Question about Sony Televison & Video
RM-A-AU029 I accidentaly pushed the DMPORT button and now i can't get the regular TV to come on.
Sony Remote RM-YD035 does not change channels or turn off TV
You have worn those buttons on your remote out. Those are you most used buttons. You can have you remote repaired by pros here. You can buy a new Sony RM-YD035 here. Or you can purchase the keypad repair kit here and fix it yourself.
Oct 05, 2012 | Sony Rm-yd035 Remote Control
Keyin remote rm-133e tv code for hitachi...
This site HERE should help you with the codes you need.
Jan 17, 2012 | Televison & Video
CHUNGHOP RM-311E code for LG television
couldn't find the code for lg but this should do the trick
Automatic Code Searching
1. Turn on the TV set by hand. Point the controller at your TV set.
2. Press 'Set' button continuously, then press 'power' button, and release the two buttons simultaneously. At this time the light is on.
3. Press the '+' (or '-') button of volume once, pay attention to the volume of your TV to see it increase or decrease. Repeat this action until the volume changes. Then press 'set' button once. at this time the light is out. Set up is finished.
Jul 26, 2011 | LG Televison & Video
Control DMPORT with harmony 880??
I wish I could take credit for this one, but I found something that may be helpful to you from Logitech's technical support forum:
The adding of an iPod dock is frequent question. The quickest & easiest solution is to just add a Digital Music Server with Manufacturer: Apple and Model: iPod to you account. The reason behind this is just to let the Harmony Software know you have an iPod & wish to create an activity to use it.
Once the iPod is in your account you can create a 'Listen to Digital Music' activity. It will ask you which device you want for volume, so just choose the A/V with the dock & the DMPort as the input.
After the activity is been created, you can go back and says 'Yes, but you wish to add more control'. This is where you would add the TV as a additional device in the activity & tell it to go to AV1. Once that is done, the Harmony will turn on the TV & set it to AV1, and turn on the AV & set it to DMPort.
You can also 'Customize Buttons' for the activity in case there are any volume & control buttons you wish to specify yourself instead of using the Apple iPod.
Nov 13, 2009 | Logitech Harmony 880 LCD Remote Control
Was accidentaly locked and i forgot how to unlock
just push and hold the lock button until the lock light goes off sometimes up to 90 secs
Sep 06, 2009 | Jenn-Air JSD2789GES Side by Side...
Ipod dock plugged it, switch to DMPORT no sound from speakers
I had the same problem. I tried everything and finally following two fixed the problem:
Dock insert has to be put before inserting Ipod in the dock. Dock insert usually comes with iPod when you buy it....After inserting the doc I was able to hear the sound but it was very faint. Then I updated the ipod's firmware. My Ipod classic was two years old. I updated the firmware by connecting it to the PC and opening itunes. Clicked on 'ipod' link and clicked to update button.
After the update, this ipod started working with my home theater system's DMPort.
HTH.
Feb 28, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
How do you program the Sony rm-p311 remote
You may wish to clear the remote's memory before starting. Slide the top left switch to "Learn." Press ANY button on the remote, do not worry if the indicator light flashes. Press the "Program Clear" button. The indicator should flash 4 (maybe 5?) times. You are now ready to program. Make sure the switch is in the "Learn" position. Place the rm-p311 and the remote you want to program in about 2 cm apart facing each other. Push the button you wish to program on the rm-p311. The indicator light should come on with a slight delay. Press and hold the button on the other remote until the indicator light goes out. Put the slider back to "User" mode and test it! For more info., go to sony's support site and search for the user manual for the STR-AV1070 receiver. It contains instructions for the remote.
Jan 11, 2009 | Televison & Video
Configuration of Chunghop RM-X10. Manual lost
turn on the tv for example,push ¨s¨ buton(right uper side) and tv1 buton , the light on,release the two bttons simultaneously,press the ¨s¨ button again, and release it,the light start twinkling,now press the power button many times until the tv turned off-on,and finaly press the tv button . (tomas from spain)
Sep 27, 2008 | Universal Remote Control Remote Control
Setting up TV
There probably is a TV/Video button on the bottom of your TV. Push the button until the screen changes to a regular screen. The TV/Video button is also on the remote most likely. Just keep pushing it. Often there are 2 or 3 aux channels. Hope it works!
Aug 11, 2008 | Sylvania Televison & Video
Televison & Video Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
