Question about Standard Oregon Chainsaw Chain For Stihl Chainsaw 24" Bar Length 84 Drive Links 3/8 0.05 Gauge Chiesel Chain
018c oiler not enough oil to properly lube the chain
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 171 Answers
Ck.the oiler drive gear behind the chain sproket
Posted on Jun 23, 2013
Is there a oil ajustment for the bar oiler on a homelite chain saw
Homelite XL auto oiler - YouTube
? 2:44
https://www.youtube.com/watch?v=PnNTJ3xI_wo
Mar 24, 2012 - Uploaded by 343HFD
Refurbished, carb cleaned/adjusted, new filter, fixed automaticoiler. Anyone know the nut size for the bar ...
HOW TO REPAIR CHAINSAW OILER - YouTube
? 6:38
https://www.youtube.com/watch?v=kmUkieIP-vw
Jan 20, 2012 - Uploaded by gregthegardener
lf your chain saw isn't lubing the chain it can cause serious chain ... How to Replace the Bar & Chain Oil ...
Dec 03, 2015 | Homelite Garden
HOW AND WHERE TO ADJUST THE OILER ON THE 240 HUSQVARNA
The Husqvarna 240 does not have an adjustable oiler. Always use good quality bar and chain lube, never motor oil.
Jun 14, 2014 | Husqvarna Garden
I have a1640 partner and the oiler pump does not pump out oil when in use. I cleaned the saw and I have lost the cap which fits on the end of the plunger of the oil pump
Hi allanpriest...
Forget the auto oiler...use a handheld oil gun to lube the chain on your saw...just lube the chain approx. every 2 - 4 minutes of use
Please take time to rate me
Sep 15, 2011 | Electrolux Garden
I need to know the oil gas ratio, and about chain
Hi ccollins529...
Normally a 50 to 1 mixture is fine...1 pint 2 cycle oil to 6 gallons of gasoline.
Use "bar and chain" oil on the bar, this is an oil blended for the chain and bar.
If yours has an auto oiler you will put the oil in the bar/chain oil container.
If you do not have an auto oiler,use a hand oiler to lube the chain when needed.
Aug 28, 2011 | Garden
Brand new poulan pro 4620avx--bar oil is coming out of oiler but not getting onto chain
Hello. Thin your bar oil just a wee bit with some kerosene. If you have a gallon of bar oil add 1/4 cup of kerosene, stir it up and you will be fine. For starters also, directly apply some bar oil to the chain so that you are always using a well lubed chain. Joe
Oct 03, 2010 | Poulan Pro Chain Saw 46cc 20"
Doesthis thing need oil or some other liquid type
The bar and chain require bar oil (only) to be placed in the capped tank. The motor itself is air cooled, and should be blown out with compressed air often to remove the accumulated sawdust. Make sure the chain is tightened just enough to prevent the lower part of the chain from drooping from the bar and can be turned by hand. Make sure to keep the chain teeth sharp by properly filing for best cutting. Test the chain oil pump operation by running the saw with the chain tip near a piece of cardboard--it should throw off a thin line of oil after a moment or two of running. Hope this helps!
Apr 05, 2010 | Remington Electric Chain Saw
Chain oiler not working properly
If it pumps then quits perhaps the tank vent is plugged. When it quits roll the saw, loosen;;; then tighten the oil cap. If it no better post back (below) with a model and serial number and we will analyze your oil system. If it works post back with numbers and I can at least provide a link to your exploded parts list.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 04, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
What is the most likely cause of oiler not working
Several causes exist. Most likely are:
1) Clogged oil-hole in bar.
2) Clogged strainer in oil tank. (part # 530056533)
3) Unhooked pickup hose in oil tank. (part # 530038373)
4) Faulty oil pump. (part # 530071259)
Of course, check oil level and use proper bar&chain lube.
Hope this helps,
Dolf-
Oct 16, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Husqvarna chainsaw 440e - enough chain lube?
That seems low to me. Page 15 in your manual is the only oil discussion I found. Usually there is an oil pump adjustment reference somewhere. I didn't see one beyond return it for service on page 15. Are the chain and bar hot after cutting a while? I recommend you not get a longer bar without an oiler adjustment. I think the hand of the EPA has been here.
An IPL (exploded parts list) for a 440 can be found here:
http://weborder.husqvarna.com/order_static/doc/USA/2009/I09000/I0901018.pdf
There is no oiler adjuster listed. HTH
Lou
Might be a good idea to copy the IPL,
Oct 07, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Standard Oregon Chainsaw Chain For Stihl Chainsaw 24" Bar Length 84 Drive Links 3/8  0.05 Gauge Chiesel Chain Logo
60 people viewed this question
Top Standard Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Standard Measuring Tool and Sensor Expert? Answer questions, earn points and help others
