Whirlpool w10252716 beeps three times and door is locked
2 Suggested Answers
ohms
  • 1879 Answers
SOURCE: LTF2140ES0 washer just beeps three times, wont start
Frigidaire engineers are so smart they programmed it to beep 3 times for door lock problem, draining problem and other problems in the internal electronics and didn't bother to give the users specific info to read off the machine.
Posted on Oct 31, 2008
How do I remove auto door locks
  1. Put the key in the ignition and turn it to on.
  2. Press the Unlock button three times.
  3. Turn the ignition off.
  4. Press the Unlock button three more times.
  5. Turn the ignition back to on.
  6. The horn should beep once. This tells you that you're now in programming mode.
  7. Press the Unlock button, then press Lock again. The horn will beep once to tell you that Auto Lock was deactivated. It will beep twice if you're reactivating the system
There are many ways, I'm not sure which one will work on your car. I answered the two ways. I hope it works.
1. Open the driver's door and put the shifter in Park
2. Turn the ignition to On (II).
3. Press and hold the unlock side of the master lock switch for five seconds until you hear two clicks.
4. Within five seconds, turn the ignition to the Lock position.
Mar 24, 2017 | Cars & Trucks
Oct 30, 2008 | Frigidaire 14 Cycle Tumble Action Washer
Stops and beeps on wash cycle
If it's a whirlpool made washer, shift actuator is possibly the problem.
Aug 29, 2017 | Amana NFW7300WW Washer
Error code of three beeps on a whirlpool dryer model 68972981
Hi troy crawford,
Well if it beeps for 3 times and then shut off when you press start it means that the dryer thinks that dryer door is open. You will have to replace your door switch to fix the problem. or you can also try closing the door normally, then firmly press on the top edge of the door. You will hear the final latch grab, then you press and hold the start button. many time it will works...
Good Luck
Regards
Nov 07, 2011 | Whirlpool Dryers
Trying to get gas self clean/oven to start. Getting error E1 F5.
E1 F5 is bad door lock assembly. Only way to repair is to replace the locking assembly completly. Sorry. Hope this helps.
Mar 06, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
My Whirlpool duet washer lights flash/beep
probably your door then, look at the door itself, at the latch is it broken? should form a complete square hole with four sides. if broken some part is probably inside lock asm. if complete, look at lock and determine if its in the lock position with door open, a arm will be up preventing the latch from going in. replace as necessary. Old duets (red lights) use standard lock asm same as GE and samsung. New duets (green lights) use whirlpool/new maytag unique asm. New locks come in two interchageable models, German (made in china) and Mexican, Mexican model is more troublesome, get german.
If lights flash during a cycle or other time, its giving a code, note the F code displayed
Jul 19, 2009 | Whirlpool Washing Machines
Front load will not lock
are you getting three beeps when trying to start, if so door lock problem
Nov 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Door locked
f 22 is the code for door Lock failed after six tries try hitting pause/cancel twice if door unlocks spray lock with wd 40 try again and advise
Dec 29, 2007 | Whirlpool WFW8500SR
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
