Question about Joal 150 Volvo FH12-420 Dump Truck Die Cast
HOW MANY LITERS OIL FOR EN GEN VOLVO FH 420 - Joal 150 Volvo FH12-420 Dump Truck Die Cast
Hi can you please give the diffs speeds for a truck fh 16 660 2010 vin yv5auj0d8ad132444 vehicle 132444 importer no 7830
Driveline - Specifications : Volvo Trucks - United Kingdom ...
www.volvotrucks.com > ... > Specifications
Volvo TrucksFind all the driveline specifications for the new Volvo FH, including the engines, I-Shift, ... 12-speed splitter and range gearbox with automated gearchanging system. ... Supplied as standard with I-Shift and gives the gearbox its basic functions. .... Pleasebe aware that if you change your cookie settings, we can no longer ...
[PDF]Volvo FH series Product guide - Volvo Trucks
www.volvotrucks.com/.../Trucks/...fh.../Volvo-FH-Series_...
Volvo TrucksVOLVO FH AND VOLVO FH16 PRODUCT GUIDE volvo fh series .... You can literally steer the truck with one finger. This not only gives you complete control of the ... By constantly receiving information about vehicle speed, ..... 335 mm under thedifferential. ... Please note: this is not available on a right-hand drive (RHD).
[PDF]Manual New FH - Volvo Group
www.volvogroup.com/...Trucks/Manual%20new%20FH%20f...
AB VolvoIf you have any questions or want to know more about your truck, please contact your. Volvo dealer. ... network across Europe, we can help you with repairs to your truck and its .... Differential lock. .... manual gives you an overview of the .... Adapt the speedand maintain as even a speed as possible. 02. DRIVING TIPS. 16.
Jan 01, 2016 | Cars & Trucks
1988 244 dl volvo radiator capacity?
Capacity: 9.9 US qts. = 9.4 liters (manual transmission models); 9.7 US qts = 9.2 liters (automatic transmission models) good luck:)
Nov 14, 2010 | 1988 Volvo 240
How much oil should i put in at an oil change on a 2001 monte carlo 3.4
Hello, this is the oil capacity of your vehicle.
I hope this info is helpfull
  • with filter change
4.1 liters
4.3 quarts
  • without filter change
3.75 liters
4.0 quarts
  • 3.4L (LA1)
4.1 liters
4.3 quarts
3.75 liters
4.0 quarts
  • 3.4L (LA1)
4.1 liters
4.3 quarts
3.75 liters
4.0 quarts
  • 3.4L (LA1)
4.1 liters
4.3 quarts
3.75 liters
4.0 quarts
  • 3.4L (LA1)
4.1 liters
4.3 quarts
3.75 liters
4.0 quarts
4.1 liters
4.3 quarts
3.75 liters
4.0 quarts
with filter 4.3 quarts
without oil filter 4 quarts
Oct 08, 2010 | Chevrolet Chevy Cars & Trucks
Fluid capacities and fluid specs
2000 TOYOTA TACOMA 2.7L 4-cyl Engine Code 3RZ-FE
Engine Oil Grade 1......API* All TEMPS......5W-30 Optional ..10W-30
Engine, 2WD, with filter..........5.5 liters
Engine, 4WD, with filter..........5.4 liters
Manual Transmission,......GL-5/ GL-4 All TEMPS......75W-90
Automatic Transmission,A340E......AF3 / A43D......AF3
Differential, Front/ Rear W/ ADRD......GL-5 ALL TEMPS......75W-90
Differential, Front Less ADRD......GL-5 ALL TEMPS......80W-90
Transfer Case,......GL-4/GL-5 ALL TEMPS......75W-90 Gear oil.
Capacity:
Cooling System, Initial Fill..........8.5 liters
Automatic Transmission, A340E Initial Fill..........1.6 liters
Automatic Transmission, A340F Initial Fill..........2 liters
Automatic Transmission, A43D Initial Fill..........2.4 liters
Automatic Transmission, Total Fill
4 speed A340E..........7.2 liters
4 speed A340F..........10.1 liters
4 speed A43D..........6.5 liters
Manual Transmission, ..........2.5 liters
Differential, With ADRD Front..........1.2 liters
Differential, Without ADRD Front..........1.1 liters
Differential, 2WD V6 Rear..........2.6 liters
Differential, 4WD Extra Long Rear..........2.5 liters
Differential, Short WB With LSD Rear..........2.7 liters
Differential, Short WB Without LS Rear..........2.6 liters
Transfer Case, Electronic..........1.2 liters
Transfer Case, STD..........1 liters
Feb 09, 2010 | 2000 Toyota Tacoma PreRunner
What kind of oil and how much oil does a 1995 volvo 960 need?
your oil capacity is 6.1 quarts the oil you use depends on the mileage if under 80k i would use 10w-30 if over than try 10w-40 high mileage.
Feb 02, 2010 | 1995 Volvo 960
Oil spec
1995 HONDA ACCORD 2.7L 6-cyl Engine Code C27A4 C27A1
Engine Oil Grade 1......API All TEMPS......5W-30
Manual Transmission,......SJ All TEMPS......10W-30, optional 10W-40
Automatic Transmission,MPZA......AF2
CAPACITIES:
Engine, with filter..........4.4 liters
Automatic Transmission, MPZA Initial Fill..........2.7 liters
4 speed MPZA..........6 liters
Manual Transmission, ..........1.9 liters
1995 HONDA ACCORD 2.2L 4-cyl Engine Code F22B1 VTEC
Automatic Transmission,A0YA......AF2
CAPACITIES:
Engine, with filter..........4.3 liters
Automatic Transmission, A0YA Initial Fill..........2.4 liters
Automatic Transmission, MP0A Initial Fill..........2.4 liters
4 speed A0YA..........6 liters
4 speed MP0A..........6 liters
Jan 07, 2010 | 1995 Honda Accord
Trying to find out how much oil the Triton V-10 takes when I do my oil change? I cant seem to find it or anyone who knows
It should be listed in the owners manual, but because of different oil cooler setups you may have to do the change yourself and add oil until the correct level is established..... for the first oil change.
Most likely 7 liters,but start with 5,run the engine to fill the oil filter,let it sit for 5 mins and recheck and fill to full.
Note the amount needed for next time.
Nov 08, 2009 | 2000 Ford F250 Super Duty Crew Cabs
How much oil in xr250r??
Oil change only...
XR250L XR250R................................. 1.3 liters (1.37 US qt)
XR400R.............................................. 1.7 liters (1.8 US qt)
Oil & filter change...
XR250L XR250R................................. 1.4 liters (1.5 US qt)
XR400R.............................................. 1.8 liters (1.9 US qt)
After engine rebuild...
XR250R, 1986 through 1995 XR250L..... 1.6 liters (1.7 US qt)
1996 and later XR250R........................ 1.7 liters (1.8 US qt)
XR400R.............................................. 2.2 liters (2.3 US qt)
Jul 11, 2009 | 1997 Honda XR 250 R
How many liters do i need for oil change for my 2004 XC90 2.9turbo
Not sure which model your car is, but it's either 5.8 or 6.7 liters. Check out this page, it's got all the specifications (including oil capacities) and basic info about your car:
http://new.volvocars.com/ownersdocs/2004/2004_XC90/04xc90_10.htm#pg151
Jul 10, 2009 | 2004 Volvo XC90
Joal 150 Volvo FH12-420 Dump Truck Die Cast Logo
35 people viewed this question
Top Joal Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Joal Toy Expert? Answer questions, earn points and help others
