Question about Kent International GMC Denali 700c Mens Road Bike, Large
Use revoshift friction
How to use
What prevent friction? I really want to find out for my concentration of forces in science lessons.
friction is the physical attraction of atoms of the items in contact and is affected by the quality of the surfaces
It has a quantifiable number called a coefficient of friction and there are may engineering tables that can be found for all materials
If the surface of an object is magnified considerably, it will be seen as ridges and valleys and when two objects cone in contact ,the friction is caused by the hills and valleys hitting each other in movement
This is why metal parts that have no lubrication wear out and if the movement is fast enough will generate heat to the point that the surfaces melt into each other
in metals it is known as friction welding and is widely used in industry
how to reduce friction
it is done by filling those hills and valleys with a substance that keeps the surfaces apart such as oil, water or a substance where the surface melts momentarily and fills the hills and valleys and so the hills and valleys get smaller and smaller
IN a simple example-ice skates on ice
The small surface of the blade actually hits the ice hills and valleys and generates heat that melts the ice to water and that water fills up the next lot of hills and valleys in the ice
skaters are actually travelling on a surface of water that is separating the skate from the ice
with out friction we could not walk as the feet would simply slip out from under us, we could not rub our arms to get warm as there would be nothing to generate the heat
cars would not move as there would be no friction for the tyres to grip the road
birds could not fly as the air would have no friction on the wings and so there would be no differentiating air pressures to create a vacuum for the lift
to increase friction simply increase the load between the surfaces
example is to place a piece of paper between 2 books
try to pull the paper out and it comes out fairly easily
put another book on top on the upper book and the friction is increased and the paper is harder to pull out
putting more books on top and eventually the friction is greater than the tensile strength of the paper and so it tears
Hope this gives you friction for thought as it rubs brain cells together.
Jun 09, 2015 | Miscellaneous
How to use revoshift gears
Twist grips usually work when pedaling. at first, try one side only, then the other.
Mar 14, 2015 | Cycling
My revoshift is functioning properly. Any suggestions for correction?
The reason its rotating out is because there is slack in the cable. To tighten the cable put shifter in lowest gear and chain on smallest chainring, Loosen derailler bolt, with a pliers pull slack out of the cable. Be careful not to pull so hard that you move derailer to next chainring. If you are unsure of this operation, consult your local bike shop.
Nov 02, 2014 | Cycling
Types of friction?
  1. Static friction
  2. Kinetic friction
  3. Rolling friction
  4. Fluid friction
Jul 12, 2014 | Games
Manual for shimano revoshift
All available manuals are listed at www.shimano.com
Dec 08, 2010 | Cycling
How do i relpace my clutches and install new ones
Remove the left side cover to expose the clutch. Remove the outer pressure plate by removing the 6 bolts and springs. You can now remove the first friction plate. Then a metal pressure plate, then friction, metal, friction, etc.. The first and last friction plates are a few thousandths of an inch thicker than the rest of the friction plates. When installing the new plates, be sure the two thicker friction plates are at each end of the clutch. A complete diagram of your clutch can be found at the following website. Please rate my answer. Thanks.
www.babbittsonline.com/pages/parts/viewbybrand/default.aspx
Aug 12, 2010 | 2006 Suzuki GSX-R 1000
I have a Tunturi W No EE 329847 are friction pads asbestos free.
The friction pad are asbestos free and you can purchase them at Accel Fitness of North America At 1-800-503-1221
Mar 11, 2010 | Exercise & Fitness
Install Shimano revoshift. bike came with shift cable not attached. how do I attach it? thanks, barry lentz
Front or rear? Is the cable not in the shifter?
If the cable is not in the shifter, there will be a screw in the shifter (made of plastic, usually black) facing outward. You open this and shift the shifter into the highest gear, then slip the cable through and out the side that accepts the cable sleeve. Then you run it through the sleeve and to its appropriate derailleur (left hand=front, right hand=rear).
Sep 12, 2009 | Mountain Shimano Revoshift Bicycle...
I have a 550 maxim is there a certain order for the clutch plates to go back in
Yes, there is a certain order for the plates. The firstplate must be a fiber friction plate then a metal pressure plate, then friction, metal, friction, metal, etc.. You should wind up with a friction plate as the last plate to go in.
Aug 25, 2009 | 1981 Yamaha XJ 650
Kent International GMC Denali 700c Mens Road Bike, Large Logo
49 people viewed this question
Top Kent International Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Kent International Cycling Expert? Answer questions, earn points and help others
