Question about Braun Hand Blender 600 Watt 220 Volt - Will Not Work In Usa
Silvercrest blender seized spindle
Any spare parts silvercrest ssms 600 b3
I am looking for the part as showed image.
May 29, 2014 | Blenders
Silvercrest drink blender seal
Silvercrest could be a source of replacement seals
Jun 08, 2013 | Blenders
Blade not turning
Ouch. That doesn't sound good.
Is the blade seating & locking on the spindle? Try turning it with your hand (unplug the blender first!).
Examine the underside of the blade, and the spindle, for cracks.
If you find a problem here, it may be a simple matter of replacing the blade assembly.
If not, try running it dry... no blade, no container. Just short shots of one second. Is the spindle turning? If it turns, then put the container & blade back on... but just put water in the container.
If the blade turns, whipping the water (but doesn't turn if you put something more dense in it), that suggests that your bearings are going out.
In summary:
  • If the spindle turns but the blade doesn't turn, look at your blade assembly. (Plastic can hide a crack.)
  • If the spindle turns "sometimes", but not when subjected to resistance, then it's probably worn bearings.
  • If the spindle doesn't turn at all, then your blender will need to be professionally repaired or replaced.
Mar 03, 2011 | Cuisinart BFP-10 7-Speed Blender
Hi, my blender blades won't turn on i have cuisinart blender 7 speed plz help
when the blender cup is not on, does the spindle turn (medal stud looking thing)
and does it do it on all speeds?
Aug 12, 2010 | Cuisinart SPB-7 SmartPower Work Top...
The motor on the Bamix hand mixer is working properly yet the spindle will not spin. It appears as if it is not engaging. The spindle is not jammed.
there is a rubber connetion between the motor spline and the spindle which holds the screw that connects to the spindle, this has broken
Jun 09, 2009 | Bamix Immersion Handheld Blender
Need replacement parts for foodnetwork bobby flay "bobby blender", model no. BF-9349
My food network blender has seized. The power is working but the blades do not move.Please advise. Thanks!
May 04, 2009 | Blenders
Black plastic "ring" that fits over the spindle on the motor base snapped
I just bought a replacement part on ebay. It cost about $11, which included shipping. buy-it-now-store.com
Jan 16, 2008 | Cuisinart SPB-7 SmartPower Work Top...
Blinking lights on KitchenAid blender
Alternating blinking lights on a Kitchenaid blender indicate a bad circuit board which is unable to run the motor properly. Unplug the blender, take the jar off, and turn the spindle by hand. Then plug it back in. If it does not work properly, try a different outlet (perhaps not in the kitchen). If nothing works, the blender needs to be repaired.
Aug 27, 2007 | KitchenAid KSB3 Classic Work Top Blender
Braun Hand Blender 600 Watt 220 Volt - Will Not Work In Usa Logo
61 people viewed this question
Top Braun Blenders Experts
Ross Keen
NOEL
NOEL
Are you a Braun Blender Expert? Answer questions, earn points and help others
