Question about Briggs & Stratton Garden
Engine turns over but wont start
18hp intec engine husky mower
  • thomas May 08, 2013
    the carberator has flames in it also
    Problem Solver:
  • 10 Answers
It sounds as though you may have a sheared flywheel key. The keys are made of aluminum and shear easily if the flywheel is not tight. Remove top cover and flywheel retaining bolt/nut. Examine key for location with slot in crankshaft. If sheared, orient the flywheel slot and crankshaft slot so that a new key fits. Be sure flywheel and crankshaft mounting surfaces are clean and free of oil/grease. Tighten crankshaft retaining bolt/nut to 90 ft lbs. Flywheel posisition is maintained by friction between it and crankshaft.
Posted on May 01, 2014
  • charlesr41 May 01, 2014
    It sounds as though you may have a sheared flywheel key. The keys are made of aluminum and shear easily if the flywheel is not tight. Remove top cover and flywheel retaining bolt/nut. Examine key for location with slot in crankshaft. If sheared, orient the flywheel slot and crankshaft slot so that a new key fits. Be sure flywheel and crankshaft mounting surfaces are clean and free of oil/grease. Tighten crankshaft retaining bolt/nut to 90 ft lbs. Flywheel position is maintained by friction between it and crankshaft.
woobie dog
  • 1273 Answers
SOURCE: murray 18hp 42 deck wont start
Hi.
The best advice here is to put your battery on charge, and, while it is charging, remove each connection, and clean the terminals back to "bright and shiney". The clicking noise is probably the solenoid trying to pull in to provide power to the starter. There also sounds like the comnnection to the starter needs to be removed and cleaned. If this connection is dirty or loose, it can arc and smoke without cranking. Also, if the terminals at your solenoid are corroded, the motor cannot recharge the battery on the run, and loss of power to the battery will result. Clean your connections, and try again!
This should correct your issues. In extreme conditions, it may be necessary to replace your wire from the solenoid to the starter, if it is significantly deteriorated, but I'd clean it all up first.
Best regards, --W/D--
Posted on Aug 11, 2009
  • 257 Answers
SOURCE: I have a riding lawnmower that has a 18hp briggs
sounds like you may have a froze up pully on the deck somewhere,, check those,, hope this help you,,good luck
Posted on Aug 15, 2009
  • 239 Answers
SOURCE: Husky ride on mower will not start.
Sounds more like a safety switch problem, first verify the seat switch then the mower switcher and make sure it's not in reverse.
Posted on Sep 04, 2009
mickey813
  • 472 Answers
SOURCE: Looking for mower deck belt diagram for a Husky
THAT NUMBER IS NOT COMEING UP CAN YOU SEND ME THE NUMBERS FROME UNDER THE SEAT
Posted on Oct 08, 2009
SOURCE: 18hp craftsman riding mower model#917.255913. won't turn left!
I have had this problem for the longest time. I replaced the secondary gear twice. Helped for a brief period and now won't turn left again. Replaced the steering shaft and worked for a brief period. Back to no left turns once again. The issue is with the secondary gear and bearings (plastic) which is only a temporary fix. What I had done was welded a piece of steel to the bottom of the steering shaft eliminating the secondary gear connecting directly to the tie rod for the steering. Works perfect now.
Posted on Jun 01, 2010
Sears troubleshooting
remove the cooling cowl and clean the grass and dirt rom around the cooling fins of the head as it is probably getting to hot and the fuel is evaporating before it gets to the cylinder.
Jul 13, 2014 | Garden
This could be do to many reasons. If it was setting all winter and its your first time in the spring I would say dirty carb. If something was hit by the blades and will not start I would check the shear pin under flywheel.
May 06, 2013 | Briggs & Stratton Garden
B&S 18HP will not start
check compression squirt a shot of starting fluid in the carb see if it wont start check all your safty switchs
Apr 24, 2013 | Briggs & Stratton Garden
My cub cadet wont restart after it gets hot
what engine do you have and how long has it been doing it for, try a new plug at first.
Jan 10, 2013 | Cub Cadet I1042 42" 18HP Zero Turn Tractor...
Engine backfires on craftman 18hp 42inch Won't
remove the valve covers and check the valve adjustment
Jul 06, 2012 | Garden
18hp kohler engine (grasshopper) won't start. Single click from starter/solenoid when key turned. Battery new/charged.
I have a duetz-allis mower with 18hp. kohler eng. won't start, have new seloniod, new circuit breaker, getting fire to switch & out. Still won'tstart
Aug 04, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Sep 19, 2009 | Garden
Briggs & stratton 18 HP intek ohv won't start
check the safety switches one of them are bad
Jun 25, 2009 | Garden
Garden Logo
71 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
