Question about Ace Hardware Ace Staple Gun
Staple gun 2034775 won't shoot staples - Ace Hardware Ace Staple Gun
4 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: won't shoot staples
look for a jammed staple near the end of the magazine that is stopping them from advancing. Also make sure they move freely in/on the magazine. Double check to ensure that you are using the right staples for this tool.
Posted on Oct 02, 2009
tbirdfan1
  • 3051 Answers
SOURCE: reloading ace 22084 staple gun
Hello there:
when you purchase staples for this particular gun even though you might get a staple that is says it fits this gun you need to look at the type of staple if you get the one that says heavy duty it will not work it took me 2 times to find out the right ones for this gun it comes in a green box and says standard duty on it not heavy duty this is where most people make their mistake. ok?
best regards michael
Posted on Oct 03, 2009
jeff_drakesr
  • 155 Answers
SOURCE: I bought a used item #f509040 brad/staple gun (Air
The nails fit one side same place as the staples its usually on right side but may not matter. I hope this helps please rate if the answer helps in any way. Good Luck and have a great weekend.
Posted on Apr 03, 2010
My gun will not shoot staples
The most common cause of the gun not firing is loading it with the wrong staples. Look at the packaging for the staples and see if it lists the gun. Staples are NOT universal and are make for specific staple guns.
It "sounds like" it is jammed. You may have to pull out the staple with needle nosed pliers. e`1
How to Load Staple Gun
How to Troubleshoot Staple Gun Hunker
Oct 04, 2017 | Staples Tools & Hardware - Others
Arrow jt27 staple gun won't load or staple
Everyone here is assuming that you have fully operational gun. I have a business where we use these guns. I can tell you now that 3 out of 5 of the Arrow JT-27 just don't work. The staples won't advance. After looking at the information online, it is probably due to a weak spring. The best solution is to go with a different brand of stapler. This one is just not worth the trouble.
Jan 16, 2013 | Tools & Hardware - Others
Paper pro generation ii won't staple
you can open this one its ribbet.also not good idea to try it.
can be dangerous.its not worth to loose a pretty face then to by a new one.http://www.ebay.com/itm/Pro-Heavy-Duty-Tacker-Staple-Gun-Insulation-Screening-Upholstery-Stapler-/110746725341?pt=LH_DefaultDomain_0&hash=item19c904ebdd
Jul 26, 2012 | Black & Decker Tools & Hardware - Others
What part do I need to remove to make a bostich MIIIFS floor stapler to shoot 2 inch staples
You shouldn't have to do anything to the MIIIFS flooring stapler to shoot 2" staples. It is designed to shoot 1 1/2" to 2" staples right out of the box. If your stapler won't feed 2" staples, check the magazine all the way up to the power head for any foreign material that may hold up your staples.
Apr 26, 2011 | Stanley Bostitch STB-MIIIFS Flooring...
Gun shoots but no staples coming out, part that
try carefully tapping it in with a nail punch and hydraulic tool oil
May 15, 2010 | Tools & Hardware - Others
My gun will not shoot staples after loaded I thin there is a part missing
Staple gun are simple device and the 'shooting' mechanism is just a sring loaded bar that hammers the staple out: the problem is usually a jam/stuck staple where the staple in the orifice where the staple comes out. Just use a small screwdriver and /or plier to remove the stuck staple which could be jammed against the hammer bar. You may need to force the hammer bar backwards with the help of your small flat head screwdriver.
Hope it helps!
May 02, 2010 | Stanley CT10C Heavy Duty Staple Gun/Cable...
How do you adjust the staple size to load 1/2" or 1/4" staples?
Staple guns can use a variety of staples; the width of the staple is fixed, the lengths vary from 1/4" up (usually in 1/8" increments). You don't need to adjust the staple gun for the different lengths, just be sure the width fits your gun since some manufacturers have used brand-specific staples.
There are also a variety of staple types; there are staples for ceiling tile, electric wire, window screening, etc. My favorite staples for wood have the tips cut on a sharp angle, they penetrate wood well. Some staple types require a particular gun, I have a gun that shoots only round-top staples for small cables like phone & thermostat wire.
Dec 05, 2009 | Stanley CT10C Heavy Duty Staple Gun/Cable...
(DP) air staple gun won't reload after shooting 1 staple
i have mini blow 8 mm gun automatic after i chut he did not reloaded plz tell how i can fixed
Jun 06, 2009 | Staples Tools & Hardware - Others
Ace Hardware Ace Staple Gun  Logo
Top Ace Hardware Tools & Hardware - Others Experts
John Trevino
Are you an Ace Hardware Tool and Hardware - Other Expert? Answer questions, earn points and help others
