Question about Kent International GMC Denali 700c Mens Road Bike, Large
How to use shimano revoshift friction
Why cant I find any information on my Shimano Tourney RD-TY10 rear derailleur?
Because it's been out of production for some time. There's no useful info to be had anyway. It is adjusted the same as most any rear friction derailleur. It is not useable with indexed levers (click to shift). If you really think you need info do the following Google search: "RD-TY10 site:shimano.com" and scroll through the results.
May 05, 2017 | Shimano Cycling
The 6 speed revoshift gear wiring is in need of repair and we aquired the bike with no owners mannual. can ya point me it the right direction? Thank ya. jen
One of these should get you going...
http://techdocs.shimano.com/techdocs/index.jsp
http://techdocs.shimano.com/techdocs/blevel.jsp?FOLDER%3C%3Efolder_id=2534374302052334&ASSORTMENT%3C%3East_id=1408474395181679&bmUID=iS2s7KN lists a lot of Revo Shifters
http://techdocs.shimano.com/media/techdocs/content/cycle/SI/Nexus/ShiftLever/SB-7S45/SI-65R0C-001-ENG_v1_m56577569830630954.pdf
http://techdocs.shimano.com/media/techdocs/content/cycle/SI/Nexus/ShiftLever/SL3S41E_SMBC06/6NL0A-001_SL3S41E_SMBC06-EN_v1_m56577569830625399.pdf
http://www.parktool.com/blog/repair-help will describe some of the techniques and tools required (they sell tools).
Since you'll need to go to a bike shop to buy the right shifter and brake cables anyway you should have them show you some of the fine points and ask about the special tools (cable cutter, for example) required. You may find that unless you intend to become a regular self-service bicycle mechanic the cost of equipping for that is prohibitively expensive and the occasional paid repair or tune-up would be worthwhile. In fact, a tune-up would address your problem and others of which you may be unaware.
Jan 18, 2011 | Cycling
Manual for shimano revoshift
All available manuals are listed at www.shimano.com
Dec 08, 2010 | Cycling
Install Shimano revoshift. bike came with shift cable not attached. how do I attach it? thanks, barry lentz
Front or rear? Is the cable not in the shifter?
If the cable is not in the shifter, there will be a screw in the shifter (made of plastic, usually black) facing outward. You open this and shift the shifter into the highest gear, then slip the cable through and out the side that accepts the cable sleeve. Then you run it through the sleeve and to its appropriate derailleur (left hand=front, right hand=rear).
Sep 12, 2009 | Mountain Shimano Revoshift Bicycle...
Kent International GMC Denali 700c Mens Road Bike, Large Logo
425 people viewed this question
Top Kent International Cycling Experts
John Egan
John Egan
Are you a Kent International Cycling Expert? Answer questions, earn points and help others
