
    Sergeant:
  • 468 Answers
Check this informative article about installing band saw blade . However, I am in doubt if that article could really help you in properly replacing the blade. But you may use it as your reference. I can refer you also to sears support site or to vintagemachinery . I am not sure how old your band saw is , you may also visit owwm.org or make posts on different forum sites. If you have questions, you can post your comment to this thread.
Posted on May 07, 2013
Craftsman lt 1000
Sounds like you installed the blades backwards, so the blunt edge of the blades are hitting the tall grass. This would cause the engine to bog down and almost die.
When replacing blades, always note the direction of the cutting edge. If possible, take a digital photograph of the old blades so you can refer to the picture so you can be sure of the direction.
If you go to Sears.com and search your model number, you should be able to find an owners manual that tells you how to install the blades.
Sep 02, 2014 | Garden
Why do i have excessive vibration /broken blades with a sears scroll saw
You have poor quality blades (try Olsen blades), or
You're forcing the work past the blade (just "offer" the work to the blade, let it cut, don't force it to cut), or
Your tension is too high, or
Your tension is too low, or
Your blades are getting installed upside-down (teeth point DOWN).
May 10, 2014 | Sears Scrollsaw Woodworking & Crafts
Can't rotate Blade Angle for Craftsman Radial Arm Saw 113.23100.
The manual writer may have confused knobs or may have used different terminology to identify the same part. A call to Sears might clarify this issue, but then again maybe not. Check operation of all apparent knobs and you may locate the correct ones.
Dec 03, 2013 | Craftsman Sears Radial Arm Saw Owners...
I have Sears- Craftsman 10" band saw #113.244510. after installing new tire the blade tracks to the rear. Have followed manual but cannot solve proble- any suggestions?
Check this blog first. Are you installing a new blade? If the blade is running backwards, you just have to reverse it, turn inside out. Try watching the Alex Snodgrass' Youtube video Band Saw Tune Up .
Oct 17, 2013 | Craftsman 12 x 80" Band Saw Blade 6 tpi...
I have a Sears 22 inch lawn mower, model #917.376070, Serial number 121906M-029886. I recently purchased and installed a new blade from the Sears parts store in Milwaukee (part no. 917-141114) and...
The blade only cuts on the outer 4 inches of the blade rotation(diameter). As the mower moves forward, it cuts the full width of the deck. If sprigs of grass are missed or excessive vibration is present, you may have a bent crankshaft. Check and be careful, ejection of the blade hazard exist.
Jul 17, 2017 | Computers & Internet
Repair Manual for 3 /4"
You can find the manual online at:
http://www.managemylife.com/mmh/owner_manuals/24889/CRAFTSMAN-Planer-L0403001?brand_name_search=315173700+CRAFTSMAN
Cheers,
DIYPro
Apr 27, 2011 | Garden
I have a 12" Sears - Craftsman - Band Saw and the blade keeps coming off. How do I install a new blade and keep it on?
Two potential issues here:
a.) You probably need to align your bandsaw wheels. Here's a link to a craftsman 12" bandsaw manual. Assuming you have model 113243310, 113243311, 113243300, or a similar model, read over page 12-14 "Installing the blade". Specifically, look at section 10 about adjusting the tracking.
Having the blade guides set properly is important too. A thrust bearing (the one up top, behind the blade) that's set too far forward can push the blade off the wheels too.
b.) If it's flat out too loose and you can't get it tight, the blade might be too long. It's worth double checking your manual to confirm you are supposed to be using an 80" blade and double checking the blade package to make sure you actually have an 80" blade.
Jun 14, 2010 | Craftsman 12 x 80" Band Saw Blade 6 tpi...
Instructions to install blade on circular saw
Once you have the right size blade it is really simple to change it.
You only really need two things.
1. locate the button that locks the spindle. It is usually located on the body of the saw. Your manual can show you a picture of it.
2. You will need a 3/8 drive socket that fits the spindle bolt.
I believe these are standard thread orientation and come off counterclockwise.
Mar 20, 2010 | Sears Craftsman 7-1/4 in. Circular Saw...
I bought this dozer blade uses and cant figure out how to attach it to my tractor. Is there a mounting bracket that bolts onto the tractor? Are there any pictures of this or an installation manual with a...
You can go to sears.com and lookup the tractor part number and snow blade part number and they will show you all the brackets and attachments needed. Also the site will show all tractors that the snowblade will fit. Hope This Helps Don
Nov 16, 2009 | Craftsman 16" High Garden Tractor Snow and...
Proper Band Saw Blade
I was just on Sears website and if you go to the bottom of page you can link over to Sears Parts Direct and type in your model number and you should be able to get it online. Good luck
Dec 17, 2008 | Saws
Craftsman 12 Tilt Head Band Saw Owner Manual 113247210 Logo
268 people viewed this question
Top Craftsman Saws Experts
Mike
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
