Question about Sony DVP-FX780 7" Portable DVD Player
Portable DVD player is giving a message "Cannot play Disc". The DVD player starts like it is going to play and then stops. I have tried many different DVDs and the same thing
Showing "Cannot play disc". Player starts like it is going to play and then stops showing message. I have tried several different DVDs. It was playing one DVD and then stop.
dankind38
  • 6 Answers
SOURCE: SONY SLV-350P DVD PLAYER/VCR COMBO
I'm afraid you are dealing with a weakened Laser on the unit. The cost vs. benefit ratio of fixing this unit is not worthwhile.
You will find that there are newer versions of this device on the market less expensive than what you paid for the unit you have now.
Posted on Dec 30, 2007
bestdarngood
  • 3037 Answers
SOURCE: Sony DVP-NC675P Multi-disc DVD player will not play dvd's
have you tried cleaning the laser at all?
Posted on Apr 05, 2008
abhishek33
  • 1239 Answers
SOURCE: I want to be able to play all my recorded dvds but get message
HI CHECK THESE Steps:
1. Remove the screws that hold the top case on the dvd player. There will be a couple of screws on each side of the player and a couple of smaller screws on the back. They will most often be BLUE RAY head screws.
2. Once the cover is removed, push the eject button to open the cd tray and get it out of your way.
3. Unplug the player from the outlet.
4. Take the can of compressed air and blow out the entire inside of the case. Make sure to blow inside the carriage and around any moving parts of the dvd player including tracks, tray, gears, etc.
5. Check the inside of the carriage using a small flashlight and look closely to make sure there is not debris caught in the spindle or other places like hair, large clumps of dust, dirt, and anything else that should not be there. If you see this kind of material remove it with tweezers and repeat blowing out the inside.
6. Pour a small amount of the rubbing alcohol into the cap and lightly dip a cu-tip in it and shake off any excess.
7. Now and clean off the optical lens (which will look like a small glass bubble in the middle of the carriage) with the cu-tip. Repeat this process a couple of times using a clean cu-tip each time.
8. Let air dry for 2 minutes before plugging the player back in and closing the tray.
9. Replace the cover and clean your discs before placing them back in the player. Test to see if the problem has been fixed.
You should clean your dvd player out at least once or twice a month for good preventative maintenance which will extend the life of your dvd player.
Posted on Jan 04, 2009
konzzz
  • 255 Answers
SOURCE: dvd player does not read disc
try cleaning it first.
Posted on May 29, 2009
xptareq2000
  • 1447 Answers
SOURCE: Discs won't play.
please change laser unite then solve your problem
Posted on Sep 09, 2009
Dvd player gives message "this
Tries many more DVD discs tries to check it out as the disc u insert in the DVD player tray have difference region format disc that why u getting that answer.
Jun 05, 2011 | Panasonic PV-DM2792 Triple Play 27 in....
Portable dvd player when you put disc in machine it comes up with wrong disc display on screen is it the settings
It would more likely be the types of discs used. They are either of a region code not compatible with the player, contain foreign/unknown data, or they are unsupported formats. For example, if the player supports DVD-R playback, and you put a DVD-RW in, the player will generate 'wrong disc' message if the player cannot recognise the disc or the contents on it.
The disc formats/types that can be played should be outlined either on the unit itself or in the instruction manual (if you still have it). If the player shows that message even with genuine shop-bought DVDs then there is a defect within the unit, workshop attention may be required to fix it, but it could be costly.
'WRONG DISC' usually means the disc inserted is of a different region code to the player, or the wrong format (DVD-RW instead of DVD-R as exampled above). Try using different discs before going any further.
May 04, 2011 | Televison & Video
Says loading disk and then says wrong disk everytime. tried several different dvds. always the same answer!
The DVD portable player and the DVD disc came from the same countries?Ur DVD portable player and DVD disc u are using might have the wrong region DVD disc format frequencies.Like PAL frequencies only play Euroupean,Asia,Middle East,Austriala and Africa products.NTSC frequencise play only USA,Canada and Mexico DVD Disc products.
Dec 13, 2010 | Coby 7" Widescreen TFT Portable DVD Player...
Our only one month old portable insignia dvd player will not read any dvd...get message stating "loading" or no disc...Please advise
try clean the lens with cotton buds gently/smoothly...try audio cd or vcd to play if it will play and not playing if the disc is dvd...lens for replacement partially burnt
Jan 03, 2010 | Insignia I-PD720 Portable DVD Player
Will not play dvd's plays cd's
Just like my Samsung unit, it sometimes play, sometime not, Try different dvd, if one plays, leave it playing until finish, try another one and so on. dvd machines need to have some exercise too
Aug 09, 2009 | Zenith DVP615 Portable DVD Player
No valid disc message displayed. Disc is spinning.
When a DVD player starts doing that, it either needs to be cleaned, or something is going wrong with the DVD mechanism inside of it. You can purchase DVD lens cleaner from any large retail store that has an electronics section. However, if you clean it and the problem persists, it will likely be cheaper to replace the unit rather than trying to have it repaired unless you're under warranty in which case any repair or exchange will be covered by said warranty. If you call the manufacturer they will give you your full range of options.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Aug 04, 2009 | kawasaki PVS1965 Portable DVD Player
Philips PET710 DVD player shows 'no disc' when disc inserted
I have the same problem with my portable dvd player and found that cleaning the lens of the player using a non-alcolhol wet nap for cleaning eye glasses worked well. I also found the rail that the optics runs along while playing needed a very small amount of silicone greese applied using a Q-tip. You may find that the optic unit may be "stuck" somewhat but can be resolved by gently moving the optic along its guide using a finger.
This changed my unit from not working at all, to working intermittantly sometimes having to vary the player on and off to recongnise the disc. Hope this works
Jul 28, 2009 | Philips PET710 Portable DVD Player
Dvd plays cd's but not dvd's - gives no disc message
I have a durabrand portable dvd player we've owned for about 1yr and had just started messing up. When you put the dvd in it says it's loading and shows the blue dvd screen it just wont come on but you can hear it trying, please help what could be wrong?
Aug 12, 2008 | Durabrand DUR7 Portable DVD Player
Problem with dvd player. Trutech 7 inch
I was told that they could reset it but I can not find a number on this company
Mar 20, 2008 | TruTech PVS12701 Portable DVD Player
Sony DVP-FX780 7" Portable DVD Player Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
